SnowGypsy Posted May 19, 2019 Report Share Posted May 19, 2019 I saw a sales video on Rescue Tape (self-fusing silicon) that looked good. I was also looking at the Gorilla Waterproof and Seal Tape. We haven't been impressed by the other Gorilla products that we bought yet reviews for that were better than for the Rescue Tape. Has anyone used either of these? If not, do you keep something else on hand in this category? We are looking for just something multi-purpose to carry in the vehicle. When it comes to patches, we have excellent results with Tear-Aid which comes in different types depending on what needs repair. Quote Cathy Link to comment Share on other sites More sharing options...
Pieere Posted May 19, 2019 Report Share Posted May 19, 2019 I have used Eterna-Bond on roof seams. It really holds well. Is thicker than most tapes so it depends what you need it for! Quote Living Life One Day At A Time! Link to comment Share on other sites More sharing options...
Daveh Posted May 19, 2019 Report Share Posted May 19, 2019 Eternabond has such an established reputation for effectiveness, this is an area where it makes no sense to look at alternatives. Quote Dave and Lana Hasper Link to comment Share on other sites More sharing options...
whj469 Posted May 19, 2019 Report Share Posted May 19, 2019 As noted above why not use eternabond? Quote Link to comment Share on other sites More sharing options...
Lou Schneider Posted May 19, 2019 Report Share Posted May 19, 2019 (edited) Rescue Tape and Gorilla Tape are good where you may want to remove it for a more permanent or better looking repair in the future. Eternabond tape is just that. You'd better be happy with your first try because once it's down, it ain't coming off! Edited May 19, 2019 by Lou Schneider Quote Link to comment Share on other sites More sharing options...
SnowGypsy Posted May 19, 2019 Author Report Share Posted May 19, 2019 OK, thanks, I'll check out Eternabond. It might be best to have 2 or 3 different choices on hand. Quote Cathy Link to comment Share on other sites More sharing options...
KodiakJack Posted May 19, 2019 Report Share Posted May 19, 2019 I used the silicon rescue tape to fix a cracked APS pipe fitting. It was way easier to fix that way than cutting out and replacing the fitting due to it's location under the underbelly. That was 6 year ago. Great stuff. Later, J Quote 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
SnowGypsy Posted May 20, 2019 Author Report Share Posted May 20, 2019 Sounds good! I saw them roll it into temporary gaskets in a video, and for pipes/hoses. Thanks! Quote Cathy Link to comment Share on other sites More sharing options...
Ray,IN Posted May 21, 2019 Report Share Posted May 21, 2019 I have used Rescue Tape to temporarily patch a radiator hose, yes-like their pictures. That temporary radiator hose patch on my farm tractor worked so well, it's still there after 3 years. Etenabond could reliably withstand the heat, pressure, and associated grease and oil typical on a farm tractor. When used as intended, Rescue Tape is unequaled IMO. Rescue Tape cannot be used on a flat surface(patch an awning) like adhesive tape, as it only adheres to itself. I agree, Gorilla Tape is over-rated, used it once, gave the rest of the roll away. If you want a tape that will securely hold something together without breaking, check out Nylon or Fiberglass re-enforced packing tape. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 5, 2019 Report Share Posted June 5, 2019 Just used rescue tape on pump fitting that was leaking at my sticks and bricks. Works well. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted June 5, 2019 Report Share Posted June 5, 2019 15 hours ago, SuiteSuccess said: Just used rescue tape on pump fitting that was leaking at my sticks and bricks. Works well. I guess the stiches you put in ripped out? Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Carlos Posted June 5, 2019 Report Share Posted June 5, 2019 There are multi-purposes products, but there are no ALL-purpose products. Silicone self-fusing tape has a few uses, "duct" tape types like Gorilla have another, and I also like Fiber-Fix for some things. The latter is a hard, water-cure strip that ends up like fiberglass. Very stiff and strong, but not useful on a flexible surface or anything flat. But you can put a shovel handle back together with it. I also fixed some outdoor chair leg welds with it, holding for three years now. Quote Link to comment Share on other sites More sharing options...
kb0zke Posted June 10, 2019 Report Share Posted June 10, 2019 Several years ago I bought a three-pack of Rescue Tape (red, clear, black) and have used maybe 1/3 of each. When used as designed it works well. Quote David Lininger, kb0zke 1993 Foretravel U300 40' (sold) 2022 Grand Design Reflection 315RLTS Link to comment Share on other sites More sharing options...
jeff_g Posted September 18, 2019 Report Share Posted September 18, 2019 On 6/11/2019 at 12:07 AM, kb0zke said: Several years ago I bought a three-pack of Rescue Tape (red, clear, black) and have used maybe 1/3 of each. When used as designed it works well. Twice that. I keep it in the bike and the RV, and certainly I would buy more (even though it did not perform too well on my house plumbing). Had a leakage in our home in march, used 2 rolls and wrapped it twice, pipe still leaked. Effectively fixed a garden hose though. Quote Not all those who wander are lost - J. R. R. Tolkien Link to comment Share on other sites More sharing options...
TLRam1 Posted September 18, 2019 Report Share Posted September 18, 2019 If Rescue Tape does not stick to the hose I can't see how the tape would prevent water from leaking out. Quote Terry Link to comment Share on other sites More sharing options...
Danandfreda Posted September 18, 2019 Report Share Posted September 18, 2019 I used gorilla tape on a slide out because I could not get eternabond in time and it does not come off if it’s on a clean surface. I tried to peel but I comes off in small pieces that you can get your finger tips on. I now have eternabond but gorilla tape works real good Quote Link to comment Share on other sites More sharing options...
