Barbara Posted September 10, 2019 Report Share Posted September 10, 2019 Want to pull a travel trailer with a 2018 chevy Transverse. There would be three adults three dogs. What kind of trailer would you recommend for us to travel in? Thank you Quote Link to comment Share on other sites More sharing options...
SWharton Posted September 10, 2019 Report Share Posted September 10, 2019 Does it have the towing package? Look on the door for a sticky with your towing capacities and get back to us. With 3 adults and 3 dogs you are reducing your weight. Are the dogs big or small? Quote Link to comment Share on other sites More sharing options...
filthy-beast Posted September 10, 2019 Report Share Posted September 10, 2019 Do you have the 3.6L engine and tow option? IF so max is 5000 pounds. Look on your door for the GVWR, this is the max the Transverse can weigh. Look for GCWR, this is the max the Traverse plus the trailer can weigh. Now here's the most import thing to find. How much does the Traverse weigh with a full tank, three adults, three dogs and cargo in the back. Are these NFL linemen and mastiffs or size 0 petite models and pugs? You cannot go by printed material as every option added reduces cargo capacity. Load up and go to a truck stop to get weighed, cost less than $20 last time I did it. Once you know the real curb weight fully loaded, minus it from GVWR. The difference will be the max tongue weight the trailer can add. I would not run at or near max, I always want a safety margin. for a travel trailer you want 10% to 15% of the total weight to be on tongue. Quote 2020 Platinum F350 6.7L CC DRW, 2021 Riverstone Legacy 37mre 5th wheel Link to comment Share on other sites More sharing options...
2gypsies Posted September 10, 2019 Report Share Posted September 10, 2019 After doing all the above recommendations I would guess you will have a tiny trailer. Quote Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
Kirk W Posted September 10, 2019 Report Share Posted September 10, 2019 Welcome to the Escapee forums. With any version of that vehicle you will be very limited in what you can safely tow. From Cheverolet: Quote Trailering Capacity (lb. / kg): 5000 / 2268 (3.6L with avail. trailering pkg.) 1500 / 680 (2.0L with avail. trailering pkg.) If you have one of the front wheel drive models you will be limited to a maximum towing weight of 1500# which means a small popup trailer is about the limit. If you have an all wheel drive with a V-6 and towing package you are then safe with up to 5000# of RV, which still limits you to something around 20' maximum length if it is an ultral lite trailer. It is critical that you keep these weights in mind when you shop for an RV as if you exceed them you will find it very difficult to control and tiring to drive. If conditions get difficult you will be in danger if you try to tow too much. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted September 11, 2019 Report Share Posted September 11, 2019 (edited) I think you will find this TT towing calculator quite accurate and helpful when deciding what travel trailer your towing vehicle will safely handle. Please note, some boxes require actual weights instead of published figures. Edited September 11, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
LindaH Posted September 11, 2019 Report Share Posted September 11, 2019 I would suggest you change the subject line of your post to reflect your question rather than using your name. Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
FL-JOE Posted September 13, 2019 Report Share Posted September 13, 2019 Welcome to the forum. Like Kirk said, you will no doubt be limited to a small pop up type camper. Quote Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
markandkim Posted September 13, 2019 Report Share Posted September 13, 2019 1 hit wonder. Shes not coming back. Quote Retired USN Engineer 2020 Ram 2500 Bighorn 6.7 Diesel 2014 Crossroads Zinger 27RL (Traded) 2022 Grand Design Reflection 315RLTS Link to comment Share on other sites More sharing options...
Kirk W Posted September 13, 2019 Report Share Posted September 13, 2019 7 minutes ago, markandkim said: 1 hit wonder. Shes not coming back. She was signed in just yesterday but didn't post anything. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted September 14, 2019 Report Share Posted September 14, 2019 Given the replies she received, this may be a moment of truth for her, or as a professor once said, " that was a significant emotional event." It will take time for her to process all the information, and I expect her return after that happens. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
SnowGypsy Posted September 14, 2019 Report Share Posted September 14, 2019 In our owner's manuals for our vehicles, it lists information on towing, so that is where I would start. This is a good website for becoming familiar with the terminology, etc. when it comes to RVing explaining stuff in a user friendly manner: http://changingears.com/ Also, if the trailer is going to be just for weekends or vacations, there might be something that would work, but if 1500 lb limit, looking at something "barebones" in a pop-up or something like a mini-camper (basically a place to sleep) like the Runaway Campers, Escapade campers, and Aliner has come out with a new family unit that is mostly beds and nothing else although I couldn't get a weight on that. We just need to better understand what Barbara's needs are. It can be really intimidating to be a "newbie" among those that are experienced. We bought our first pop-up used a couple of blocks from our house in 1984! Quote Cathy Link to comment Share on other sites More sharing options...
