solo318 Posted May 30, 2019 Report Share Posted May 30, 2019 So I upgraded the front wheels and tires on my truck conversion to get more axle weight. The problem that i have now is that the tpms systems only seem to go up to 115 psi. Are any of you folks running a system that reads higher? Thanks as always. Quote Click For Full-Size Image. Link to comment Share on other sites More sharing options...
jeffw Posted May 30, 2019 Report Share Posted May 30, 2019 The TST 507 goes beyond 150. My trailer tires start at 125 and end up beyond 150. Quote 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
solo318 Posted May 31, 2019 Author Report Share Posted May 31, 2019 14 hours ago, jeffw said: The TST 507 goes beyond 150. My trailer tires start at 125 and end up beyond 150. Do you use the flow through or the cap sensors? Quote Click For Full-Size Image. Link to comment Share on other sites More sharing options...
ewacowboy Posted May 31, 2019 Report Share Posted May 31, 2019 I have the EEZ RV TPMS and run my 5th wheel pressures at 125psi cold. Not a problem at all. Quote Jim and Kellie 2017 DRV 38RSSA Mobile Suite 2016 Western Star 5700xe YouTube Channel Link to comment Share on other sites More sharing options...
FL-JOE Posted May 31, 2019 Report Share Posted May 31, 2019 I have the TST system and use 12 sensors, 6 are older flow thru and 6 are newer button. I have my steer axle tires set at 115psi cold and see 125 and above reading all the time. I'm not sure there would be a max reading with either type sensor on the TST brand system. Quote Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
HERO Maker Posted May 31, 2019 Report Share Posted May 31, 2019 Both Pressure Pro and TST claim 215 and 218 pressure readings per their website. Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
solo318 Posted May 31, 2019 Author Report Share Posted May 31, 2019 Thanks guys. Quote Click For Full-Size Image. Link to comment Share on other sites More sharing options...
Imurphy907 Posted May 31, 2019 Report Share Posted May 31, 2019 how heavy is your front end and what tires are you running that you need that much air? Quote 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
solo318 Posted May 31, 2019 Author Report Share Posted May 31, 2019 I just put new toyos on it. good for 7100 ish lbs each. I wanted the highest load rating I could get since truck conversions run nose heavy. Most of the time I'm good, But I wanted some extra capacity. Quote Click For Full-Size Image. Link to comment Share on other sites More sharing options...
