remoandiris Posted April 17, 2019 Report Share Posted April 17, 2019 I have a Dish 1000.2 with hybrid WA LNB. My Super Buddy says the signal strength on 110 is 41. When I check the signal strength on the Hopper3, under Dish diagnostics, the signal strength is 11. 110 is where the locals emanate. Could it just be a crappy Cat 6 cable? This is the same cable I've used for over a year with no issues. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted April 17, 2019 Report Share Posted April 17, 2019 How are the ends of the cable? I used to cut the old ends off yearly and added new connectors to get a cleaner contact wire. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
remoandiris Posted April 17, 2019 Author Report Share Posted April 17, 2019 7 hours ago, Mark and Dale Bruss said: How are the ends of the cable? I used to cut the old ends off yearly and added new connectors to get a cleaner contact wire. I'll check the ends. I have an unused HF tool to make connectors. Interestingly, this a.m., the signal strength showing on the Hopper under Diagnostics is 43. I made no changes to anything from last night. SO overnight, it went from 11 to 43 all by itself. KRAZY!! Link to comment Share on other sites More sharing options...
Jim & Wilma Posted April 17, 2019 Report Share Posted April 17, 2019 Intermittent connections can be frustrating. As a connection heats and cools, there's good potential for microscopic movement which can change the connection characteristics, especially if some oxidation has set in. It's likely you've not seen the last of this and I'm with Mark on replacing the F connectors. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
remoandiris Posted April 17, 2019 Author Report Share Posted April 17, 2019 One thing I didn't do, but need to do, is check signal strength at the far end of the coax from the dish, and again inside where it connects to the Hopper. Link to comment Share on other sites More sharing options...
