aztex Posted February 17, 2019 Report Share Posted February 17, 2019 Howdy, I survived a few nights in the 20's with a furnace on the fritz and learned how to fix it and got a good space heater and many blankets! I want to be more prepared as it gets warmer (hopefully sooner than later! :D) I have an Airstream Sport 22FB with stock Dometic AC that sounds like a jet plane! Are smaller portable units an option? How about small less amperage swamp coolers? My plan is to avoid extremes but ya know how things can go... The Airstream opens up pretty good to get lots of air flow. Thanks, Az Tex Link to comment Share on other sites More sharing options...
2gypsies Posted February 17, 2019 Report Share Posted February 17, 2019 All you need to plan your trips with 'elevation' in mind. 6500' to 8000' elevation will allow you stay without air conditioning. Personally, we prefer around 8,000' and have to use blankets at night! Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
RV_ Posted February 18, 2019 Report Share Posted February 18, 2019 A noisy Rooftop AC is usually the result of age but can often be the result of someone tightening the four nuts on the bolts that hold it on the roof. When that gasket gets too old it can leak causing folks to tighten the nuts too much. Here's another reason I had where my AC capillary line to the compressor was vibrating until it cut it through, letting the freon and oil run all over the roof which oil made a bad patch of my roof membrane. Thhttps://www.bing.com/videos/search?q=checking+loud+RV+AC&pc=MOZI&ru=%2fsearch%3fq%3dchecking%2bloud%2bRV%2bAC%26pc%3dMOZI%26form%3dMOZLBR&view=detail&mmscn=vwrc&mid=537D8582C052948CF307537D8582C052948CF307&FORM=WRVORC There are a bunch of videos there to help find the noise. RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
Kirk W Posted February 18, 2019 Report Share Posted February 18, 2019 1 hour ago, aztex said: I have an Airstream Sport 22FB with stock Dometic AC that sounds like a jet plane! While it is true that needing maintenance can make them noisier, even under ideal circumstances roof air conditioners are loud and particularly so if they are not ducted. In recent years some of them have improved, but not a great deal. Swamp coolers are not generally very practical for use in an RV, particularly if you travel very much. I have seen them used in permanently parked RVs in the desert, but remember that they also require a water supply so aren't very useful if boondocking, which is also true of the roof air conditioners since they require more power than is practical from an inverter. I'm not sure how one could make one of the portable air conditioners work in an RV? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
aztex Posted February 18, 2019 Author Report Share Posted February 18, 2019 Thanks! It's a brand new factory installed AC. It isn't rattling; just a loud fan! It's the roof mount type on an Airsteam. I guess a "portable" would be doable with power but portable is relative and they aren't really when it comes to vehicles.... I'll have to see how it goes! Thanks, Az Tex Link to comment Share on other sites More sharing options...
RV_ Posted February 18, 2019 Report Share Posted February 18, 2019 Aztex, Pull the plenum down for the AC and check if the factory over tightened it and squeezed it down too much. If it has been compressed too much it may not re-expand causing leaks when it rains. But RV air conditioning units are very loud compared to home units. There are basement units in some motor homes but I have no experience with them or if they are quieter. There is untapped profit for the company that silences them RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
sandsys Posted February 18, 2019 Report Share Posted February 18, 2019 3 minutes ago, RV_ said: There are basement units in some motor homes but I have no experience with them or if they are quieter. Our one basement unit was much quieter than any of our roof units. Linda Sand Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
whj469 Posted February 18, 2019 Report Share Posted February 18, 2019 Is it ducked? I once had a stand alone AC in the bedroom of a fiver and it was always loud. Link to comment Share on other sites More sharing options...
