GimmyTree Posted July 20, 2019 Report Share Posted July 20, 2019 (edited) I have just ordered a very pricey LiFePO4 battery to go with my 160 watt solar panel. Now I want a MPPT controller and I was hoping someone here could confirm this is the correct controller for the battery and panel. I believe it is the correct controller but I would like a second opinion please. The charge controller:https://fazcorp.co.nz/collections/mppt-s...v-ml2430-1 With a MPPT Bluetooth Communication Module so I can monitor the solar system from my Amazon Kindle:https://fazcorp.co.nz/collections/mppt-s...ies-bt-1-1Solar panel: Standard power: 160 Watts Maximum power voltage: 17.8 Maximum power current: 9.0A Open Circuit voltage: 21.1V Short Circuit current: 9.5ALiFePO4 battery: Nominal voltage: 12v Capacity: 100Ah Discharge cut-off voltage: 8.4v Operating voltage min 11.5 V - max 14.8 V At 80 % DOD Optimal discharge current < 50 A Charge voltage: 14.6v Edited July 20, 2019 by GimmyTree Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted July 20, 2019 Report Share Posted July 20, 2019 Check these out... https://www.victronenergy.com/solar-charge-controllers Quote Link to comment Share on other sites More sharing options...
GimmyTree Posted July 20, 2019 Author Report Share Posted July 20, 2019 8 hours ago, DesertMiner said: Check these out... https://www.victronenergy.com/solar-charge-controllers Thanks, I'm just taking a look now. Quote Link to comment Share on other sites More sharing options...
vermilye Posted July 20, 2019 Report Share Posted July 20, 2019 I'm using a Victron SmartSolar 100/30 with a pair of Battleborn batteries. So far it works great. I did have to set the parameters as suggested by Battleborn... Quote Travel photos RV Blogs Journals & Travelogues at:http://www.lakeshoreimages.com My Travel Blog - Jon's Journeys Link to comment Share on other sites More sharing options...
