53wlee53
I'm not sure where to post this
We were in Collingwood Ontario in September and saw this setup in the Walmart parking lot. Guess they have lightened up Airstream Trailers sense 1977. Our first Tavel Trailer was a 1977 31' Excela. It weight 8300 lb loaded.
The TV is a Volkswagen Tiguan.
Share this post
Link to post
Doesn't that thing have the two rating of a small car?  Class 1 maybe?  At least it looks like they are using WD.
Share this post
Link to post
I have a Avian it wheighs about 8k. Pulled it over the Bighorn moutions with my one ton, when we got to the botton my wife gave me the go ahead to get a bigger truck.
Share this post
Link to post
I thought it was a prank until I pulled up beside it and saw it was hooked up to a weight distrubting hitch with sway controllers. I looked up the tow capacity of it and it's 1500 lb!
My Wrangler JK has a higher towing capacity. I thought ya'll might get a laugh or scare.
Share this post
Link to post
I've pulled my share of stupid stunts, one if I told you I don't think anyone would believe and survived! So now I try to play it safe.
Share this post
Link to post
Perhaps in the same class as those guys hauling 40' toy haulers, overloaded, with a F250 running a Powerstroke, and lifted 8" running 38"s. "Well, its got a diesel and it pulls it fine".  Till they get to the scales OR until the adjusters get a hold of that set up after an accident, that the insurance company denies the claim on because of the obvious lack of attention to the tow ratings.
It just doesnt make sense to take chances with safety.
Share this post
Link to post
3 minutes ago, Dan Johnson said:
This is why I will not buy a used vehicle with a tow hitch on it.
All of my trucks came stock with hitches and my Jeep came stock with a hitch.  That's a lot of vehicles you can't buy.
Share this post
Link to post
Whats bad is he was at least 4 times the tow cap of the SUV. I doubt he could get the tranny out of 3rd gear unless coasting. My JK won't stay in OD with 3k lb behind it.
Share this post
Link to post
There is a clown in Canada that pushes towing with a lot less vehicle than you need.  He claims he puts on the correct hitch systems and then you are safe.  Seen a couple of his set ups and they are dangerous.
Ken
Share this post
Link to post
And it's got a higher tow rating.  I'm re-gearing my JKUR for towing, which will help a lot.  It's got 4.10s and 35" tires, going to 4.88s.
Share this post
Link to post
6 hours ago, hemsteadc said:
Doesn't look anything like an MDT.
Unless that acronym mean Magic Duty Tow
Share this post
Link to post
Ford calls there 250 Super duty, maybe this is VWs version of a MDSUV.
How does the Ruby do on fuel with 4.10s and 35s? I have the Sport with 32/3.21 gears. Going to 35s/4.10s maybe 4.56s in a few months. Concerned at hwy speeds 4.88s will have the motor screaming.
Share this post
Link to post
Around 16, and I was getting 18 without the lift and big tires.  It does better in the city than on the highway, unless the highway time is at 55-60 MPH.  It's just a brick, aerodynamically, and with the lift and tires, a bigger brick.  This is my second JKUR, and I had done 4.88s on the previous one.  The motor is barely above stock RPM with the 35s and 4.88 gears.  4.56 puts the RPM slightly lower than the stock 4.10 with stock tires.  So my fuel economy went up with the 4.88s on the previous one as compared to 35s and 4.10.
I've never driven a Jeep on 3.21 gears, that sounds so low-ratio.  Is it a manual?  Is it the pre-12 model?  I've got a 2015 automatic.
Share this post
Link to post
It's a 2012. 3.6 auto. If I remember correctly it"s the only ratio in the sport. Might be incorrect.It works wit 32" tires but I know it will be to tall for 35s. They would work with a LS3 and a 6L80E. But then I would need Dana 60s Front and rear.
Share this post
Link to post
I thought the stock tires and the 4.10s were perfect.  Putting on 35s made it a bit sluggish sometimes, and on an uphill highway at 75-80 it hunts gears, which is not good.  So yours seems so tall.  I held off doing 4.88s until I started towing, then it really needs it.  Off road, the 4:1 transfer case makes the gears not really relevant.
Share this post
Link to post
They are tall! The Ruby has a much better transfer case. I've read the 3.6 likes high rpm. It's jumps on takeoff very well, can't imagine how it will do with 4.88s & 35" tires. I stuck my 60hp Kubota 4x4 tractor so deep the bushhog was on the ground and it pulled it out.
Share this post
Link to post
So far on our trip, I have seen several 40+, tri axle tpoy haulers running with a single wheeled one ton.
I will go out on a limb that they were sold on this because it can "pull" it. I assume this ids illegal and since the LEOs won't do anything about it.. will the Ins company pay out when it is in an accident ?
Share this post
Link to post
Our Newmar weighs 18.6k empty. When we bought it it was 1-1/2 years old. The guy who bought it new left the dealer with a 3/4 ton, returned 15 months later with a 1 ton and traded it in on a Motor Home. He said to much trailer  for the truck.
Share this post
Link to post
FWIW......That is a VW TOUAREG, not a Tiguan. Mid-size vs compact. Still a ridiculously large trailer to tow behind it.
Touareg's are rated for 3500kg (7700lb) towing and have a 2inch receiver with a 7pin plug from the factory(no brake controller installed, but wiring is provided). We had one and I couldn't imagine pulling a trailer half that size. Even our little garbage trailer (maybe 1500lbs) turned it into a fuel guzzling slug.
Share this post
Link to post
Your correct about the Touareg tow rating. All I have to go on is the front grill in my pic. All Touareg's have a completely different grill than the pic. I could only find a grill like this on the Tiguan.
Not a VW guy so I could easily be wrong. If I'm wrong, my apologys.
Share this post
Link to post
Escapees Hangouts
Shade My RV
AGS Now Hiring
RV Pet Safety
