RandyA Posted April 5, 2019 Report Share Posted April 5, 2019 (edited) It would be extremely helpful for me to have some sort of headcount for the build-it project at the ECR. I have asked those who want to participate to bring a 50 amp plug. I will be bringing the remaining materials and knowing if I have enough or too many will help as I get things together. The following is an edited repost of what was put up earlier: Posted March 6 (edited) This is the preferred 50 amp plug. Clicking on the above link to Amazon will allow on-line ordering. Plugs should be available at any RV parts store and selected WalMart stores. The quick check tester will include these functions: L1 to neutral pedestal wiring OK L2 to neutral pedestal wiring OK L1 to ground pedestal wiring OK L2 to ground pedestal wiring OK The correct phase relationship between L1 and L2 No reversed hot or neutral connections Bonding of ground and neutral at the pedestal Failure of select lights to illuminate will indicate a possible fault in the pedestal wiring. This is a simple low-tech project for those that do not have a commercial EMS or want to do a quick check of any 50 amp park outlet. The indicator lamps are neon with resistors pre-attached. Extension wires will need to be soldered and attached to the appropriate points inside the plug. The device replaces the sometimes awkward testing of the park pedestal with a VOM. I will bring the additional components needed with me. There is no additional cost for components used to complete the project. Edited April 7, 2019 by RandyA Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
rickeieio Posted April 5, 2019 Report Share Posted April 5, 2019 Count me in. Will you have a "donation bucket" to help defray your costs? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
geodog Posted April 6, 2019 Report Share Posted April 6, 2019 Count me in. I could help cover some of the overhead expenses I will be going to Mor-Ryde from the rally for a suspension and brake upgrade. I just finished installing the BluDot hardware today. ShortyO Quote Link to comment Share on other sites More sharing options...
RandyA Posted April 6, 2019 Author Report Share Posted April 6, 2019 Additional expenses are insignificant and I do not want "donations" - I just need to know how many are interested so I can prepare properly. Sincere thanks to those that offered anyway. Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
alan0043 Posted April 6, 2019 Report Share Posted April 6, 2019 Hi Randy, Please count me in. I have my plug. What tools do we need to bring ? Thanks Randy for the project, Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
DesertMiner Posted April 6, 2019 Report Share Posted April 6, 2019 Any chance you can “share” the “how to” and a parts list for those of us that won’t be at the ECR? TIA Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 6, 2019 Report Share Posted April 6, 2019 I’m in. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
jkoenig24 Posted April 6, 2019 Report Share Posted April 6, 2019 I'm in. What do I need to bring? THANK YOU! Quote Link to comment Share on other sites More sharing options...
sclord2002 Posted April 6, 2019 Report Share Posted April 6, 2019 Randy, you know I'm in. I am looking forward to this project and the rally. Charlie Quote Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
PaHunter Posted April 7, 2019 Report Share Posted April 7, 2019 Sadly we have to leave on wednesday, so will miss it. Quote Chris . Sandpiper 379 FLOK, Volvo 2012 730. Link to comment Share on other sites More sharing options...
RandyA Posted April 7, 2019 Author Report Share Posted April 7, 2019 8 hours ago, DesertMiner said: Any chance you can “share” the “how to” and a parts list for those of us that won’t be at the ECR? TIA Yes, it will be online with Carl's recap info after the rally. Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
RandyA Posted April 7, 2019 Author Report Share Posted April 7, 2019 7 hours ago, jkoenig24 said: I'm in. What do I need to bring? THANK YOU! Any of the following will be helpful. I will have a collection of these to share but the more we have the faster things will go. Hot glue gun - preferably with 7mm clear sticks Low wattage soldering iron Phillips screwdriver Small wire snips or toenail clippers 7/32" drill bit (and drill) Butane lighter for heat shrink tubing Small long nose pliers Sharp pocket knife Your reading glasses Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
DesertMiner Posted April 7, 2019 Report Share Posted April 7, 2019 28 minutes ago, RandyA said: Yes, it will be online with Carl's recap info after the rally. Thank you👍 Quote Link to comment Share on other sites More sharing options...
Danandfreda Posted April 7, 2019 Report Share Posted April 7, 2019 Count me in on the project Quote Link to comment Share on other sites More sharing options...
DanBree Posted April 8, 2019 Report Share Posted April 8, 2019 I plan on being there. Quote Dan & Bree 2010 Freightliner Cascadia 125, DD15, 455hp, UltraShift (Yetti, For Sale) 2015 Grand Design Reflection 308BHTS Travel Trailer (For Sale) Link to comment Share on other sites More sharing options...
NeverEasy Posted April 9, 2019 Report Share Posted April 9, 2019 I am in! Chet Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
lockmup68 Posted April 10, 2019 Report Share Posted April 10, 2019 +1. I also have a heat gun if needed. Shannon Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
