Inverter mistake
runaway parents
Well I screwed up big time. I am admitting to this so I can try to keep someone else from doing this. Turned on inverter memorial day weekend to vacuum out the truck need less to say it got left on truck has been sitting since Then went to fire it up last night nothing not a light not any noise at all batteries totally dead. Thought I would hook up the old f250 and try to jump it. about 5 minutes of charging and the 780 came back to life. Was surprised the old f250 had enough in it to turn that big rig over. Hopefully I didn't ruin the batteries on the 780 we will see. The point to this story don't forget to turn those inverters off. Guess some of the newer rigs has a indicator light on dash  ours doesn't.
Some of the newer trucks have a low voltage shutoff that will disconnect most electrical loads when the battery voltage drops to a critical level. This ensures you have enough voltage left to start the truck. I know that late model Pete's and KW's are like this and I assume some of the other brands do as well.
As far as your batteries go, they had to be just below the threshold level to have enough voltage to crank the truck. If they had been in really bad shape, I doubt that 5 minutes from your F250 would have charged them enough to crank it back to life. You took a little bit of life from them but it shouldn't be as bad as you think it is.
2017 Kenworth T680
2015 DRV 38RSSA Elite Suites
2016 Smart Prime
To add to the mix,
My inverters are connected directly to the batteries so no protection from the truck, however, the inverters shut off at 10.5 volts.
Steve
4 hours ago, Carlos said:
Interesting, my tow vehicle won't let you run the inverter with the vehicle turned off.  It has to at least be in the accessory position.
My inverter doesn't look like it was installed at the factory. It has no indicator lights any ware  except on the inverter itself. Definitely aftermarket . But you know I wonder  if I could wire it to the accessory switch ? You got me thinking. Hmmm.
You can't wire the power inputs to accessory switches, because they draw a lot of power.  If the inverter has an on/off input, as many do, then you can drive that from any switch-only power.  That uses very little power.  The other option is a high-power relay.  Whatever watts it is rated for, divide by 12 and that's the amps you need to supply.
2 hours ago, runaway parents said:
Well my friend that is all it took 5 minutes and it turned over. You should never doubt someone you don't know it s like calling them a liar. Not a good idea!!!!!!!!!!!!
I didn't read that like that at all... Perhaps the point was that 5 minutes for the F250 was enough to get it started but as Sehc said, you might want to put a full charge on the batteries with a good charger.
Shawn and Andrea
Elvis the Cheagle Dog
2013 Volvo 730 / iShift / D13 XE Package / ET Hitch
2016 DRV Mobile Suites 43 Atlanta
2018 Jeep Wrangler Rubicon Unlimited
Read the blog at 40foothouse.com
I jumped my Pete with our dodge doully farm truck. Took a little longer than 5 minutes but less than 10. I have jumped semi trucks off all kinds of vehicles. Cars Pickups tractors whatever is handy. Sometimes it takes a half hour or longer but it gets the job done. You can jump start a semi off a Geo metro if you have all day.
Farmer, Trucker, Equipment operator, Mechanic
Quando omni flunkus moritati-When all else fails, play dead
I'm a man, but I can change, if I have to, I guess.
Are you sure that the F250 charged the batteries OR did the HDT just start from the F250 batteries? Guess it really doesn't matter as long as it started. I once started mine from a golf cart. Now that is embarrassing.🙄
Edited by Brad & Jacolyn
Brad and Jacolyn
Tucker the Wonder dog and Brynn the Norfolk Terrier
2009 Smart "Joy"
2004 VNL630 "Vonda the Volvo"
2008 Hitch Hiker 35 CK Champagne Edition
VED12 465 HP, Freedomline, 3.73 ratio, WB 218"
Fulltiming and loving it.
That’s not embarrassing, that shows you have brains.  Now if you pull started it with the golf cart  . . .
I want to see someone verify having jumped their truck with an electric wheelchair.
98 379 with 12.7 DD
LG Dodge w/5.9 CTD
Chrome habit I’m trying to kick.
1 minute ago, noteven said:
We jump start hunters without permission aka trespassers with a electric fencer.
My grandfather had his model T set up to give people a shock if they touched it.  Back in the days of dirt roads and leather shoes..
been trying to figure out how to rig up same system for my truck, especially the fuel tank.
98 379 with 12.7 DD
LG Dodge w/5.9 CTD
Used the smart car recently to boost a new to me farm truck special. Auction sale '77 Chevy crew cab dually, 454, TH400 auto. Sat for about 5 mins, fired her up. Used #2 gauge booster cables, mind you.
2007 32.5' Fleetwood Quantum
Please e-mail us here.
Great news  batteries seem to be ok .After getting it started with f250 we  drove it about 10 miles brought it home put it on charger for a day pulled charger let it sit till yesterday went out and fired  it  up took it out and put about a 100 miles on it every thing seems to be working fine. thought I was going to have to buy four new batteries PHEW that was a close one wallet feels a lot better!!!
Was the inverter supplying a load at the time?  All but the cheapest models cut off at 10.5 volts which is, BTW, considered a dead battery.  If there is no load on the output of the inverter the loss is minimal, usually one amp or less and the time required to drain the batteries could be days - but combined with additional loss through the truck electronics that stay on even when the key is off - the the time period could be shorter - much shorter.
My take is the truck batteries would have shown about 10.5 volts if you had checked them with a voltmeter.  Low enough that anything but pure resistive loads (like a filament lamp) would have stopped functioning.  While it is true that starting batteries like we have in our truck are more quickly ruined by full discharge than deep cycle batteries they are durable enough that a few dead cycles will not appreciably shorten their life span.  I am in total agreement that it would be beneficial to hook the batteries up to a 4-stage external digital charger for a couple of days being sure you have at least one boost cycle during that period.
I too have started my Volvo from a golf cart, but I was throwing 16 volts at the starter from two 200 Ah 8 volt batteries.  The battery in the lawn tractor would not do the job 😃.
As far as future battery discharge prevention - here is an idea.  Rather than try to switch the high amperage supply cables tap into the inverter on-off switch.  While some inverters have a RG-11 telephone wire type connection for on-off it works better to go inside the inverter and solder some wires to the inverter's switch to make your own remotely located on-off switch (leave the OEM inverter switch off).  This switch can be in the form of a N.O. relay that closes when 12 VDC is supplied to the coil when the ignition is on.  The same type of Bosch relay used throughout your truck works great and you can get them on eBay or Amazon with a pre-wired socket for just a few bucks.
Randy, Nancy and Oscar
How about a 10 year old 1.6L Nissan Sentra?  At one of our transmitter sites a Class 8 winch truck was stuck after the driver left the headlights on over a long weekend.
Amid much derision I jumpered the Sentra's battery to the big rig's 8Ds, ran the engine at a fast idle for 10 minutes and the truck started right up.
The Nissan's alternator did get a bit aromatic but it worked fine until I sold the car 8 years and 160,000 miles later.
12 volts is 12 volts.
Edited by Lou Schneider
The question would be current.  My Jeep has a huge alternator, the wife's BMW has a much smaller one.  Diesel trucks have two batteries or more, and large alternators.  The Nissan, not so much.  Jumper cable size matters a lot also.  I can (have) instantly jump a large truck from my Jeep with the #2 wires I carry.  But have also spent a while waiting for a charge to happen on cheap-junk light cables.
A starting draw of 1500 amps for 12 seconds is the same as charging at 30 amps for 600 seconds (10 minutes).  😉
16 minutes ago, Carlos said:
Only if you ignore wire gauges, clamp resistance and surface area, battery internal resistance, and a bunch of other factors.  They are "the same" in theory, not in practice.
That's why I mentioned in post 14 of the current🤣  27, that jumper guage and clamps are important.   (How's that for slipping in a pun?)
KW T-680, POPEMOBILE
Newmar X-Aire, VATICAN
