dirtyboots Posted August 18, 2019 Report Share Posted August 18, 2019 I've found these two shops - https://www.idahorv.com which is located in an RV park in Wendell and this one in Kimberly https://snakerv.com/quick-response/ that will travel to location. Any experience and/or other recommendations? Thanks! Quote Link to comment Share on other sites More sharing options...
bobsallyh Posted August 18, 2019 Report Share Posted August 18, 2019 dirtyboots, there is Frankie's RV repair that is mobile. We just spent a month at US 93 RV at Twin and he was in and out of there several times. There is also another mobile guy that was in and out of there that has a white pickup with a tall cap over the bed that just has "RV Repair" lettered on the cap . I don't know about the other two but Intermountain is located along I-84. Try calling US 93 RV park and they maybe able to give you info on the two I mentioned. Quote Link to comment Share on other sites More sharing options...
dirtyboots Posted August 18, 2019 Author Report Share Posted August 18, 2019 Thanks! I'm still up in Challis but will leave in a few days in that direction. No reservations yet....so open to where I might land - hopefully near a good RV repair shop/mobile. Luckily the issues I need looked at haven't stopped my travels....yet! Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted August 18, 2019 Report Share Posted August 18, 2019 What do you need looked at? Quote Link to comment Share on other sites More sharing options...
dirtyboots Posted August 18, 2019 Author Report Share Posted August 18, 2019 10 minutes ago, DesertMiner said: What do you need looked at? Have a couple LED interior lights that have gone 'on the blink' . The converter (?) breaker has tripped and would like to find out why - and was in a big hail storm at North Fork, so would like the roof checked. Probably a couple other items I can't remember at this moment.... Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted August 18, 2019 Report Share Posted August 18, 2019 Can you replace the LED bulbs? Did the C/B reset? Quote Link to comment Share on other sites More sharing options...
dirtyboots Posted August 18, 2019 Author Report Share Posted August 18, 2019 45 minutes ago, DesertMiner said: Can you replace the LED bulbs? Did the C/B reset? When I took the lights snap on cover off found there are NO bulbs....was told the light fixture needs replaced. Reset the breaker (it's happened a couple times) and all is well battery wise, just need to find out what is causing the failure. Thanks for being helpful. Quote Link to comment Share on other sites More sharing options...
ms60ocb Posted August 18, 2019 Report Share Posted August 18, 2019 I don't know what your RV is, but the Circuit breakers be for the 120 vac equipment and the LED's would be part of on your 12 vdc circuits which are fused. What is that Circuit breaker servicing? Clay with a FW Quote Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
dirtyboots Posted August 18, 2019 Author Report Share Posted August 18, 2019 (edited) 48 minutes ago, ms60ocb said: I don't know what your RV is, but the Circuit breakers be for the 120 vac equipment and the LED's would be part of on your 12 vdc circuits which are fused. What is that Circuit breaker servicing? Clay with a FW My RV is a bumper pull toy hauler - the circuit breaker is labeled CONV. Any more than that is why I'm looking for an RV repair person. Everything else is above my pay scale....! Appreciate your help. BTW - I'm not saying the two problems are connected. The lights have been bad for a while. These are just things I need attended to that have happened while I've not been close to a larger area with RV repair. Edited August 18, 2019 by dirtyboots Quote Link to comment Share on other sites More sharing options...
ms60ocb Posted August 18, 2019 Report Share Posted August 18, 2019 On my FW that would be my Battery Charger/invertor (12 vdc to 120 vac)., so watch your battery Voltage. Of course as you travel the truck should put some charge into the battery(s). Good luck and happy travels Clay Quote Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
