noteven Posted September 14, 2019 Report Share Posted September 14, 2019 (edited) ..... Edited September 15, 2019 by noteven Off topic Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Pete Kildow Posted September 14, 2019 Report Share Posted September 14, 2019 (edited) First off 18 DO is killing you, if your running in 18th gear. People think OD gets you the best MPG. It will not do it in any truck. Now you can take that 18OD and run it in direct. That is where your going to do best on Fuel. Not sure the model # of your trans, but 14th should be direct for you. With your gears you should be turning around 1350 at 65 +/- 2 or 3 MPH. But that can depend on if the truck is still running the factory tire size. As some change tire sizes to do a poor man's gear change. But your driving a brick, and not going to get the MPH the better air stream trucks can get. Used to run a 1989 379. 18 DO top gear was back to the dash. 24.5 tall rubber, 3.36 rears. Fuel was turned up beyond hot. I had to drive by the Exhaust temps even empty. That truck was a triple digit truck. And had it running those numbers a lot back in the late 80's early 90's. Got a unreal 3.1 MPG. But fuel was cheap, speed make money. Left lane truck it was, fuel sipper it was not. Went into a T600 right after that truck. Set up the same way, run it the same way for 6 months. That truck would bet 5 MPG running hard all the time never shut off while on the road. But run it normal and seen 7 out of it easy. But when fuel is no though. And we all ran outlaw, it was fun. But no way would I run a brick today. If I wanted to get great MPG. My 1995 T600 11.1 Detroit series 60, 400HP, 10 speed direct, 2.93 rearend along with 295/22.5 tires. 65 MPH is only cruising. And gets unreal MPG, but it was set up that way in 1995. By a company that wanted to save on fuel. Edited September 14, 2019 by Pete Kildow Quote Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 14, 2019 Author Report Share Posted September 14, 2019 48 minutes ago, Pete Kildow said: First off 18 DO is killing you, if your running in 18th gear. People think OD gets you the best MPG. It will not do it in any truck. Now you can take that 18OD and run it in direct. That is where your going to do best on Fuel. Not sure the model # of your trans, but 14th should be direct for you. With your gears you should be turning around 1350 at 65 +/- 2 or 3 MPH. But that can depend on if the truck is still running the factory tire size. As some change tire sizes to do a poor man's gear change. But your driving a brick, and not going to get the MPH the better air stream trucks can get. Used to run a 1989 379. 18 DO top gear was back to the dash. 24.5 tall rubber, 3.36 rears. Fuel was turned up beyond hot. I had to drive by the Exhaust temps even empty. That truck was a triple digit truck. And had it running those numbers a lot back in the late 80's early 90's. Got a unreal 3.1 MPG. But fuel was cheap, speed make money. Left lane truck it was, fuel sipper it was not. Went into a T600 right after that truck. Set up the same way, run it the same way for 6 months. That truck would bet 5 MPG running hard all the time never shut off while on the road. But run it normal and seen 7 out of it easy. But when fuel is no though. And we all ran outlaw, it was fun. But no way would I run a brick today. If I wanted to get great MPG. My 1995 T600 11.1 Detroit series 60, 400HP, 10 speed direct, 2.93 rearend along with 295/22.5 tires. 65 MPH is only cruising. And gets unreal MPG, but it was set up that way in 1995. By a company that wanted to save on fuel. This is fact. Direct, though OD is but parasitic drag, will always be the most efficient. To prove this to myself, this last trip I did in fact run in 16th any time speed fell below 60 or so. Prior trips were 7-4 and 7.6mpg running in 18th at all speeds over 55. According to gps speed, my truck speedo reads 2-3 mph fast. So 68ish is 65. It does have low pro 22.5s, not sure original spec as I have not looked it up. Reason for 16th vs. 17th, is the thumb splitter valve leaks when in low position. Soon as I fix it, I will try running in 17th when possible. Trans is RTLO-18918B Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Mastercraft Posted September 14, 2019 Report Share Posted September 14, 2019 At 52,000 lbs, and an 18 ft gap between truck and trailer, going 63-65, it does 7.0 to 7.2 mpg by the mileage guesser, 3.36 rear and OD Ishift. 7.5 mpg from top off to top off if you calculate. D16 engine. Your mileage may vary. As long as I don't have to stop for fuel to get half way across the country, don't really care about whether I am at 7 or 12 mpg. Considering the other HDT costs, even if you do the work yourself, fuel ain't that big a deal. For example, had ours for 8 yrs. Did 10 new tires before this summers adventure cause 8 yrs is pushing it....makes the difference between 7 and 10 or 11 mpg seem like noise. My routes are all Colorado, Az, Wy, Montana, SD, so no Kansas flat data to report. Quote 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 15, 2019 Report Share Posted September 15, 2019 Having pulled 2 different RV's with the same truck, the shorter, 6000lb less weighing, more aerodynamic rear of the Carrilite gave us better mileage than the DRV which is 46', 24800lbs, and a flat straight roof. The Carrilite was a tapered roof that I believe had less drag. Our truck bed is short, which keeps the cab and front cap about 2 foot apart. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Scrap Posted September 15, 2019 Report Share Posted September 15, 2019 17th is main box in overdrive and aux box in underdrive, which is the most inefficient combination in the upstairs - something like 90-92%. So it should be worse numbers. Worth a try though as it won't hurt anything in a 9-series to run it and it'll see if your numbers can see the resolution. Quote Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 16, 2019 Author Report Share Posted September 16, 2019 16 hours ago, Scrap said: 17th is main box in overdrive and aux box in underdrive, which is the most inefficient combination in the upstairs - something like 90-92%. So it should be worse numbers. Worth a try though as it won't hurt anything in a 9-series to run it and it'll see if your numbers can see the resolution. Great info. I had not looked up the actual selection configuration for this trans. Typically, at least in a smaller torque trans, the OD drag is small enough to be considered parasitic, and in many cases, the gain of putting the engine in a more efficient range would outweigh the small loss. If your 90-92% range holds true however, it may be a wash or even a further loss as you suspect. Gunna try it when I get the valve fixed though just for the knowledge. Thank you for the reply. I appreciate them all. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 16, 2019 Author Report Share Posted September 16, 2019 Ok, so.......I'm pretty sure "Leroy" belongs to an Escapee. ? Here's a video that states mileage even with a D16. If my 379 were'nt so darn awesome styling, I'd be even more excited to look at the Volvo. But my gf and I are plus size and the gap between the seats, though tolerable for our younger age, is not the most friendly. We're weekend warrior types at this point and will continue to run solo without trailer for a while yet. So the sleeper is our main cabin. Spent 5 days in it over the labor day weekend and we feel we could easily do a 10 day run given the amount of driving we prefer. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
rickeieio Posted September 16, 2019 Report Share Posted September 16, 2019 "Smiles per gallon" trump "miles per gallon". 😉 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
mr. cob Posted September 16, 2019 Report Share Posted September 16, 2019 2 hours ago, rickeieio said: "Smiles per gallon" trump "miles per gallon". 😉 Howdy rickeieio That’s a BIG 10-4, Honk, Honk! Dave Quote 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
mr. cob Posted September 16, 2019 Report Share Posted September 16, 2019 4 hours ago, Deezl Smoke said: Ok, so.......I'm pretty sure "Leroy" belongs to an Escapee. ? Here's a video that states mileage even with a D16. If my 379 were'nt so darn awesome styling, I'd be even more excited to look at the Volvo. But my gf and I are plus size and the gap between the seats, though tolerable for our younger age, is not the most friendly. We're weekend warrior types at this point and will continue to run solo without trailer for a while yet. So the sleeper is our main cabin. Spent 5 days in it over the labor day weekend and we feel we could easily do a 10 day run given the amount of driving we prefer. Howdy Deezl Smoke, Like I said in an earlier post for everyday practical reasons, my Freightliner was a better truck for RV purposes including passage between the seats and general cab space, if it had been able to carry a Smart Car, on the deck I would not have bought-built another truck. The cost to rebuild the Freightliner to be able to carry a Smart Car, would have never been recovered when I eventually sold the truck so to me when I decided to carry the Smart Car, on the truck it made sense to sell the Freightliner, which I ended up selling for pretty much what I paid for it less the cost of the repairs I had put into it. As I was going to build a truck I thought I would build what I wanted not what someone else had built. I remember three years a go I started a thread stating that I was thinking real hard about selling the Freightliner and building a classic truck that I KNEW would not be as practical for RV use but it would be the type of truck that "I" love, I decided then that it would either be a Pete 379, extended Hood or a Kenworth 900, extended Hood nothing else would be considered. It took a year to find the truck I wanted and another six months to build it but I am HAPPY with it. My aero Freightliner and the Volvo's are good trucks of that there is no doubt but as a life long gear head to me they just have no soul, they are an appliance that does a great job of moving freight but they have no style. I KNOW style is in the eyes of the beholder but to me nothing beats the LOOK of a classic "Hood" everything comes at a cost, that cost is something that has to be considered whenever a person does anything, I am 71 years young, I am a hot rodder of the old school, I don't plan on ever growing up no matter what age I live to so darn it I am going to enjoy my remaining driving years in the truck that "I" want and enjoy. Hopefully when the time comes to hang up the keys I'll be able to find another person who will buy my truck who will enjoy it as much as I do and treat it well. Here's a photo of my Freightliner, a great truck in its own right but which would you rather drive, the Freightshaker or the Pete? Dave Quote 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 17, 2019 Author Report Share Posted September 17, 2019 5 hours ago, mr. cob said: Howdy Deezl Smoke, Like I said in an earlier post for everyday practical reasons, my Freightliner was a better truck for RV purposes including passage between the seats and general cab space, if it had been able to carry a Smart Car, on the deck I would not have bought-built another truck. The cost to rebuild the Freightliner to be able to carry a Smart Car, would have never been recovered when I eventually sold the truck so to me when I decided to carry the Smart Car, on the truck it made sense to sell the Freightliner, which I ended up selling for pretty much what I paid for it less the cost of the repairs I had put into it. As I was going to build a truck I thought I would build what I wanted not what someone else had built. I remember three years a go I started a thread stating that I was thinking real hard about selling the Freightliner and building a classic truck that I KNEW would not be as practical for RV use but it would be the type of truck that "I" love, I decided then that it would either be a Pete 379, extended Hood or a Kenworth 900, extended Hood nothing else would be considered. It took a year to find the truck I wanted and another six months to build it but I am HAPPY with it. My aero Freightliner and the Volvo's are good trucks of that there is no doubt but as a life long gear head to me they just have no soul, they are an appliance that does a great job of moving freight but they have no style. I KNOW style is in the eyes of the beholder but to me nothing beats the LOOK of a classic "Hood" everything comes at a cost, that cost is something that has to be considered whenever a person does anything, I am 71 years young, I am a hot rodder of the old school, I don't plan on ever growing up no matter what age I live to so darn it I am going to enjoy my remaining driving years in the truck that "I" want and enjoy. Hopefully when the time comes to hang up the keys I'll be able to find another person who will buy my truck who will enjoy it as much as I do and treat it well. Here's a photo of my Freightliner, a great truck in its own right but which would you rather drive, the Freightshaker or the Pete? Dave A hunnerd percent understood and agree on the EXHD. Hence the reason I ended up with the 2005 379X I have. I used to have a white/purple FLD120, 12.7 DD. Though it turned in less than half the radius of my X, which is the truck's name, I just could'nt get that feeling of awe that a 379, or as you mention, a W900 give. I'm 56 and my gf is 54. We both love improvising our own inventions and love ever so much that we can say "we made that". Don't matter what others think, it's what we think that matters. As you can see from the photo of my X, it is improvised and under construction. But we love it. I'm not so sure a Volvo has no soul. A bone stock 379 or 900 does nothing more me than a fld120 etc. But a drop visored, unltra cab with stacks and a texas bumper?...........wood. I've seen some really cool graphic packages and ground effects on volvos that make them stand out and really look good. Is the front cowl under the windshield on you Pete fiberglass or aluminum? Mine is fiberglass and the wiper shaft support bumps have been broken. Looking for a fix. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
mr. cob Posted September 17, 2019 Report Share Posted September 17, 2019 Howdy Deezl Smoke, Under the windshield on my cab is aluminum, I can’t remember where I saw it but one of the large custom truck parts shops sells a kit to fix your problem. Dave Quote 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
Scrap Posted September 17, 2019 Report Share Posted September 17, 2019 Can you guys put the KW stowable armrests that fold back on your Peterbilt seats? I've never tried it but a National seat is a National seat... They give quite a bit more width. Quote Link to comment Share on other sites More sharing options...
mr. cob Posted September 17, 2019 Report Share Posted September 17, 2019 Howdy Brian, Speaking of seats, if you ever run across a deal on used or take out seats that will fit my Pete, let me know. Thanks. Dave Quote 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 17, 2019 Author Report Share Posted September 17, 2019 9 hours ago, Scrap said: Can you guys put the KW stowable armrests that fold back on your Peterbilt seats? I've never tried it but a National seat is a National seat... They give quite a bit more width. OMG !!! That is just what I need. Thank you very much for the picture and info that that is available. I try to be price conscience, but I am willing to pay for that option. That is awesome. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 17, 2019 Author Report Share Posted September 17, 2019 11 hours ago, mr. cob said: Howdy Deezl Smoke, Under the windshield on my cab is aluminum, I can’t remember where I saw it but one of the large custom truck parts shops sells a kit to fix your problem. Dave Super. Thanks Dave. Then I will be making some calls today. I already tried Peterbilt and they only sell the whole cowl. Don. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 17, 2019 Author Report Share Posted September 17, 2019 (edited) Mr.Cob, Dave, just saw your truck on Suite Travels west coast rally video. NICE. Very nice. Edited September 17, 2019 by Deezl Smoke Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
mr. cob Posted September 17, 2019 Report Share Posted September 17, 2019 3 minutes ago, Deezl Smoke said: Mr.Cob, Dave, just saw your truck on Suite Travels west coast rally video. NICE. Very nice. Howdy Don, It puts a grin on my face and that's all that really matters. Thanks for the compliment, can you post up some photos of your truck and what you have done to it? If your bored click this link it will take you to the photo gallery detailing the build of my Pete. https://mr-cob.smugmug.com/My-2001-Peterbilt-379-RV-Hauler/ Dave Quote 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 19, 2019 Author Report Share Posted September 19, 2019 Dave, I dont have to be bored to see truck porn. d:-) I'll go to your site this evening when Cari (my gf) is with me. I only have a few pictures so far, and I do not have a hosting site anymore since photobucket went commie, so I'll have to put a few replies with small pics, but i will keep it to a minimum. Thanks. Don. Oh ya, I've been calling around the big rig shops looking for the fiberglass fix for the ww, but no luck so far. Maybe there is still a chance that a fix it kit would sell? When I got it back from having the commercial name and number taken off. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 19, 2019 Author Report Share Posted September 19, 2019 Backed into the farm shop to prepare for removal of the power divider axle. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 19, 2019 Author Report Share Posted September 19, 2019 Singled long. Rig Master APU. I love that style apu and if I ever have a second truck, it will end up with a diy copy of that style. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
mr. cob Posted September 19, 2019 Report Share Posted September 19, 2019 Howdy Don, I love the color, having an APU, is great. I don’t have one but do have a small Honda 2000 watt generator that if I can figure out a place to mount it I will install someday. Any interior photos you would like to share? Dave Quote 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
Deezl Smoke Posted September 19, 2019 Author Report Share Posted September 19, 2019 Not yet. I'll be at the rig later, and will try to get a few. This was our first trip out. The welds were still warm on the container rails. Last second assembly. But we had a blast and really got hooked on the redneck improvised build. This pic is from a fossil hill at Clarno Oregon. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted September 19, 2019 Report Share Posted September 19, 2019 Your truck looks like a toy in that photo Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
