rear air bags not filling up
JEEPOHOLIC
Does the truck have the port to add alcohol into the air system to remedy frozen air lines?
update, I lost the bar that connects the leveling valve to the rear axle, that bar lifts the bed up after a load has been put on it, so I'm getting the part ordered, ohh and the valve works, it fills the air bags, so I was mistaken about the possible frozen water in the lines, but needless to say I will be dumping my air tank more often, I think there is an electronic dump valve that dumps a small amount of air on a timed basis
That pull-rod is available from most any HDT repair shop. When my rear rod-end broke I got a new one from a Love's truck stop repair shop.  Your MH ride height must be totally reset to factory specs after you install the new rod, otherwise you will be replacing the driveshaft U joints rather quickly, and perhaps the bearings in the differential and transmission ends.
