Big5er Posted April 8, 2019 Report Share Posted April 8, 2019 I saw the post where someone built a storage box on the end of the bed, under the trailer. I think I even commented on the thread but i can't find it now. I want more pictures! Who posted it?? My truck is heading back to Herrin soon to get my generator box built and the genset mounted. I think I have it all engineered in my head but a few more ideas never hurt. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
NeverEasy Posted April 9, 2019 Report Share Posted April 9, 2019 Phil, I think this is what you are looking for. Chet Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
Quickthrotl Posted April 9, 2019 Report Share Posted April 9, 2019 Phil, i have a storage box behind my 5th wheel 2004 Volvo VNL 780 2017 Momentum 376TH 2007 Harley Davidson FLHTC 2009 Smart4two Link to comment Share on other sites More sharing options...
Big5er Posted April 9, 2019 Author Report Share Posted April 9, 2019 Chet, that's it! I'm going to mount generator back there in a box. It's too big to mount behind the fairings so its gonna go back there. I would have preferred one smaller but I latched on to a commercial grade 7.5kw Onan QD for a price that was too good to pass up. Do you know how many hours I can run a genset on 275 gallons of diesel? I'll send Brad a message and ask for more pics of his build. Thanks again. Quickthrotl, thanks but I'm wanting to mount one to the rear of the truck, between it and the trailer. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Larry Burkett Posted April 11, 2019 Report Share Posted April 11, 2019 Phil Check out Hewhoknowslittle's Freightliner. He has his 8k Onan mounted into the back of his frame. His truck is not singled though. Link to comment Share on other sites More sharing options...
Big5er Posted April 13, 2019 Author Report Share Posted April 13, 2019 Yeah, I've seen Roger's truck. I dont have that kinda room....or his $$$$ obviously LOL MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted April 13, 2019 Report Share Posted April 13, 2019 6 hours ago, Big5er said: Yeah, I've seen Roger's truck. I dont have that kinda room....or his $$$$ obviously LOL Yes do to Phil's great personality, we spent a long weekend together this January, I was on my way to Florida and stopped in on Phil. And you do have my $$$$, you are just saving it for traveling. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted April 14, 2019 Report Share Posted April 14, 2019 Roger, How low are the boxes aired up ? Phil, My rear body is actually saddle bags on the frame. Your truck has a body, are you going to cantilever off the frame? The hitch on my truck is not far back 8~10" behind the axle, trailer clearance is close. That is with a 90" wide straight body, a gen box alone would be about 48~56" wide? Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Big5er Posted April 14, 2019 Author Report Share Posted April 14, 2019 9 hours ago, Hewhoknowslittle said: And you do have my $$$$, you are just saving it for traveling. Sweet!! I thought I was broken but now that I have your $$$$ I'm rolling in it. Thanks Roger 😁 5 hours ago, Steve from SoCal said: Phil, My rear body is actually saddle bags on the frame. Your truck has a body, are you going to cantilever off the frame? The hitch on my truck is not far back 8~10" behind the axle, trailer clearance is close. That is with a 90" wide straight body, a gen box alone would be about 48~56" wide? Steve Steve, check out the picture in the post that Chet referenced for me. I'm basically going to add a pair of receiver hitches and mount a stinger on the rear of the truck using them at the bottom and pins at the top to control bounce. My hitch is much further to the rear than yours so I'm going to use that wasted space under the front of the 5er. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
NeverEasy Posted April 15, 2019 Report Share Posted April 15, 2019 I am interested in your install. I bought an Onan 6.5 diesel and want to mount it back there. It is 30 long x 25 tall x 24 wide. Are you going to shock mount it in any way or will it be a rigid mount to the receivers? I noted you will use two receivers. I was thinking the one installed for tow-behind trailers and outside support arms sitting on the cross member. I have the base plate ready and contemplating the front and back needs for air-flow while running/weather while in transit. It probably will not happen until after the ECR. Chet Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
Big5er Posted April 15, 2019 Author Report Share Posted April 15, 2019 Chet, the 7.5 is vented, cooled and exhausted from the bottom and designed to be installed in a compartment so I dont need to worry about airflow. I had planned on a rigid mount but if Herrin has any suggestions, I am open to them. I have one receiver hitch already but thought two would have less play and allow for more stability. Again, If Larry has a better idea I'm open to suggestions. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 15, 2019 Report Share Posted April 15, 2019 With the weight of a diesel generator, dual mounts are almost a necessity. Especially with the balance point being a moving target. I initially built one for a single point, but it flopped around enough I quickly tired of the noise and motion. It was originally mounted on a LDT, but still. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Big5er Posted April 15, 2019 Author Report Share Posted April 15, 2019 Darryl, that is why I was planning for pins/bolts/some other attachment at the top, to help stop that movement. In your opinion will that help/be enough? Needless to say I will have to move the rear ID lamps and the camera/trailer light connections. The picture shows where I plan to add receiver hitches, the pins and the rough size/position of the box. Another angle of the rear of my truck MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 15, 2019 Report Share Posted April 15, 2019 Two points of mounts is enough, by themselves. Only when a single point mount is used, is something needed to tame the flop. People use wedges, clips, and all manner of things to calm the motion, but two mounts are all that's needed. The weight of the load will control fore-aft movement and the two mounts with control the side to side motion. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Big5er Posted April 15, 2019 Author Report Share Posted April 15, 2019 I figured the weight would control the slop in the receivers but since these uprights are there, I thought pinning it couldn't hurt. That generator weighs in around 600 lbs, plus the box. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Steve from SoCal Posted April 16, 2019 Report Share Posted April 16, 2019 Phil, If you triangulate the outer tray to the points shown, that will stiffen up the whole thing. I am not a fan of cantilevered loads on the very back of a truck body. It can get pretty bouncy. My 2 cents, Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
HERO Maker Posted April 16, 2019 Report Share Posted April 16, 2019 Phil, while you're at it, have Larry add another step plate across the rear (or side) of the new box. You will like it for getting on top of the bed. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 16, 2019 Report Share Posted April 16, 2019 1 hour ago, HERO Maker said: Phil, while you're at it, have Larry add another step plate across the rear (or side) of the new box. You will like it for getting on top of the bed. Oooh! I like that idea. As far as the triangulation points, never hurts to have too much support. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Big5er Posted April 16, 2019 Author Report Share Posted April 16, 2019 Thanks Steve, I'll let work on that. Rocky, great idea. Thanks MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
lockmup68 Posted April 16, 2019 Report Share Posted April 16, 2019 Mine is mounted long ways in between the frame rails in front of the hitch. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Big5er Posted April 16, 2019 Author Report Share Posted April 16, 2019 I've seen yours and I am jealous. I wish I had that much room. That is a sweet mount. This is plan B...well maybe C. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Brad NSW Posted April 17, 2019 Report Share Posted April 17, 2019 Phil, Sent you a message describing my build. Will send pics tomorrow when it's light out so you can see what I was describing. Don't know how much help it will be because I wouldn't be comfortable putting more than 200lbs in it (box weighs just under 100). I did find out things didn't bounce around in there as much as I thought. I'm dual in the rear and have lowered my tire pressure to 80psi per the tire manufacturers load vs pressure chart. Might be helping smooth the ride out. Brad 2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel. Occupants - Dena/Brad/Hershey BLOG LINK Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 17, 2019 Report Share Posted April 17, 2019 Phil, I think you are on the right track. You MUST use dual mounts or you will regret it. There would be quite a lot of movement without dual mounting pints. Also, there can be a lot of sag if not supported right, but Larry should be able to handle that. It should work out well assuming you get it stable enough. Just make sure there is a flex line in the fuel line or it will crack on you - but I assume you know that. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Big5er Posted April 17, 2019 Author Report Share Posted April 17, 2019 I am planning on some quick disconnects on the fuel lines and a plug on the 12v from the truck batteries so I CAN remove it if need be. I don't plan to take it off, but who knows? I may use bolts instead of pins for a tighter connection. I'll left Larry figure that out. He's never let me down. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
lockmup68 Posted April 18, 2019 Report Share Posted April 18, 2019 Few thoughts: 1. even though it is heavy and unlikely, bolts or locking pins to keep the handsy people at bay 2. Need to relocate the license plate so it is not blocked? or is it acceptable in this case? 3. Are you relocating the light connections? I'm mostly thinking rubbing of trailer wire on the genset. 4. Are you putting the genset in a box? Or just a cradle. Just thinking you don't want someone coming by and starting it up if it is wide open on the back. I do like the location of my genset, but will be a bear once I fix the rear of the bed (raise the bed up to be level and raise the hitch to the correct ride height (current hitch is at 41" vs 48")). Easy to change the genset filters and oil from the ground, but if you need to pull panels off to troubleshoot electrical, too close to airbags (and airbags actually rub a bit when deflated I discovered, I have a small hole in one of the airbags), to get the panel off. I will probably have to raise the genet up to the top of the bed at the sametime. I'm also wondering if the exhaust exiting underneath is going straight to the air filter of the genset and maybe choking it a bit? I'm thinking of putting a 90 on the muffler and routing it further to the outside of the body. Right now just dumps down underneath and right in front of one of the brake cans. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
