DavidCD Posted September 11, 2019 Report Share Posted September 11, 2019 Hello everybody, I just replaced our 7 year old Suburban SW6DE water heater with a new unit (same model). The old unit was mounted on a cradle of plywood with 2 short lengths of 2x2 screwed onto the plywood as chocks that press on each side of the bottom edge of the water heater. The new unit - also a SW6DE - is slightly smaller in diameter than the original unit. It's the same 6 gallon capacity tank so I'm thinking the foam insulation must be a bit thinner on the new unit. So, there is gap - about 3/8 inch total - between the chocks and side of the new water header which I have shimmed with some scrap wood and the fit is now snug in the cradle. I was surprised that the old heater was not strapped down; it just sat in this cradle. The only structural connection between the heater and the travel trailer were three long screws that passed through brackets on the heater door frame and screwed into the face of the heater's control housing. I was not impressed with the heater just being secured by the three screws but that's the way it has ridden since we've had the trailer. Are everyone's water heaters installed like this or are there some strapping or stronger brackets used? Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 11, 2019 Report Share Posted September 11, 2019 What you describe is pretty standard instalation. I have never seen that develop into a problem. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
DavidCD Posted September 12, 2019 Author Report Share Posted September 12, 2019 Thanks for your reply, Kirk. I'm surprised the water heater hasn't jumped off that little cradle that it sits in - I've hit some really major pot holes (I-10 at Orange, Tx ; I-40 in Oklahoma) and had the seat cushions fly. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 13, 2019 Report Share Posted September 13, 2019 I would agree with you on the surprise as it is fairly heavy when full of water too. Even so, it seems to be what all manufacturers have been doing for a long time and appears to work. When I did what you are now I considered tieing mine down but to do so might have crushed the foam under any strap and mine had been riding that way for nearly 10 years with most of that fulltime travel so I didn't modify it. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
chirakawa Posted September 13, 2019 Report Share Posted September 13, 2019 My water heater weighs 100 lbs and is connected to rigid piping, not to mention the screws in the front. The wedges keep it from sliding fore or aft. I can't imagine it moving much. Quote Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Ray,IN Posted September 14, 2019 Report Share Posted September 14, 2019 9 hours ago, chirakawa said: My water heater weighs 100 lbs and is connected to rigid piping, not to mention the screws in the front. The wedges keep it from sliding fore or aft. I can't imagine it moving much. I agree, and if one were to experience a roll-over or crash that did move the heater, it is the least of the resulting problems. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
