Wizards&OZ Posted March 4, 2019 Report Share Posted March 4, 2019 What are some of the things you recommend we do to our motorhome in between trips. Like, those times we park the RV in the driveway for a month or less before heading back out on the road. What are some obvious and less than obvious things we should consider doing to the RV. Like, empty tanks? Fill tanks? Refridgerator? Open/Close windows? Etc. This would be during the summertime, so winterizing won't be necessary. Thoughts? Link to comment Share on other sites More sharing options...
Barbaraok Posted March 4, 2019 Report Share Posted March 4, 2019 Are you hooked up to power or not? If not, throw disconnect switches. Is the refrigerator emptied, if so, keep doors open. Open roof vents (assume you have covers for them) and cover windows Empty tanks when you leave the last stop, then had a few gallons of water to each tank to keep the bottom of the tank wet. Make sure you have water in the traps. I fill zip-lic bags 1/2 full with water and place over each drain and also over the the toilet valve. Make sure there are no food items left that could swell if they get very warm or break apart (boxes letting go). Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
rynosback Posted March 4, 2019 Report Share Posted March 4, 2019 I would refer a lot to your owners manual on maintenance and storage. Some rigs might have specific things to do over others. This could also be a good question to pose on a forum that is all about your make and model of rig. Since I do not know what you own, you will have to Google it. 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
sandsys Posted March 4, 2019 Report Share Posted March 4, 2019 If you plan to leave dry foods in the rig be sure they are in rodent proof containers. Also, find out what type of rodents frequent the area and what type of deterrent works best for that. Then vacuum every crevice where you might have spilled food--one time we had carpets cleaned and when they moved the couch the guy exclaimed, "Treats!" Linda Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
chindog Posted March 5, 2019 Report Share Posted March 5, 2019 Check the water levels in your batteries every month regardless of use. Mike and Retha Hopkins 2014 Fleetwood Discovery 40G Link to comment Share on other sites More sharing options...
kb0zke Posted March 5, 2019 Report Share Posted March 5, 2019 If you are actually only parking for <month, you probably don't have to do much of anything. If you have power, even 15A, you can keep the refrigerator going and your batteries charged. I'd take the time to sanitize the fresh water tank a couple of times a year with that sort of use. That downtime can be helpful for getting maintenance done or doing upgrades. Some people like to keep their RV ready to go at all times, especially those in fire-prone areas or hurricane paths. Unless you are willing to abandon your S&B every time there is a tornado watch, though, trying to leave when a tornado threatens probably is a waste of effort. They can move faster than you can. David Lininger, kb0zke 1993 Foretravel U300 40' (sold) 2022 Grand Design Reflection 315RLTS Link to comment Share on other sites More sharing options...
Rockie Posted March 20, 2019 Report Share Posted March 20, 2019 I saw a pretty good list on https://www.rvriders.com/rv-road-trip/ Quote Things to do when done traveling in your RV and you are ready to store it: Remove all extras the the RV, including linens and clothing. Unplug the fridge and freezer then let them dry out. Remove the propane tanks. Drive the RV around the block every couple of moths to prevent flat spots on the tires of the RV. Cover vents with bug preventing screens. Wash and apply a heavy coat of wax to the RV. Apply a cover that has holes for the air vents. Turn off the circuit breaker. Remove all valuables. Remove your battery and store it at home. Pay your mail forwarding service. In areas where the winters are cold, anywhere but the beach, you must follow some winterizing procedures: Pressurize the water pump. Add some antifreeze to the windshield wash solution. Seal off all faucets. Put a cup of antifreeze in the drains. Empty the water heater. Link to comment Share on other sites More sharing options...
richfaa Posted March 23, 2019 Report Share Posted March 23, 2019 We have no idea what our time between trips are as we never kept a record. When between trips the RV is on our property with full hook up since we have been on the road for 8 to 9 months of the year for the last 12 years the time between trips is not all that long. We are never in cold weather and have not winterized a RV since 2005. We do remove perishables when not on the road but keep the fridge powered up at all times. We winter in a warm climate for 6 months of the year so it can be said that our time between trips is 6 months. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
