bobsallyh Posted September 15, 2019 Report Share Posted September 15, 2019 Has anyone or knows of somebody who has an integrated brake controller on newer pickup trucks that went belly-up? With the truck out of warranty, they were quoted some high price to fix the problem. So instead, they installed an "old school" brake controller like a Prodigy, etc. Quote Link to comment Share on other sites More sharing options...
Jennifer Ministries Posted September 15, 2019 Report Share Posted September 15, 2019 My Integrated brake controller is receiving power but never shows that a trailer it attached. I checked the 7 pins and they all have power. The trailer brakes has a very low electrical energy that flashes on and off. Quote Link to comment Share on other sites More sharing options...
Chalkie Posted September 15, 2019 Report Share Posted September 15, 2019 (edited) This may be a silly question, but my truck has TWO fuses for the trailer brake controller. Have you made sure that all related fuses have been replaced and not just checked? It is possible to have a fuse check good and still be bad. Edited September 16, 2019 by Chalkie Quote Link to comment Share on other sites More sharing options...
bobsallyh Posted September 16, 2019 Author Report Share Posted September 16, 2019 This Ford truck is not mine. The friend got it back the end of last week from the Ford dealership since they had to order parts. But it still doesn't work. Of course the dealership didn't try it with trailer in tow. If it were mine, I'd try a Prodigy. Hot wire to the battery and find the brake light wire going to the taillights. What I question is if the ECM would pitch a fit. Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted September 16, 2019 Report Share Posted September 16, 2019 What year is the truck? Is the brake controller completely dead or just not working correctly? Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 16, 2019 Report Share Posted September 16, 2019 Last winter I had a customer ask me about the same problem. The fifthwheel side of the situation worked. But the truck did not pass power on the female receptacle. I walked over to a neighbor in the campground that I had to talk to for a minute and his friend asked me what I was working on. I told him what was working and what was not. He said he had the same problem on his Chevy truck. It turned out to be a relay, fuse or something that GM put under the spare tire on his truck. But on this GM truck they installed it behind the rear axle, on the inside of the frame. Now on the truck that I worked on it had two small bolts holding it to the frame. You could look in behind the rear wheel and see the 10 mm bolt heads sticking there. The neighbor friend even had a spare part. We installed it and it made the system work. Now why did they install it there????? Just an idea,. Vern Quote Link to comment Share on other sites More sharing options...
Chalkie Posted September 16, 2019 Report Share Posted September 16, 2019 Another thought, rather than purchasing an aftermarket brake controller, if you are convinced the integrated one is bad, why not replace the trailer brake controller module with a new one? They can be had from Rockauto for about $85 which is likely less than a decent aftermarket controller. I did not post a link to the part as it it may be year/model specific. Quote Link to comment Share on other sites More sharing options...
