Zulu Posted April 12, 2019 Report Share Posted April 12, 2019 The last two times I've used my DISH Travler it has taken longer to acquire the sats and my ending Controller screen looks like this: Missing asterisks (*) in front of 110 and 129. The sats still appear on my Hopper 3, and their signal strength is also good, and I receive all my programming ok. I contacted Winegard who answered the next day -- kudos. In effect, they said don't worry about it. That Travler acquisition can take up to 45 minutes. Great. I hope I'm not heading in that direction, nut my Travler is over a decade old. I'm seeing tripod set up in my future. Anyone else seen this behavior? SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted April 12, 2019 Report Share Posted April 12, 2019 The Trav'ler on our Trailer Supreme trailer is 9 years old and still function. Since you are receiving signals, I would suspect the logic board in the turret decoding the signals from the LNBF head is fading. Trouble is that is a trip to Winegard for a fix. But I would consider a rebuild of the Trav'ler. And I do carry a tripod for the EA satellites and when trees in the way Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Zulu Posted April 13, 2019 Author Report Share Posted April 13, 2019 9 hours ago, Mark and Dale Bruss said: Trouble is that is a trip to Winegard for a fix. But I would consider a rebuild of the Trav'ler. And I do carry a tripod for the EA satellites and when trees in the way What does a rebuild entail? Yeah, I have enough DISH parts to open a store. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted April 13, 2019 Report Share Posted April 13, 2019 Winegard would do the rebuild. \you would send the turret into them. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
LindaH Posted April 13, 2019 Report Share Posted April 13, 2019 20 hours ago, Zulu said: That Travler acquisition can take up to 45 minutes. I've been told that, too, by Winegard. But I'm not that patient. When the dish starts having trouble locating the satellite, I'll stow the dish, disconnect it from power, wait for 10 seconds or more, and then start the process over again. That has always worked for me...but so far, I've never had the problem you're showing. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
docj Posted April 13, 2019 Report Share Posted April 13, 2019 From what I have observed with my Trav'ler the satellite acquisition logic is keyed to the satellite on the left, in this case 119. The other two are used to determine the correct skew. My Trav'ler is a DirectTV model but I think the logic is probably the same since mine is about the same age. For DirecTV the 3 satellites are 101, 110 and 119 At one location last summer our Trav'ler was unable to lock onto 119 because of a nearby tree. In that case it went through the entire satellite acquisition sequence at least twice, if not three times, before finally stopping and presenting a screen similar to what the OP posted., that is with one(or more) of the other asterisks missing indicating the absence of a satellite lock on those birds. Although I didn't time it, I know that the acquisition process took at least ~15-20 minutes. My guess is that the increased acquisition time reported by the OP is driven by the inability of the Trav'ler to find one or more of the targeted satellites for whatever the reason. In my case, the problem was a tree, in the OP's case it could well be an electronics issue, but the end result is the same--increased acquisition time because the Trav'ler will repeat its acquisition process several times before "deciding" that it can't find all three satellites. If you're impatient and don't want to wait for it to go through multiple attempts to find the satellites, one thing you can do is do an "emergency power off" (Power + Select buttons) when you observe it peaking before it starts the acquisition process all over again. I've done this in the past when this problem has arisen and it's always left me with a "good enough" satellite lock to be able to watch most channels without issues. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Jim & Wilma Posted April 13, 2019 Report Share Posted April 13, 2019 We’ve had this same screen once when shooting through trees. Signals were sporadic and some channels were SD. I assumed one of more of the LNBs were not getting adequate signal strength. I did have a problem a couple years ago where Travlr was not able to acquire SATs with clear sky. Found one of the coax conductors, of three coax bundle, opened between LNB and base. I know someone else also had a coax failure. If it was me, I’d swap LNBs out and also check the coax cables for good continuity. I’m not hopeful this will yield results but it’s simple enough to do and worth the effort imo. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Bill w/bus Posted April 15, 2019 Report Share Posted April 15, 2019 We had a problem that was the internal cabling within the turret. This cabling is a failure point. LNB 's could be failing or possibly the cabling within the arm to the exterior turret connection points. The voltage is ,14 and 18 volts therefore good and secure connections are critical for proper operation. Good luck with your troubleshooting. Bill Bill & Lynn Baxter MCI102A3 Conversion, Detroit Diesel S50 Link to comment Share on other sites More sharing options...
harley-dave Posted April 15, 2019 Report Share Posted April 15, 2019 Ours also does this. Doesn't seem to make a difference in operation. The acquisition time is the same as always was. Our travelr was installed in 2005. I have replaced the LNB, the reflector and the 3 coax cables on ours over the years, mostly due to sun and wind damage. (bad storm). Dave Link to comment Share on other sites More sharing options...
Zulu Posted April 19, 2019 Author Report Share Posted April 19, 2019 It's back to normal . . . *119 *110 *129. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
