MikeShatt Posted April 22, 2019 Report Share Posted April 22, 2019 Hello all, has any one put a bumper pull hitch on their truck with out or before putting a bed on the truck? what did you get, and where did you get it. looking to put one on asap. Also did you have to relocate your license plate, or will you have to adjust something when you go to put a bed on it? Thank you all for the advice. Quote Link to comment Share on other sites More sharing options...
Randyretired Posted April 22, 2019 Report Share Posted April 22, 2019 I extended the frame, changed the lights and built a bumper pull hitch. I am not aware of any hitches that can be purchased for an HDT but custom building one is fairly simple. Having a shop build one would probably be the easiest. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Sculptor Posted April 23, 2019 Report Share Posted April 23, 2019 We have a receiver on our Volvo, no flatbed yet. It was custom fabricated for the truck. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Exile Posted April 23, 2019 Report Share Posted April 23, 2019 The only ones i’ve seen sold for a bigger trailer are weld on hitches. The frame configurations and obstructions require a custom fit. ordering one will get you close, then just need some square tubing or angle to weld the hitch to, and bolt the whole thing on. if you want a hitch NOW, buy a bolt on adaptable hitch that bolts to the top of the frame. They are usually class iii i believe, so probably not good for a big trailer. Usually used to flat tow a car. Etrailer, search for weld on hitch. https://www.etrailer.com/s.aspx?qry=Weld-On+Hitch&furl=-pg-Heavy_Duty_Truck_Hitch Quote 98 379 with 12.7 DD LG Dodge w/5.9 CTD Chrome habit I’m trying to kick. Link to comment Share on other sites More sharing options...
MikeShatt Posted April 23, 2019 Author Report Share Posted April 23, 2019 Thanks you it is to tow an enclosed 20 footer with a couple of ATV’s. Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted April 23, 2019 Report Share Posted April 23, 2019 Google is your friend..... Quote Link to comment Share on other sites More sharing options...
Chuck Posted April 23, 2019 Report Share Posted April 23, 2019 I had one custom done for $800.00 and some change. Lights and 7 pin were already set up. Also, consider a Gen Y hitch, or some equivalent, for a tow behind due to the relatively light pin weights. Quote Link to comment Share on other sites More sharing options...
jkoenig24 Posted April 23, 2019 Report Share Posted April 23, 2019 Are you going to be at the ECR? If so, check out Steve Dixon's rig. He a "bumper pull". Quote Link to comment Share on other sites More sharing options...
NeverEasy Posted April 23, 2019 Report Share Posted April 23, 2019 I used a hitch off a '84 Chevy 3/4 ton truck that I junked. It is a heavy duty hitch rated at 1600 lbs tongue weight/15,000 lbs towing. The side plates were bolted to the cross bar. Those came off and were given to RandyA. I cut some 1/2 inch plate to replace it with enough drop to make the hitch a reasonable height. As I remember, it had to be made narrower so it all got welded instead of reusing the bolt-on setup. The receiver sits on a 2 x 4 thick walled rectangular tube cross-member for additional support. Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
dan412 Posted April 23, 2019 Report Share Posted April 23, 2019 I bought mine from etrailer Reese titan 20,000 lbs weld on i think it was 800.00 fit the frame perfectly, But had to trim for a couple of bolts for clearance. Quote 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
Parrformance Posted April 23, 2019 Report Share Posted April 23, 2019 I placed the tag on the front of the truck, where the bumper has holes for the state issued tag. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
rickeieio Posted April 23, 2019 Report Share Posted April 23, 2019 As to tag placement, keep in mind how you're registered. In Indiana for instance, a tractor or dump truck has the tag on the front, but a motorhome has it on the rear. Ohio has two tags, front and rear, but on a tractor the tag with the stickers goes on the front. Get it right, so when that day comes where you're explaining to the gentleman in uniform why you're legal, you really are legal. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Steve from SoCal Posted April 23, 2019 Report Share Posted April 23, 2019 I concur with Rick, My tag is on the back, where a tractor would have the plate on the front. As for hitch, mine is a little overkill for your use but the idea is the same. I bolted vertical plates to the back of the frame with diagonal braces. I wanted it removable, the hitch plate bolts to the side frame. Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
MikeShatt Posted April 23, 2019 Author Report Share Posted April 23, 2019 Thank you all for the advice. I am talking with a fabricator at this time. Steve, great pics. Quote Link to comment Share on other sites More sharing options...
MikeShatt Posted April 23, 2019 Author Report Share Posted April 23, 2019 Sorry about the profile pic, will upload better one soon. Quote Link to comment Share on other sites More sharing options...
Black Posted April 24, 2019 Report Share Posted April 24, 2019 Hello, I went with the Draw-Tite 4907 7" bracket kit and the Draw-Tite 41991 hitch. This is a Class V universal fit hitch that's specifically made for heavy-duty and commercial vehicles with frames up to 62". The ratings are 16k lbs gross trailer weight and 1,600 lbs max tongue weight although it can be reinforced to handle more. It's cheaper to buy the components separately then as a kit and all together I spent ~$130 for the hitch and about $15 in bolts. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted April 25, 2019 Report Share Posted April 25, 2019 I am in the design process. since the picture was taken I have changed my mind a little bit. I am going to extend the frame so the brackets will go straight down. That will be channel iron. The bumper its self is 8x8 tube 3/8 thick. I got a receiver tube that will be welded to the bottom of the bumper. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Black Posted April 25, 2019 Report Share Posted April 25, 2019 25 minutes ago, jenandjon said: I got a receiver tube that will be welded to the bottom of the bumper. Any thoughts of cutting a square hole in the tube and welding the receiver tube into it? Aside from the added support, it seems like it'd be a "cleaner" look. Quote Link to comment Share on other sites More sharing options...
NeverEasy Posted April 25, 2019 Report Share Posted April 25, 2019 It would have to stick out far enough to put the pin in. That would be a PITS (shin). Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
Black Posted April 25, 2019 Report Share Posted April 25, 2019 Good call, I forgot about the pin. Other than a vertical pin, it sounds like below the bumper it is... Quote Link to comment Share on other sites More sharing options...
Parrformance Posted April 25, 2019 Report Share Posted April 25, 2019 23 minutes ago, NeverEasy said: It would have to stick out far enough to put the pin in. That would be a PITS (shin). A new hole could be drilled closer to the end flange, keeping it tucked neatly. Hindsight is 20/20, I would put the hitch higher, and used a drop hitch If I had it to do over again. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
jenandjon Posted April 26, 2019 Report Share Posted April 26, 2019 23 hours ago, Black said: Any thoughts of cutting a square hole in the tube and welding the receiver tube into it? Aside from the added support, it seems like it'd be a "cleaner" look. Yea I though of that. I was going to put the lights into the bumper also. But, I decided to us the bumper for extra storage. I made end caps that clip on. I will weld the tube to the bottom then weld some 1/4 inch angle on either side for extra support. I was originally going to go with 4x4 tube or 6x6 but I got a whole pile of this 8x8 cheap enough at an auction. Most likely put some padding in there and store my big rod and reel in it. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
tyates007 Posted April 28, 2019 Report Share Posted April 28, 2019 (edited) I have done 2 different trucks of mine using this type that we built. It is simple, strong and looks nice. My bumper ties in with the hitch. This just bolts to frame Click For Full-Size Image. Click For Full-Size Image. Edited April 28, 2019 by tyates007 Quote Link to comment Share on other sites More sharing options...
beemergary Posted April 29, 2019 Report Share Posted April 29, 2019 Built my own and everything is bolted on jusy like the flat bed. Quote Link to comment Share on other sites More sharing options...
beemergary Posted April 29, 2019 Report Share Posted April 29, 2019 finished project. Quote Link to comment Share on other sites More sharing options...
