Chefitutide Posted May 22, 2019 Report Share Posted May 22, 2019 I have a 2012 ford explorer xlt without the OEM tow package. I have an Apex Hybrid trailer with 7 pin connection. My RV dealer installed a Tekonsha 118540 from the ford harness and from that adapted a 7 pin. All the pins work except for the 12v running lights. I was told I might need a special adapter from the tail lights or battery to get this to work. Some helpfull people have suggested the Curt C56093. But that only gives me the 4 pin. I need the 7 pin. Is anyone familiar with how this is done? Quote Link to comment Share on other sites More sharing options...
Kirk W Posted May 22, 2019 Report Share Posted May 22, 2019 (edited) Welcome to the Escapee forums! Are you saying that the 7 pin plug on your trailer fits the 7 pin socket on your truck and all except the running lights are working? Have you tested to be sure that everything else is working? Since there are no unused pins in that style of plug it sounds like something other than an adapter. Here is how it should be wired. If you do not have an electrical meter you can check for all of the proper power with a simple 12V test probe from any auto parts store or from Walmart. Edited May 22, 2019 by Kirk W Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Chefitutide Posted May 22, 2019 Author Report Share Posted May 22, 2019 Quote Are you saying that the 7 pin plug on your trailer fits the 7 pin socket on your truck and all except the running lights are working? Have you tested to be sure that everything else is working? Since there are no unused pins in that style of plug it sounds like something other than an adapter. Here is how it should be wired Correct. Everything except for the running lights(pin 3 in your diag) work. Backup, 12volt charge, blinkers, brakes and stop lights all work. According to my RV dealer, they would most likely have to adapt something off the tail lights of my car, but suggest against it, since the wires and I quote "are too thin to carry the voltage needed for your trailer". He said he could try, but advised looking into running a line directly from the battery. Ford advised against running to the battery because it will screw up the "Battery Maintenance controller(BMC)" So im stuck at this point. The people over at ETrailer suggested I could get a power module/converter off the tail light harness, but I can't seem to find one that will convert to 7 pin. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted May 22, 2019 Report Share Posted May 22, 2019 1 hour ago, Chefitutide said: Everything except for the running lights(pin 3 in your diag) work. Backup, 12volt charge, blinkers, brakes and stop lights all work. I have 2 vehicles today that came with the 7 pin plug installed as part of the towing package. They are a 2003 Dodge truck and a 2009 Kia Borrego and both of them have power to the running lights in that plug. I am very sure that your Ford has it there also, or did when it was built. Have you verified that the problem is in the Explorer and not the RV? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Sehc Posted May 23, 2019 Report Share Posted May 23, 2019 The wires would be "too thin" for the amperes if used for the general trailer 12 volt charging. But if only for the tail lights and markers, there should be no problem. You could even use LED for less amperes. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted May 23, 2019 Report Share Posted May 23, 2019 (edited) 2 hours ago, Sehc said: The wires would be "too thin" for the amperes if used for the general trailer 12 volt charging. The pin that he is asking about only supplies the vehicle running lights and turns on and off with the tow vehicle headlights/parking lights. Pin #4 is the one that supplies 12V to the trailer batteries. Edited May 23, 2019 by Kirk W Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Sehc Posted May 23, 2019 Report Share Posted May 23, 2019 Just reacting to what I read on the post. or What the dealer told him about "too small for the voltage". Quote Link to comment Share on other sites More sharing options...
Sehc Posted May 24, 2019 Report Share Posted May 24, 2019 I went back and see that the dealer installed a 4 pin connector. The OP needs this 7 pin set-up. https://www.amazon.com/dp/B00YJEWI4E/ref=psdc_15737351_t1_B0071XQ56W Quote Link to comment Share on other sites More sharing options...
