scotts Posted June 24, 2019 Report Share Posted June 24, 2019 i have a dometic stat that has the 3 wire connections, my issue is when the stat is set for heat and calls for the furnace the fan on the AC runs and the heater does operate, when temp is satisfied both turn off. To get around this i turn off the AC breaker and the furnace operates fine. Bad stat or "controller" in AC unit? Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted June 24, 2019 Report Share Posted June 24, 2019 What thermostat do you have. It may just need reprogrammed. Vern Quote Link to comment Share on other sites More sharing options...
scotts Posted June 24, 2019 Author Report Share Posted June 24, 2019 dont know M# and RV is not available, but it is square and has the digital square display in the center. during research it is being called Dometic Single Zone LCD RV Thermostat. hope this helps Quote Link to comment Share on other sites More sharing options...
Kirk W Posted June 24, 2019 Report Share Posted June 24, 2019 The actual control of which unit operates is in the air conditioner in most cases. Is it the one that looks like this? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
scotts Posted June 24, 2019 Author Report Share Posted June 24, 2019 exactly what i have just saw a video that said the fan may be set to blow all the time. but the video was fort a heat pump stat will that hold true for the pictured stat as well Quote Link to comment Share on other sites More sharing options...
Kirk W Posted June 24, 2019 Report Share Posted June 24, 2019 I haven't worked with that exact thermostat, but here is a place to get the operating manual for it if you don't already have a copy. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wrknrvr Posted June 24, 2019 Report Share Posted June 24, 2019 Read the manual on how to initiate the system. It will probably be at the end of the installation instructions. It mite be a little confusing but it is there. Print that and keep it handy. You may need it again. That is how to reset the controls. That may fix your problem. Safe Travels, Vern Quote Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted June 24, 2019 Report Share Posted June 24, 2019 You probably don't need to reset anything. I had the same one. It sounds like you have the fan set to either high or low. Push the mode button so the light by the fan is on and set it to auto. Easy to get confuzzled with them new fangled contraptions....... Quote Link to comment Share on other sites More sharing options...
scotts Posted June 24, 2019 Author Report Share Posted June 24, 2019 THANKS ALL!!!! Quote Link to comment Share on other sites More sharing options...
