Wrknrvr Posted July 6, 2019 Report Share Posted July 6, 2019 (edited) Just curious as to the thinking on greasing a Binkly hitch head. On top of the hitch is the tool I use to grease the underside of the hitch head. Was just reading the hitch post problem and wanted to share what I do. JJJust Curious,. Vern Edited July 6, 2019 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted July 6, 2019 Report Share Posted July 6, 2019 Anything is better than nothing. I use a similar tool to get grease into the bottom of the head. Between the pins being in single shear, and the inability to grease properly, the heads were designed as a wear item. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Pete Kildow Posted July 6, 2019 Report Share Posted July 6, 2019 I just spray mine, with white Lithium grease from a can. Worked for years, and easy to do. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted July 6, 2019 Report Share Posted July 6, 2019 1 hour ago, Pete Kildow said: I just spray mine, with white Lithium grease from a can. Worked for years, and easy to do. X2 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rdickinson Posted July 7, 2019 Report Share Posted July 7, 2019 8 hours ago, Pete Kildow said: I just spray mine, with white Lithium grease from a can. Worked for years, and easy to do. X2 Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 7, 2019 Report Share Posted July 7, 2019 I used to spray with white lithium grease, made a white gooey mess. Now I put on a vinyl glove and have a jar of marine axle grease I smear everywhere on jaws etc. Now I have a bluish black gooey mess 😜. BTW word of caution, don’t hit your head on the trailer pin or it will make your Brylcreem days seem like child’s play. Don’t ask me how I know. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Wrknrvr Posted July 7, 2019 Author Report Share Posted July 7, 2019 This what I do for greasing that unknown area. No it is not a perfect way to do the job. But any grease in that area is better than none. Some of that grease should find its way into moving parts. It can be aimed at the pivot points of the jaws, top and bottom. Also it can be pointed at the rotating pins also. Along time ago I had a good friend come buy for a month or so to visit. So we got there fifthwheel positioned in place. Went to unhook and it would not unlatch. Now this guy is very smart on mechanical things. Just never bought grease. I do not think he even had a grease gun. If he did I never seen it.. In another business I had for years I would look at used equipment for sale. So it was either new ( no grease at bearings ), or used and lots of grease at the bearings. But the worst thing was a used piece of equipment with rust at the moving parts. Jjjjust need to explain it better,. Vern Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted July 7, 2019 Author Report Share Posted July 7, 2019 https://images.app.goo.gl/fsus4eSa6c27wSBk6 i needed to use a different computer to post this picture. So if one put grease on top of the moving parts in this position it would help lube them .Not perfect but better. Vern Quote Link to comment Share on other sites More sharing options...
Pete Kildow Posted July 8, 2019 Report Share Posted July 8, 2019 11 hours ago, Wrknrvr said: This what I do for greasing that unknown area. No it is not a perfect way to do the job. But any grease in that area is better than none. Some of that grease should find its way into moving parts. It can be aimed at the pivot points of the jaws, top and bottom. Also it can be pointed at the rotating pins also. Along time ago I had a good friend come buy for a month or so to visit. So we got there fifthwheel positioned in place. Went to unhook and it would not unlatch. Now this guy is very smart on mechanical things. Just never bought grease. I do not think he even had a grease gun. If he did I never seen it.. In another business I had for years I would look at used equipment for sale. So it was either new ( no grease at bearings ), or used and lots of grease at the bearings. But the worst thing was a used piece of equipment with rust at the moving parts. Jjjjust need to explain it better,. Vern I grew up on a poor dirt farm. But dad did not save $$ on Oil or grease. 2 stroke outboard double oil. He told me plugs are cheaper then the engine. Commercial Fisherman also. All farm tractors and combine. You got it if it called for grease every 20 hours. We did it every am. Did not matter if the combine only ran 4 hours the day before. When we sold all the old stuff. Every bearing was still good. Nasty looking but sure greased. Today I grease everything more then needed. But keep it clean also. Ran up on a guy 3 years ago. Same Trailer saver hitch as mine. He was bragging it had been maintenance free for the last 6 years.🤬 Quote Link to comment Share on other sites More sharing options...
rickeieio Posted July 8, 2019 Report Share Posted July 8, 2019 Plain bearings like lots 'o grease. Sealed bearings,,,,, a little dab will do ya. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
