Reidgreh Posted February 28, 2019 Report Share Posted February 28, 2019 My brother who is computer illiterate would like to add a side air scoop to help push more air into the radiator on his Dutch Star. I am requesting your input on 2 things and will happily relay the info to him: 1) Is this advisable to do? Are there any downsides to this approach 2) Do you know of any sources to obtain a side air scoop of this type? Appreciating y'all in advance. Link to comment Share on other sites More sharing options...
Barbaraok Posted February 28, 2019 Report Share Posted February 28, 2019 Year, model? Assume it is a rear radiator as side radiators get air stream easily Thoroughly clean gunk off of radiator is first step if overheating. Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Ray,IN Posted March 3, 2019 Report Share Posted March 3, 2019 He does realize a scoop will force road dirt and bugs into the radiator faster, right? The first action he should take is to do as Barb and Dave said, clean the radiator of dirt and oils; there should be no other reason for additional air movement. Newmar engineers are very good at designing great MH's. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
