ARGO Posted March 20, 2019 Report Share Posted March 20, 2019 Looks like I may have to replace several headliner panels due to a leak. Current setup is vinyl over 1/4 foam, over wood and 3/4" Styrofoam on top for insulation (?). Well, there's gotta' be better, has anyone done anything different? With the headliner down, now's the time. Search on here came up 0 Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
ALLOY Posted March 21, 2019 Report Share Posted March 21, 2019 Best insulation (but not the easiest to install) in a RV roof is XPS (extruded polystyrene). It should be fit as tight (cut the pcs 1/32" oversize) as possible and then caulk any gaps so there is no air flow around it. If you want more insulation adding another layer of 1/4" or 1/2" foam will reduce the thermal bridging. Quote 2011 Cameo 34SB3 Link to comment Share on other sites More sharing options...
ARGO Posted March 22, 2019 Author Report Share Posted March 22, 2019 Tks! I'd love to get it sprayed, but I think the cost/benefit would kill it. I put a 1/2" layer of pink styro in a boat overhead & that helped the A/C a lot. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
ALLOY Posted March 23, 2019 Report Share Posted March 23, 2019 On 3/22/2019 at 4:21 AM, ARGO said: Tks! I'd love to get it sprayed, but I think the cost/benefit would kill it. I put a 1/2" layer of pink styro in a boat overhead & that helped the A/C a lot. Just to be clear XPS isn't Urethane Spray Foam. You don't want to use spray foam in an RV unless there is a properly installed / 100% sealed vapor barrier. I've seen mold around the staple holes in a vapor barrier. Even the best foam spayed under ideal conditions is 5% open cell which means the foam will absorb 5% moisture/condensation. Also avoid ISO Board. ISO Board works great to insulate against heat (sun) but not cold. It contains a gas that when cold turn to liquid thus reducing the R rating. Quote 2011 Cameo 34SB3 Link to comment Share on other sites More sharing options...
ARGO Posted April 13, 2019 Author Report Share Posted April 13, 2019 OK, looks like the dreaded "headliner replacement" is on the horizon. Anybody done one? Vinyl, 1/4" foam, luan & Styrofoam. Factory sent me instructions on how to do it, & panels are relatively cheap. Can't find a shop competent to do that here closer than Elkhart Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
ARGO Posted June 17, 2019 Author Report Share Posted June 17, 2019 Still looking for a shop to do my ceiling replacement, suggestions welcome Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Ray,IN Posted June 17, 2019 Report Share Posted June 17, 2019 (edited) There are many RV repair/remodeling shops available. The most obvious action is run a search for those type shops within 100 miles of your location, no results-widen search. ALLOY seems to have the best option for increasing insulation R-value.To fill voids I would use the best quality spray foam available. Edited June 17, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
ARGO Posted June 17, 2019 Author Report Share Posted June 17, 2019 Problem seems to be they all want to remove roof, drop in headliner and replace roof. Can't do mine that way, HAS TO BE done from inside & shops are scared. Too much like work I guess. Want to stay east of Miss and south of Baltimore, Elkhart's too cold in winter. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Ray,IN Posted June 18, 2019 Report Share Posted June 18, 2019 On 6/17/2019 at 3:42 PM, ARGO said: Problem seems to be they all want to remove roof, drop in headliner and replace roof. Can't do mine that way, HAS TO BE done from inside & shops are scared. Too much like work I guess. Want to stay east of Miss and south of Baltimore, Elkhart's too cold in winter. Nearly all RV's are built from the bottom up,and the roof is the last constructed. This means adding insulation from inside is much more difficult, requiring cutting around walls, cabinets, etc to remove the ceiling paneling. Removing the roof is IMO the most practical, I don't know why your roof is not removable, could you explain? Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
