Friz Posted March 7, 2019 Report Share Posted March 7, 2019 I have not been on the road pulling a 5th wheel with a diesel pick up truck in 13 years. Although I have always had a diesel pickup I go to the car pumps to buy diesel.The last time I camped the semi-truck pumps at truck stops had larger diameter nozzles which were too large for my pickup truck. Obviously I had to chose fuel stations wisely. I would have paid the extra money to fill up at a truck stop for the convenience of using the semi truck pumps. I have a 2004 F250 diesel. Are pickup trucks now able to use the larger nozzles? Thanks, Friz Quote Link to comment Share on other sites More sharing options...
mptjelgin Posted March 7, 2019 Report Share Posted March 7, 2019 My 2019 F-350 is rated to take a 30mm (1.2 inch) nozzle, and fill at up to 20 gallons per minute. I've used a truck pump once. It had an obviously larger nozzle and it filled quickly. What I don't know is if there are even larger nozzles out there. Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 7, 2019 Report Share Posted March 7, 2019 (edited) Most major truck stops have an RV lane for filling pickups with a regular size nozzle. It's usually located at the front or next to the truck lanes but separate from the usual car lanes. I'm speaking of Love's, Pilot's/Flying J etc. Edited March 7, 2019 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
LindaH Posted March 7, 2019 Report Share Posted March 7, 2019 Even if there's not a specific RV lane, we found that *most* truck stop diesel lanes have one pump with a smaller nozzle, usually on an outside lane. If in doubt, go inside before pulling up to a pump and ask. Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
Second Chance Posted March 7, 2019 Report Share Posted March 7, 2019 Friz, What make and year is your truck? Both my 2012 Ford and previous 2013 GMC can/could handle the larger truck nozzles without a problem. Rob Quote 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
sandsys Posted March 7, 2019 Report Share Posted March 7, 2019 6 hours ago, LindaH said: Even if there's not a specific RV lane, we found that *most* truck stop diesel lanes have one pump with a smaller nozzle, usually on an outside lane. If in doubt, go inside before pulling up to a pump and ask. X2. I quickly learned that in my Sprinter van. Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
MidMOTraveler Posted March 7, 2019 Report Share Posted March 7, 2019 No problem But don’t set the handle they are high pressure high capacity pumps. The back wash from the fuel fill neck will get you covered in diesel. Remember truck stop etiquette, usually your cc won’t work at the pump. Walk in tell the cashier you lane # and that it’s a private truck most will ask how much. I usually tell them $100 they will swipe the card, go fuel. Pull forward to the line making sure a semi can pull in and fuel. Return to the cashier and get a credit/ receipt Nows the time for a quick restroom break but if you plan to be a while park it and go in. Enjoy your travels ! Quote Link to comment Share on other sites More sharing options...
Kirk W Posted March 7, 2019 Report Share Posted March 7, 2019 9 hours ago, Friz said: I have a 2004 F250 diesel. My 2003 Dodge 2500 does not accept the large truck lane nozzles. But I find life much less complicated with my little travel trailer if we just use the RV lane when available and the car island with diesel if it isn't. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Larry Burkett Posted March 7, 2019 Report Share Posted March 7, 2019 I can fill my 2019 F450 from empty to full in 4 minutes flat at the truck stops, and there is no back splash when it shuts off. Money goes fast though. Quote Link to comment Share on other sites More sharing options...
rynosback Posted March 8, 2019 Report Share Posted March 8, 2019 My 2015 Ram 3500 takes the larger/semi nozzle. It just pumps it really quick. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Ray,IN Posted March 9, 2019 Report Share Posted March 9, 2019 My limiting factor for my dually was the vent hose size; liquid in- air out, to slowly. My MH has a 90° bend 4" from the inlet, foaming is the problem there. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
richfaa Posted March 9, 2019 Report Share Posted March 9, 2019 Our 08 F-350 has the large fill we knew that.We normally use pilot /FJ. We normally use the RV lanes. We will use the truck lanes if necessary. We have never had a problem of any kind. Quote Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted March 9, 2019 Report Share Posted March 9, 2019 I have never had a problem with my 2012 F350 filling it at any pump I chose to include truck islands but as others have stated watch the rate of flow. Quote Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
Mr. Camper Posted March 9, 2019 Report Share Posted March 9, 2019 We rarely use the big truck stops as they are usually along the Interstates. We have used smaller ones along US routes and never had a problem filling our 2016 RAM 2500 at any pump. Much more room to maneuver at the truck pumps when we have the RV hooked up. One of us is usually pumping the fuel while the other one does the windshield and walks the fuzzy kids. As previously stated pull up out of the way when done pumping to allow the next in line to move up, even if there is no one behind you. Quote Link to comment Share on other sites More sharing options...
Friz Posted March 10, 2019 Author Report Share Posted March 10, 2019 On 3/7/2019 at 11:43 AM, Second Chance said: Friz, What make and year is your truck? Both my 2012 Ford and previous 2013 GMC can/could handle the larger truck nozzles without a problem. Rob 2004 F250. A response on another forum said that Fords after 2003 can take the larger nozzle. Will see if it is true next time I fuel up. Quote Link to comment Share on other sites More sharing options...
Don_T Posted March 11, 2019 Report Share Posted March 11, 2019 We have a Pilot/Flying J CC so we drive up to the truck pumps and fill up with the card and get out of the way. We have had no issues doing this. Quote Link to comment Share on other sites More sharing options...
sandsys Posted March 12, 2019 Report Share Posted March 12, 2019 4 hours ago, Don_T said: We have a Pilot/Flying J CC so we drive up to the truck pumps and fill up with the card and get out of the way. We have had no issues doing this. The only problem I have heard of with this is when a motorhome manufacturer put the DEF tank on the wrong side so the owner had to drive up the wrong way to fill the DEF tank. Fortunately the truck driver approaching that island was kind. Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Friz Posted May 22, 2019 Author Report Share Posted May 22, 2019 A little late but thanks for the help. Yes, the large nozzles fit into mine. Checked it out last week. Had forgotten how oily/greasy the deck is around trucker's fuel pumps. My floor mats reminded me. Quote Link to comment Share on other sites More sharing options...
