D.Smith Posted March 28, 2019 Report Share Posted March 28, 2019 Has anyone removed their class c cab over window, or know where I can find info on doing it? Link to comment Share on other sites More sharing options...
Kirk W Posted March 28, 2019 Report Share Posted March 28, 2019 I don't believe that would be any different from removing any other RV window. Most of them have an inside frame that is held in place with screws every 3 - 4". If you remove the screws you can then lift the frame off. You then need two people, one inside to press outward on the window and one outside to take the window as it comes loose. It will be stuck to the side of the RV with caulking tape that is used to seal nearly all things which penetrate the exterior of RVs. When you put it back in you will need to put new tape on. It is available from Amazon or nearly any RV supply store. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
