Matt Posted April 19, 2019 Report Share Posted April 19, 2019 5th time trying to post so apologies for brevity. New fifth wheel, water draining slowly in tub and gets backed up when trying to shower. There is a hard plastic inline piece in the plumbing with what appears to be a very small hole. Anyone know how water is supposed to go through this small hole in drain? Also curious what large round cap is on top. Thanks in advance! I would attach pic but can't get past size restriction. Link to comment Share on other sites More sharing options...
Pat & Pete Posted April 19, 2019 Report Share Posted April 19, 2019 41 minutes ago, Matt said: I would attach pic but can't get past size restriction. Maybe turn your camera down ? Sorry , I can't speak to your drain problem . Goes around , comes around . Link to comment Share on other sites More sharing options...
Kirk W Posted April 19, 2019 Report Share Posted April 19, 2019 It may be that the round cap is a plug to stop the draining and allow you to fill the tub. The motorhome that we used to have had a tub and it also had a cap of sorts that you pushed down to plug the drain and pushed down again to allow it to snap upward to allow the tub to drain. It also tended to capture things that went into the drain, like hair and such and that did make things drain slowly. If your RV is new, you may want to take it back to your dealer to get this corrected but if not, it probably can be disassembled to clean it. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Lance A Lott Posted April 19, 2019 Report Share Posted April 19, 2019 2 hours ago, Matt said: 5th time trying to post so apologies for brevity. New fifth wheel, water draining slowly in tub and gets backed up when trying to shower. There is a hard plastic inline piece in the plumbing with what appears to be a very small hole. Anyone know how water is supposed to go through this small hole in drain? Also curious what large round cap is on top. Thanks in advance! I would attach pic but can't get past size restriction. http://www.rvnetwork.com/topic/130466-picture-posting/ Try this no size restrictions Link to comment Share on other sites More sharing options...
