Exile Posted August 18, 2019 Report Share Posted August 18, 2019 Any recommendations for a code reader? it has a round connector, can’t remember if it is 6 or 9 pin. threw it twice while idling yesterday and shut down an hour away from my house on maiden voyage, then restarted and drove home no issues. This am, threw it twice and shut down. Found what appeared to be the main computer power wire loose. Tightened it up and went on a test drive just fine. it would be nice to know what the codes are though. Tried searching this site, didn’t come up with much. Trucking sites don’t say much either. Quote 98 379 with 12.7 DD LG Dodge w/5.9 CTD Chrome habit I’m trying to kick. Link to comment Share on other sites More sharing options...
chief916 Posted August 18, 2019 Report Share Posted August 18, 2019 24 minutes ago, Exile said: Any recommendations for a code reader? it has a round connector, can’t remember if it is 6 or 9 pin. threw it twice while idling yesterday and shut down an hour away from my house on maiden voyage, then restarted and drove home no issues. This am, threw it twice and shut down. Found what appeared to be the main computer power wire loose. Tightened it up and went on a test drive just fine. it would be nice to know what the codes are though. Tried searching this site, didn’t come up with much. Trucking sites don’t say much either. I believe you can go to www.detroit diesel ecm codes. Not sure if exact wording but check around and you should find what you're looking for. Quote Link to comment Share on other sites More sharing options...
Exile Posted August 20, 2019 Author Report Share Posted August 20, 2019 Thank you, I finally know what the “diagnostic “ switch on the dash is for, i feel like a dummy. no active check engine light engine now, but shows throttle position sensor low voltage using diagnostic switch, so i will check that out. Quote 98 379 with 12.7 DD LG Dodge w/5.9 CTD Chrome habit I’m trying to kick. Link to comment Share on other sites More sharing options...
chief916 Posted August 22, 2019 Report Share Posted August 22, 2019 On 8/20/2019 at 7:46 PM, Exile said: Thank you, I finally know what the “diagnostic “ switch on the dash is for, i feel like a dummy. no active check engine light engine now, but shows throttle position sensor low voltage using diagnostic switch, so i will check that out. No problem....it's all a learning curve. Just so you know...I keep a upper and a lower sensor spare on the truck when we travel. The bottom sensor can be a bear to remove because it's right up next to and behind the air compressor. Quote Link to comment Share on other sites More sharing options...
