Sculptor Posted May 2, 2019 Report Share Posted May 2, 2019 (edited) SuiteSuccess started a related topic. I sometimes think it's a good idea to piggyback topics for the sake of the next person searching. Link to the topic included below. shorter version; So I got the STOP LOW COOLANT message on the instrument cluster. I usually park on gravel so I never noticed a puddle or anything. Went from a spot on the road while parked, days later became critically low. My fault for not popping the hood after cooling off to look. i assumed a hose had cracked because it seemed to lose water very suddenly. I looked over the gravel, the hoses, the expansion tank and connections. I crawled underneath, felt around where I could not see, even looked at our rear sleeper heater repair. For anyone who wants to know more about the chronic sleeper heater leak for Volvo sleepers, we have many photos and cad screen shots of our disassembly and reassembly fun. No write up yet but someday. The level sensor in the reservoir tank looked borderline, and there was residue on the fan shroud resembling a leak. No greasy moisture on the sensor electrical plug. It appears the sensor was leaking in the past so I tightened the clamp and moved on. At the Volvo dealer I bought a few parts, thermostat, short hose, $60 each. Coolant filter $15 or so, EXPANSION TANK PRESSURE CAP $35 or so, a couple or other things I forget exactly what. 6 gallons of COOLANT just less than $7 per gallon. The caps are because you might want the info that follows. Everywhere I looked including online, Diesel engine coolant was $12 on up. Like batteries, the dealer had the best price. You just never know. The service desk was next. I described the leak events etc, and immediately the mechanic who happened to overhear said, "Replace the over pressure cap on the pressure tank." AKA reservoir. He added that when running on the highway, the system may regenerate. The cap relieves pressure at 15 pounds but if it goes bad, will shoot the coolant out the overflow drain hose. So you will never see it! i gave it some time to be sure, and the tank level is right where I left it a month ago. i came up with what I think is a unique way to refill the cooling system, and I'm not inviting the flame throwers to comment, but I will take constructive advice. 😃 I will have to tell that story later on edit. http://www.rvnetwork.com/topic/134846-volvo-radiator-drain-hose/?do=findComment&comment=981047 Edited May 2, 2019 by Sculptor Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Sculptor Posted May 3, 2019 Author Report Share Posted May 3, 2019 So I bought the "I can't believe it's $60" radiator drain hose that SuiteSuccess originally posted about. I drained the system and was able to fill 2 buckets @ 4 gallons each. I spent some time looking for the coolant capacity of my truck. I am not sure but I believe it's 15 gallons. Rather than perching on a ladder and pulling the buckets up with a rope, to reuse the coolant, I bought a cheap submersible pump on sale for $40. I wrapped a vacuum cleaner filter around it, and connected the radiator drain hose to the outflow. Of course I left the tank cap off. Backing up a bit, I saw some posts about the very cool and expensive vacuum tester and filling tool online for $130ish. There were others like it that were cheaper also. I was not thrilled with the cost and plan to never need it again. (Yeah right) the pump options were expensive also, except maybe the drill powered pump. The submersible seemed relatively cheap. The 8 gallons went into the system very quickly, and filled from the bottom up, to minimize the chance of trapping air. I then poured the missing 4 gallons in from the top. I don't know for sure how much or how little air was trapped in the system when filling from the bottom. I let the truck idle a good long while to open the thermostat, fill the coolant filter, and circulate any air to the top. There seemed no difference in the level afterward. I hope this is helpful to anyone else, and to me also from more knowledgable folks who might know why this was a poorly done procedure. Respectfully, Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Sculptor Posted June 15, 2019 Author Report Share Posted June 15, 2019 Well I was wrong. I thought it was fixed after hours of leak free driving on a hot day. It’s not. HELP PLEASE 🙂 What I thought were fuel lines across the steel frame directly between tanks, appear to be leaking coolant. Can someone please clue me about this system? Does this keep the fuel at a constant temperature? If there is a kit or part numbers please post! I don’t know what to search for. Plus we are wrenching on a new leveling valve this morning so I will have to get searching later. Thanks in advance. About my goofy sump pump solution above, are you guys just being polite? 🤣 No comments yet? Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 15, 2019 Report Share Posted June 15, 2019 Hopefully someone will reply and help. I’m clueless. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 15, 2019 Report Share Posted June 15, 2019 I can't help much from here. It's on you to determine if lines are fuel or coolant. I will say that fuel tanks are seldom heated, as fuel is often used as a coolant sink for electronics. Sleepers have coolant lines, often rusty steel with rubber where flex is needed. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Scrap Posted June 15, 2019 Report Share Posted June 15, 2019 Are they DEF coolant lines? Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 15, 2019 Report Share Posted June 15, 2019 Maybe some pics might help. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted June 16, 2019 Report Share Posted June 16, 2019 If you have a Davco filter, make sure it is not coolant heated, it sounds like yours might be. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Sculptor Posted June 16, 2019 Author Report Share Posted June 16, 2019 (edited) Hi folks, It took this long to get my latest info out to you. What I found out from the parts guy, after an in depth talk: This truck has a heater system they never see in North Carolina. This truck is from ND. Heads up Larry! (AV8R) The coolant must circulate into the tanks via a heat exchanger gadget. I'm not sure if its factory original or not. There are two crossover lines that run on a piece of angle/channel between the tanks. The steel frame and tubes are prone to corrosion. Part number 8085004. There might be an assembly number but he didn't say. I have not searched online yet the weather is too nice and I have an ET hitch to install today. To be continued. BEFORE (metal tubes $$$ from dealer) AFTER (rubber heater hose covered with cheap cord organizer tube) Edited August 18, 2019 by Sculptor add pics Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
alan0043 Posted June 16, 2019 Report Share Posted June 16, 2019 10 hours ago, GeorgiaHybrid said: If you have a Davco filter, make sure it is not coolant heated, it sounds like yours might be. Hi Dave, P/M sent. Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted June 16, 2019 Report Share Posted June 16, 2019 Not sure if you found the leak or not but on my 630 there is a drain valve on the side of the block tucked up kinda behind the turbo (at least on my 12 liter Volvo engine). I had an unexplainable leak and it turned out to be that valve AND it only leaked at about 1400 RPM. It has a threaded outlet and the tech reached WAAAY up from the bottom and screwed a pipe plug into the valve and it has not leaked since. Just another place to loook. Brad Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
rickeieio Posted June 16, 2019 Report Share Posted June 16, 2019 Kevin, I'm guessing the line you colored green is the culprit? If so, the line may only be bad in the area where it's along the brace/support angle. In that case, you might consider cutting out the rusted section and replace it with high quality hose and good clamps. Don't go to Auto-Zone. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 16, 2019 Report Share Posted June 16, 2019 Decision time. Do you ever plan to be in ND weather conditions? I'm not talking a little snow going through a mountain pass, but bone-chilling deep cold. The factory lines lasted from '13 to now. Do you want to be underneath again in a comparable time frame re-replacing the lines? Follow them forward, and delete the lines at the junction block looking thing. Leave the lines in place, for the next guy to figure out, or remove them and add blanking covers where the heat probes go into the tanks. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Sculptor Posted June 16, 2019 Author Report Share Posted June 16, 2019 1 hour ago, rickeieio said: Kevin, I'm guessing the line you colored green is the culprit? If so, the line may only be bad in the area where it's along the brace/support angle. In that case, you might consider cutting out the rusted section and replace it with high quality hose and good clamps. Don't go to Auto-Zone. Yes there is 1 pressure and 1 return so 2 of number 27. Exactly what I did except the guy sold me 4 reducers not 4 1-to-1. Grrr now I have to waste time taking them back to get the right ones. NAPA btw. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Sculptor Posted June 16, 2019 Author Report Share Posted June 16, 2019 1 hour ago, Darryl&Rita said: Decision time. Do you ever plan to be in ND weather conditions? I'm not talking a little snow going through a mountain pass, but bone-chilling deep cold. The factory lines lasted from '13 to now. Do you want to be underneath again in a comparable time frame re-replacing the lines? Follow them forward, and delete the lines at the junction block looking thing. Leave the lines in place, for the next guy to figure out, or remove them and add blanking covers where the heat probes go into the tanks. Great idea Darryl, had not thought of just cutting them out altogether. We travel north occasionally but try to limit our winter visits to Amazon delivery only, most years. 🙂 Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Sculptor Posted June 16, 2019 Author Report Share Posted June 16, 2019 2 hours ago, Brad & Jacolyn said: Not sure if you found the leak or not but on my 630 there is a drain valve on the side of the block tucked up kinda behind the turbo (at least on my 12 liter Volvo engine). I had an unexplainable leak and it turned out to be that valve AND it only leaked at about 1400 RPM. It has a threaded outlet and the tech reached WAAAY up from the bottom and screwed a pipe plug into the valve and it has not leaked since. Just another place to loook. Brad Thanks Brad. I took Darryl’s advice and put cardboard under the engine area. It stayed clean. But there is a large suspiciously dead looking patch of grass under the right tank but inside more under the frame. When I saw the frame was wet and identified coolant not fuel, I thought it was under the sleeper heater repair from 2 years ago. All this time I thought those tubes were some sort of fuel crossover. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Sculptor Posted August 18, 2019 Author Report Share Posted August 18, 2019 On 6/16/2019 at 10:35 AM, rickeieio said: Kevin, I'm guessing the line you colored green is the culprit? If so, the line may only be bad in the area where it's along the brace/support angle. In that case, you might consider cutting out the rusted section and replace it with high quality hose and good clamps. Don't go to Auto-Zone. Thanks Rick, pretty much exactly what I did. NAPA Auto Parts though. Took awhile to get around to the pics but added them above with the diagram. I considered cutting and blocking them per Darryl's good advice but this seemed easier. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Jimmy Love Posted February 14, 2020 Report Share Posted February 14, 2020 On 6/16/2019 at 7:44 AM, Sculptor said: Hi folks, It took this long to get my latest info out to you. What I found out from the parts guy, after an in depth talk: This truck has a heater system they never see in North Carolina. This truck is from ND. Heads up Larry! (AV8R) The coolant must circulate into the tanks via a heat exchanger gadget. I'm not sure if its factory original or not. There are two crossover lines that run on a piece of angle/channel between the tanks. The steel frame and tubes are prone to corrosion. Part number 8085004. There might be an assembly number but he didn't say. I have not searched online yet the weather is too nice and I have an ET hitch to install today. To be continued. BEFORE (metal tubes $$$ from dealer) AFTER (rubber heater hose covered with cheap cord organizer tube) Did you have to drain the entire coolant out of the truck to change this part? Quote Link to comment Share on other sites More sharing options...
rickeieio Posted February 15, 2020 Report Share Posted February 15, 2020 You could change the lines with very little coolant loss by clamping off the rubber line on each side of the work area. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Sculptor Posted February 15, 2020 Author Report Share Posted February 15, 2020 3 hours ago, Jimmy Love said: Did you have to drain the entire coolant out of the truck to change this part? Nope, I drained just enough to soak my hair and sleeves. Then I decided to save the rest in the truck system and clamped the hoses on each side. 😉 Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Sculptor Posted February 15, 2020 Author Report Share Posted February 15, 2020 51 minutes ago, rickeieio said: You could change the lines with very little coolant loss by clamping off the rubber line on each side of the work area. Right you are Rick. It was last summer but I’m pretty sure that’s what I did. I got tired of lounging around under a stream of coolant, it was disturbing my calm appearance. So I clamped the rubber parts above the crappy metal with whatever I could find. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
