rdickinson Posted January 7, 2019 Report Share Posted January 7, 2019 There are some 12kw Onans available for 4k Can$. 800 lbs, 100 amp output. Way overkill for sure for my rig. But the 7.5kw Onans, 60+ amps, 400+ - lbs, from an Rv Salvage location are generally 5500$ US plus tax plus exchange plus duty at the border. Freight is relative. By the time I add all to the 7.5, it gets up around 8200 $ Can. Also I'm thinking fuel consumption on the 7.5 at 75% could be similar to less than 50% on the 12. Give or take a bit. I'd equate it to a Ldt pulling my rig as opposed the HDT. So, I'm thinking of mounting it passengers side, fwd of the 100 gallon fuel tank and aft of the regen system. I already have a 7.5 but it only turns out 30 amps max so there is a lot of power sharing going on. Access would be behind the tank fairing which would need to come off for service because it doesn't tip out and lift off like the fwd one does. Size wise the 12 is 40" long, 25 or 27 tall and about 24 wide. I figured I'd throw this out there for thought. Thanks Link to comment Share on other sites More sharing options...
jenandjon Posted January 7, 2019 Report Share Posted January 7, 2019 If I am understanding you right the 12 would be half the price. Id go that way. Even though its way over kill. You will use a little more fuel but thats the way it goes. I just have a little 4.0 Onan but I mounted a 50 gallon tank just for that. It works as long as I don't use the microwave while the A/C is on. I think its better to have more than need than need more than you have. At some point I am going to need a bigger one. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
rdickinson Posted January 7, 2019 Author Report Share Posted January 7, 2019 There is that saying, better to have more than you need than need more than you have. It would be 800 lbs on the passengers side. Link to comment Share on other sites More sharing options...
DJohns Posted January 7, 2019 Report Share Posted January 7, 2019 You should post model and spec number. Lots of Onans out there that seem cheep but are 240 volt only or 50 HZ. Rearch the model carefully before you buy. 2002 Beaver Marquis Emerald C-12 Cat 505 HP 2014 Volvo 630 D-13 I Shift SOLD 2017 New Horizons SOLD Link to comment Share on other sites More sharing options...
rdickinson Posted January 7, 2019 Author Report Share Posted January 7, 2019 Model # 12HDKCD-2209G Link to comment Share on other sites More sharing options...
DJohns Posted January 7, 2019 Report Share Posted January 7, 2019 How many hours and type of use? 4K Can = ? US dollars 2002 Beaver Marquis Emerald C-12 Cat 505 HP 2014 Volvo 630 D-13 I Shift SOLD 2017 New Horizons SOLD Link to comment Share on other sites More sharing options...
rdickinson Posted January 7, 2019 Author Report Share Posted January 7, 2019 3000 US using the currency converter. I've sent of a request for info, RFI but not had a response yet. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 7, 2019 Report Share Posted January 7, 2019 Why is your existing 7.5 kW only doing 30 amp? I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rdickinson Posted January 7, 2019 Author Report Share Posted January 7, 2019 Got it in 2005 but the main breaker is 30 amp. I'd have to dig out the manual and post model#. It runs at 3600 rpm. Multiquip DAC-7000SS A.C. Generator (Canada) Tier 2 Version Link to comment Share on other sites More sharing options...
RickS Posted January 7, 2019 Report Share Posted January 7, 2019 Hi Roger, If you have an older 7.5 Onan Diesel I believe it has 2-pole 30 amp breakers so 62.5 amps (120V) total. I have a 7.5 Onan in my fifth wheel (7.5HDKAJ11451J) and it has 2-pole 30 amp breakers and have never had a problem running everything in the RV. The rpm is governed by load so is not constant rpm. Rick & Carey,Excel W41GKE Wild Cargo Toyhauler Volvo 730, D13, I-shift, 500/1850Brabus Smart Car Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted January 8, 2019 Report Share Posted January 8, 2019 I put a 12.5 K on my truck to power my DRV as I needed to 220 volts for my dryer. I am in Houston today running all three air-conditioners television marker wave induction cooktop and I’ve yet to hear it over the television very quiet and smooth it runs at 1800 RPM at all times I’m very happy with this generator can’t wait to get the solar set up so it doesn’t have to run as much. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted January 8, 2019 Report Share Posted January 8, 2019 11 minutes ago, Hewhoknowslittle said: I put a 12.5 K on my truck to power my DRV as I needed to 220 volts for my dryer. I am in Houston today running all three air-conditioners television marker wave induction cooktop and I’ve yet to hear it over the television very quiet and smooth it runs at 1800 RPM at all times I’m very happy with this generator can’t wait to get the solar set up so it doesn’t have to run as much. Roger, Can’t wait to see your truck up close. Beautiful. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted January 8, 2019 Report Share Posted January 8, 2019 2 minutes ago, SuiteSuccess said: Roger, Can’t wait to see your truck up close. Beautiful. Thank you. It surprised me as well. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 8, 2019 Report Share Posted January 8, 2019 33 minutes ago, SuiteSuccess said: Roger, Can’t wait to see your truck up close. Beautiful. Carl... Ya gotta remember you can only put so much lipstick on a Freightliner.... 🤣 Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted January 8, 2019 Report Share Posted January 8, 2019 53 minutes ago, Alie&Jim's Carrilite said: Carl... Ya gotta remember you can only put so much lipstick on a Freightliner.... 🤣 But that Freightliner requires a lot less lipstick than a Volvo 😎 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Big5er Posted January 8, 2019 Report Share Posted January 8, 2019 Well, I like my Volvo a lot better than an ugly Freight but I've spent the last 2 days drooling all over Roger's truck. It sure is sweet. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Big5er Posted January 8, 2019 Report Share Posted January 8, 2019 21 hours ago, rdickinson said: So, I'm thinking of mounting it passengers side, fwd of the 100 gallon fuel tank and aft of the regen system. Will it really fit there? I acquired a 7.5 Onan CMQD a while back. I thought the commercial and the regular versions were the same size. Maybe I need to double check the space behind that section of fairing. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 8, 2019 Report Share Posted January 8, 2019 51 minutes ago, GeorgiaHybrid said: But that Freightliner requires a lot less lipstick than a Volvo 😎 All it takes is a thicker coupon book... 💸 40 minutes ago, Big5er said: Will it really fit there? I acquired a 7.5 Onan CMQD a while back. I thought the commercial and the regular versions were the same size. Maybe I need to double check the space behind that section of fairing. He did the back of the truck right... but it still has that Freight hauler badge on the hood.... Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
GlennWest Posted January 8, 2019 Report Share Posted January 8, 2019 1 hour ago, Big5er said: Well, I like my Volvo a lot better than an ugly Freight but I've spent the last 2 days drooling all over Roger's truck. It sure is sweet. I resent that. Lol 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
