Crystal B Posted June 19, 2019 Report Share Posted June 19, 2019 Our 2017 Thor Hurricane break light is very loose. How can u tighten it up. Can’t seem to get if off or tighten it up. Quote Link to comment Share on other sites More sharing options...
TXiceman Posted June 19, 2019 Report Share Posted June 19, 2019 Sounds like you mean your brake light has been broken. Some of the lens just pops off. Look for an indentation that you can use with a flat blade screw driver to pop it loose without breaking it. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Crystal B Posted June 19, 2019 Author Report Share Posted June 19, 2019 It looks like the sled tapping screw is stripped in the fiber glass. The like are recessed In The body. So not sure how to pop them off without messing up the body. Any other ideas to try? Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 19, 2019 Report Share Posted June 19, 2019 Light pull while turning the screw counterclockwise. Start gently, both with the pull, and the screwdriver. Gradually increase the pulling effort, until the threads of the screw catch. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Crystal B Posted June 19, 2019 Author Report Share Posted June 19, 2019 Thank u so much! We will def try this!! Quote Link to comment Share on other sites More sharing options...
Kirk W Posted June 19, 2019 Report Share Posted June 19, 2019 9 hours ago, Darryl&Rita said: Gradually increase the pulling effort, until the threads of the screw catch. That is usually an effective approach. Be very careful what you use to pry between the light assembly and the RV body. I suggest the use of a wooden wedge for that purpose. Once you get them out you can repair the screw holes with some sort of filler and make new holes for the screws. Sometimes larger secrews will work for a time but the holes will probably enlarge again just as they did this time. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
$ Spot Posted June 19, 2019 Report Share Posted June 19, 2019 A marine (boat) or RV store should have a product to help with a small fiberglass repair job like yours. The filler adheres to the surrounding area because it's compatible with the material which then enables a new hole to be drilled. I've done it plenty of times when adding cleats or lights to fiberglass boats. The RV skin is probably thinner is all. Spot Quote Link to comment Share on other sites More sharing options...
jblscooper Posted June 19, 2019 Report Share Posted June 19, 2019 The product is Marine-Tek, a two part adhesive for fiberglass. JC Quote Link to comment Share on other sites More sharing options...
