dewilso Posted August 31, 2019 Report Share Posted August 31, 2019 Is there a "standard" for propane quick disconnects, or are they like cell phone charging cables where they won’t play well with each other? Quote Dave W. KE5GOH Stuck in the 70's --- In E. Texas Link to comment Share on other sites More sharing options...
Danandfreda Posted August 31, 2019 Report Share Posted August 31, 2019 Hard to find at local stores I couldn’t even get them at local propane filling places. Amazon has them all I replaced the hose on out gas propane grill so I could run it off our outside quick disconnect propane line under the rv. Just had to take off the second regulator. Rv stores didn’t even have them. Lowes has the female fitting I think but not the male. Quote Link to comment Share on other sites More sharing options...
agesilaus Posted August 31, 2019 Report Share Posted August 31, 2019 Don't know about propane disconnects but industrial tubing disconnects are manufacturer specific since I bought a number of them over the years. I suspect the propane ones are the same. Quote Link to comment Share on other sites More sharing options...
bobsallyh Posted August 31, 2019 Report Share Posted August 31, 2019 I got mine at local propane suppliers when I had the hoses made up. I think they are set up for the very low pressure which comes from the regulator. Mine has a ball valve shut off with a handle on it. The handle will not open if the quick disconnect is not in the fitting properly and the whole way. Quote Link to comment Share on other sites More sharing options...
dewilso Posted September 1, 2019 Author Report Share Posted September 1, 2019 I know where to get them, they are pretty common items. But the question is if I get a brand Y from Wally, will it fit the brand B from Ace ? My experience is “usually”, but the Buddy item FE doesn’t work with others. Quote Dave W. KE5GOH Stuck in the 70's --- In E. Texas Link to comment Share on other sites More sharing options...
Kirk W Posted September 1, 2019 Report Share Posted September 1, 2019 11 hours ago, dewilso said: My experience is “usually”, but the Buddy item FE doesn’t work with others. I do believe that you have your answer. There are also quality differences from one manufacturer to the next. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ronbo Posted September 2, 2019 Report Share Posted September 2, 2019 If you are looking for the barbecue connection, go to a RV center. Be aware they are not all the same. I replaced my coupler and could not get gas to flow. The new valve required a longer nipple. Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
