deb.mike.g@gmail.com Posted March 5, 2019 Report Share Posted March 5, 2019 is a 2018-19 pathfinder good for towing a 6000 pound travel trailer Quote Link to comment Share on other sites More sharing options...
NDBirdman Posted March 5, 2019 Report Share Posted March 5, 2019 (edited) Welcome to the forum! No experience here with that vehicle. But my opinion, I don't max out what the door sticker says I can do, I like a little room left for comfort. That 6k pounds includes trailer/water/clothes/cookware/ food, etc. I say the added is probably 1,500lbs so look at a 4.5lb camper? I'm thinking lightweight pop-up or teardrop style camper but that's just my 2 cents. That's towing weight, you have to check on tongue weight which is much lighter, then tire/axle weight ratings, brakes, etc. Even that small, if not set up right could make for a towing/stopping nightmare. Edited March 5, 2019 by NDBirdman Quote 2002 Fifth Avenue RV (RIP) 2015 Ram 3500 Mega-cab DRW(38k miles), 6.7L Cummins Diesel, A668RFE, 3.73, 14,000 GVWR, 5,630 Payload, 27,300 GCWR, 18,460 Max Trailer Weight Rating(For Sale) , living in the frigid north, ND. Link to comment Share on other sites More sharing options...
trailertraveler Posted March 5, 2019 Report Share Posted March 5, 2019 (edited) Welcome to the Escapees Forum!!! This calculator will help you figure out what trailers you can safely tow. If you already have the Pathfinder, load it with a full tank of fuel and all the passengers and gear that you will carry and get it weighed. Use this weight in the calculator to determine what trailer you can tow. If you do not own the pathfinder yet, select the trailer first and then match a tow vehicle to the Gross Vehicle Weight Rating (GVWR) of the trailer. Another issue that is not discussed as often as weight is the relationship between tow vehicle wheelbase and trailer length. This website gives a good overview of this important consideration. Again, welcome to the Escapees Forum!! Edited March 5, 2019 by trailertraveler Quote Link to comment Share on other sites More sharing options...
Kirk W Posted March 5, 2019 Report Share Posted March 5, 2019 Welcome to the Escapee forums! I would follow the advice above and you should do fine. For us to say what you can tow with your Nissan we need much more information about it. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
LindaH Posted March 5, 2019 Report Share Posted March 5, 2019 15 hours ago, deb.mike.g@gmail.com said: is a 2018-19 pathfinder good for towing a 6000 pound travel trailer Is that 6,000# the dry weight or the GVWR? Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
IBTripping Posted March 8, 2019 Report Share Posted March 8, 2019 (edited) In a word, NO. The Pathfinder is a unibody construction light SUV. The maximum towing capacity is from 3,500 to 6,000 lbs. However, the biggest limiting factor is the payload (cargo) capacity. It may have a cargo capacity of up to 1,462 lbs. If the trailer has a gross weight of 6,000 lbs, the minimum tongue weight is 600 lbs plus about 80 lbs for the weight distribution hitch. That leaves 782 lbs for passengers, pets and any other stuff carried in the Pathfinder. Only certain specific models of Pathfinders are rated to tow 6,000 lbs. On the drivers door is a white sticker and a white sticker with yellow markings. The yellow sticker will tell you the towing and payload capacity of your specific Pathfinder. Post those numbers and we can tell you exactly what weight trailer your Pathfinder can safely tow. Finally, as a rule of thumb, the gross weight of a travel trailer should NOT exceed 80% of the towing capacity of the towing vehicle (TV). The reason is the front, flat end of a travel trailer generates a lot of wind resistance. And, the large flat sides of a travel trailer acts as a huge sail which can be pushed around by passing semis and crosswinds. Even if your Pathfinder is one of the rare ones with a maximum towing capacity of 6,000 lbs., the 80% rule means you can only safely tow a maximum gross weight 4,800 lb travel trailer. Once you get the information from the yellow sticker, we can calculate the safe tow weight of a travel trailer for your specific Pathfinder. If you try towing a 6,000 lb travel trailer, it will over stress and over heat the engine, transmission, and other drive train parts. It will be a miserable, white knuckle, and dangerous towing experience. You will experience the trailer wagging the dog (tow vehicle). Either get a better tow vehicle or much lighter travel trailer. Edited March 8, 2019 by IBTripping Quote TT - 1996 Coachmen Catalina 24' bunkhouse TV - 2004 Durango 4.7L V8 Link to comment Share on other sites More sharing options...
Kirk W Posted March 8, 2019 Report Share Posted March 8, 2019 Deb & Mike, is there anything more that we can help you with? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
IBTripping Posted March 10, 2019 Report Share Posted March 10, 2019 On 3/8/2019 at 10:30 AM, rm.w/aview said: As you research your Pathfinder, there's also a relationship of the tow vehicle's wheelbase & travel trailer length. So coming back to elaborate, one guideline that's used by the RV Consumers Group is that the first 110" of wheelbase on your tow vehicle allows for a 20' travel trailer, and each additional 4" of wheelbase allows for 1' more of travel trailer. So a tow vehicle wheelbase of 146" is 36" more than the baseline of 110" which would allow 9 more feet, or a 29' travel trailer. Keep in mind that this is only a guideline and exceeding it by a small amount will not cause the world to end, but the further you go from the safe zone the more uncomfortable and perhaps dangerous the drive will be. Like carrying a sheet of plywood on a blustery day, the larger the sheet the greater the affect. X2 Quote TT - 1996 Coachmen Catalina 24' bunkhouse TV - 2004 Durango 4.7L V8 Link to comment Share on other sites More sharing options...
bigjim Posted October 14, 2020 Report Share Posted October 14, 2020 5 hours ago, drewaver said: Dude, 6000 pounds, for a pathfinder... well i am not sure, however if it is just the weight of the trailer, the dry trailer, than i guess it is too much for your car. Did you note the age of the last post on this thread? Quote Link to comment Share on other sites More sharing options...
