Utah Paul Posted April 9, 2019 Report Share Posted April 9, 2019 My Roadtrek 190 has an old style window latch and I am trying to find a replacement latch. A photo of the latch is shown below. The latch should allow the window to open a few inches and securely latch when closed, but it does not work smoothly. Does anyone know where replacement latches are available? Thank You Paul Window latch.pdf Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 9, 2019 Report Share Posted April 9, 2019 You might find what you seek at one of these places; https://www.rvadenver.com/HARDWARE-s/107.htm?searching=Y&sort=13&cat=107&show=300&page=1 http://www.keylinesaleselkhart.com/specialty.asp https://www.rvdiscountsuppliers.com/?page_id=3 Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Utah Paul Posted April 9, 2019 Author Report Share Posted April 9, 2019 Thanks for helping. None of the items appear to be a direct replacement for the original latch. Paul Quote Link to comment Share on other sites More sharing options...
bobsallyh Posted April 9, 2019 Report Share Posted April 9, 2019 (edited) Utah Paul, I googled van window latches. Came up with numerous latches. What make and year is the chassis? It could possibly be the chassis manufacture OEM latches. Edited April 9, 2019 by bobsallyh Quote Link to comment Share on other sites More sharing options...
Utah Paul Posted April 9, 2019 Author Report Share Posted April 9, 2019 The Roadteck 190 is a 2000 model. Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted April 9, 2019 Report Share Posted April 9, 2019 Have you tried soaking the latch with silicone spray and working the mechanism ? That usually does the trick for me . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
bobsallyh Posted April 10, 2019 Report Share Posted April 10, 2019 Utah Paul, what manufacture? Quote Link to comment Share on other sites More sharing options...
Utah Paul Posted April 10, 2019 Author Report Share Posted April 10, 2019 The Roadtrek is built on a Dodge frame. Quote Link to comment Share on other sites More sharing options...
Twotoes Posted April 10, 2019 Report Share Posted April 10, 2019 I too need window latches. I have a 2015 Itasca Eclipse with a dozen latches of which 4 are broken. Called Winnabego and was quoted $75 each. I’ll be damed if I’m going to pay $300 for 4 window latches. Looked at a couple of RV Surplus places and they only sell the entire window not just the latches. There has got to be a place to get them for @$10 each. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
rpsinc Posted April 10, 2019 Report Share Posted April 10, 2019 Most manufacturers assemble parts that are available from their source manufacturer. Try to find a PN or maker name on the part and use Google to help you. I found some slide seal material this way. Took some research and because it is a Teton, sourcing from manufacturer is not an option. Compared to RV sources, I paid 1/2. Quote Marcel Link to comment Share on other sites More sharing options...
docj Posted April 10, 2019 Report Share Posted April 10, 2019 19 hours ago, Utah Paul said: The Roadteck 190 is a 2000 model. Having had that same model ourselves, are you sure that isn't a Dodge part? I don't recall Roadtrek in those days having made changes to windows that were mounted in doors. Those kinds of flip-out windows are pretty common on vans configured to carry passengers. Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
bobsallyh Posted April 10, 2019 Report Share Posted April 10, 2019 Utah Paul, looking at the latches in your pictures, I notice the right side latch looks like somebody replaced a black "pin" with an 1/8" or 3/16" pop rivet. The left side latch shows two black headed pins. I wonder if the "rivet" is what is binding up? I keep Googling Dodge and Dorman latches. If I come up with something I'll let you know. I'm like docj, don't know Roadtrek that well but it looks like a Dodge OEM part. Quote Link to comment Share on other sites More sharing options...
Utah Paul Posted April 10, 2019 Author Report Share Posted April 10, 2019 Thank You everyone for all of your comments......... still looking! Quote Link to comment Share on other sites More sharing options...
