Pete Kildow Posted May 27, 2019 Report Share Posted May 27, 2019 Was thinking about buying Window Vents for my KW. But did not care for most made for it. Thought I will just make my own. Had a some scrap Lexan in the shop. so dug it out and 45 minutes later. Had these made up, and ready to mount. Used cheap double side tape for now. As these are just to try out. There's scratches and stuff on these. Will get clean Lexan 1/4" to make them up. If I like these, and thinking I will like them a lot. Allows me to let fresh air in, while the truck is sitting. Quote Link to comment Share on other sites More sharing options...
Scrap Posted May 27, 2019 Report Share Posted May 27, 2019 Nice! Ah, it's an old KW......It allows you to close your doors all the way the first time! Quote Link to comment Share on other sites More sharing options...
Pete Kildow Posted May 27, 2019 Author Report Share Posted May 27, 2019 45 minutes ago, Scrap said: Nice! Ah, it's an old KW......It allows you to close your doors all the way the first time! Yes that is also a nice item also. Without the window cracked, the door is not shutting for sure. Unreal how tight a a 25 year old truck can be. Quote Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted May 30, 2019 Report Share Posted May 30, 2019 Nice job. Looks good. Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Pete Kildow Posted June 3, 2019 Author Report Share Posted June 3, 2019 Thanks sure allows the heat out of the cab. While sitting out, and if it ever rains again. Should keep that out also. Quote Link to comment Share on other sites More sharing options...
