BROWD301213 Posted August 21, 2019 Report Share Posted August 21, 2019 Hi i have a Flagstaff by forest river and the 12v lights are very dim and there is a red light flashing under the worktop where the wiring is do i need to reset anything if so advice would be greatly appreciated. Thanks Anthony Quote Link to comment Share on other sites More sharing options...
Kirk W Posted August 21, 2019 Report Share Posted August 21, 2019 Welcome to the Escapee forums! We will do our best tohelp you. It sounds like your battery voltage is low. Do you have a volt meter that you can check it with? Are you connected to 120V shore power at present? If so the converter should be supplying 12V power so that would indicate some other problem. A bad battery could cause low voltage and a defective converter could also. The red light is probably some sort of warning but I'd need more information about that to know anything specific. If you could post a picture of the red light it might help. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Daveh Posted August 21, 2019 Report Share Posted August 21, 2019 What Kirk said. Quote Dave and Lana Hasper Link to comment Share on other sites More sharing options...
