Why spacers behind front rims?
Exile
There are two thin shims behind my front rims.
this truck used to have steel 24.5s and now has aluminum 22.5s.
i checked the best i could from the back side, and there doesn’t appear to be any interferences.
the track width doesn’t match the inside dual like a drw pickup, and is narrower than the outside dual, so no reason i could see to use these to set the track width
have not yet pulled the rim, don’t have a jack strong enough yet.
any ideas about these?
98 379 with 12.7 DD
LG Dodge w/5.9 CTD
Chrome habit I’m trying to kick.
Were the shims used with the steel wheels, could have been to keep the lug nuts from hitting a shoulder /run out of thread?   The other thing, are the isolation discs?      Some trucks with aluminum wheels have a separator gasket to minimize corrosion of the aluminum wheel on steel.
Steve
A floor jack like a 3 ton will get one wheel off the ground.  A bottle jack is cheap and will also work.
The lug nuts are very tight.
2006 Volvo VNL 780, " Arvey"  Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift
2003 Jeep Wrangler Rubicon
2010 Forest River Coachman Freedom Express 280RLS
Jackalopee
Are you sure there is a spacer?  What I see in the picture should be the brake drum.  I also noticed it looks like the studs are a little short.  I like to see at less a couple of threads showing.
"It is better to have more truck than you need than to need more truck than you have"
2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift
2014 Fuzion 40' Toyhauler
2015 Smart Car
Looks like the black part is the spacer. You can see it more in the bottom of the hub to wheel section.
My apologies for the poor picture .
good questions and points.
An isolation disc would be a good idea, but i think the object in contact with the rim is steel.  It could have been a spacer to keep the nuts from running out of thread with a steel wheel, and just left on when Al rims were installed.  I will check the build sheet for the front axle section to see what it says.
it could be the brake drum, but it looks like there are two thin layers.  I would expect a brake drum to be a single homogeneous layer with maybe a chamfer.
yes, i would also like to see more threads showing, most industrial standards i am familiar with require more than one thread showing.  Will need to fix that if i want to put centramatics on
i have a three ton floor jack, but did not attempt to lift one wheel, i agree a bottle jack is the best solution, just have been too cheap to pay full price since the size i wanted was on sale and sold out of the local tractor store.
i finally have an impact that will loosen the lugnuts, so  i will eventually get it off, i thought there might be some special reason for spacers, ( or it is probably the drum)
Thank you for the ideas
98 379 with 12.7 DD
LG Dodge w/5.9 CTD
My bets or still it being the drum.  I went down to Harbor freight and bought a 12 ton jack I think it was around $30 and leave it in the truck.  One suggestion if you do buy from HF, when you get finished using the jack compress the cylinder all the way back into the jack or the cylinder will rust.  As they say "ask me how I know"
2015 Smart Car
That's not rust, just new metal forming. I have the air jack. And always keep it wiped down with Fluid film. I sure don't need any new metal forming on mine.
