Wrknrvr Posted December 29, 2018 Report Share Posted December 29, 2018 I am trying to repair a printed circuit board and I think these are bad. But I cannot figure out what they are. thanks in advance,. Vern Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 29, 2018 Report Share Posted December 29, 2018 I can't see the entire number, but those appear to be 1N628 series transient suppressor diodes. Could be a 1N6283, 1N6285, etc. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Carlos Posted December 29, 2018 Report Share Posted December 29, 2018 Yup, diodes, just get the full part number and google it. Should be cheap and easy to get. And yes, a common failure that I've repaired on generator controllers and heater boards. Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 29, 2018 Author Report Share Posted December 29, 2018 Thanks for the info. I did try to search it but had to many numbers attached. But I did find them with your help. Thank's. Vern Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 29, 2018 Report Share Posted December 29, 2018 Good! I hope they solve the problem for you! Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Carlos Posted December 29, 2018 Report Share Posted December 29, 2018 So what is the board on, and what are the symptoms? If you pull them out, you can very easily test them with a meter. Or even just disconnect one end. In some cases, you can even test them in place, depending on their location in the circuit. If they are on the end of a circuit and there are no more components on one side, you can just test them as they are. Link to comment Share on other sites More sharing options...
Kirk W Posted December 29, 2018 Report Share Posted December 29, 2018 5 hours ago, Wrknrvr said: But I did find them with your help. Thank's. Vern So share a bit more with us when you get the chance. I agree with Dutch that those diodes are a fairly high failure item. Would love to hear "the rest of the story." Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 30, 2018 Author Report Share Posted December 30, 2018 I will say the story is long. Still frustrated with said subject. Will tell the story in a week or two when I get it solved. Bringing beer, . Vern Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 30, 2018 Author Report Share Posted December 30, 2018 I am working on my aquahot that I installed in our fifthwheel. So now this install was done with used parts from my work. I finished it two winters ago and it has worked great. Now that it is not the DW is not happy. I am a Aquahot dealer and did talk to Aquahot tech support for there input. Now what gets confusing is there is a printed circuit board to control all functions of the heating system. Then the printed circuit board controls a control box that operates the diesel burner operation. So they have to work together. So the unit has shut off occasionally in the last couple weeks. Turn it off and on and it will work for a day or two. So I pulled the burner assembly and installed new bearings as they we're noisy. So installed a new fuel filter and nozzle for the yearly service. Now no laffing allowed on this subject. Installed burner unit and it will not ignite. ??? Finally got the fuel lines reversed to the way they were suppose to be. Still not operating. Go to bed and think. Get up in the am and get to look at the system. Pinch pliers and still on the fuel lines. Ok remove them and it still will not operate. No laffing yet. Ok so now check fuel pressure, supply and install another control box. Now apply 12vdc to burner motor ...... Now the burner works. But while trying to get this unit operating the exhaust has lots of diesel fuel in it. Now I can send up smoke signals. I have an exhaust vent up the side of the fifthwheel for a smoke stack. My neighbor came over fast a few days ago as his wife said its burning. So now wait for wind blowing away from the campground so no complaints can be issued. Remember no laffing. At all,. Yet So with different parts from different aquahot units I really do not want to call aquahot yet. Now I was never around anyone working on printed circuit boards, so I have fixed some basic boards with soldering or replacing a few parts. Now Aquahots printed circuit boards are printed on both sides and some trace lines are converd by connection plugs. So sorta difficult for me to trace. I am not good at figuring out what all those extra things are for on the board. Now I have three different control boards. I finally have one the works if I jump two wires together. But those two wires are are power to the thermostat control system and back to the burner control box. Thermostat does not operate system with wires jumped. Well now I have a working control box on a operating burner assembly. Just need to figure out what is wrong with the printed circuit board. Another printed circuit board works the thermostat buts has a low voltage problem.. Now I mite be confused to say the least. I have wanted to learned how to repair printed circuit boards but it is getting frustrating . Now you can laff, Vern Link to comment Share on other sites More sharing options...
Kirk W Posted December 30, 2018 Report Share Posted December 30, 2018 3 hours ago, Wrknrvr said: Now you can laff, As one who retired after 40 years of repairing things for a living, I ain't laffin! Once you find it, given a little time it could be funny but I that is isn't today. 🤯 Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ronbo Posted December 30, 2018 Report Share Posted December 30, 2018 Sometimes we get tired at the end of the day. I was working on my ac system in our S&B. Replaced a relay pack. I had turned off the breaker in the barn and was ready to turn it on. I flipped the breaker but it didn’t work. I did some basic troubleshooting but I was not and tired. Called for an AC technician. He came out and I informed him of what I had done. He said everything looked good and asked where the breaker was. He went to the barn and flipped the breaker. It worked like a champ. Still don’t know which breaker I was flipping. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
sandsys Posted December 31, 2018 Report Share Posted December 31, 2018 My van had a macerator pump that pumped water from the grey tank up over the axel to the dump outlet. That pump stopped working. I took it to Sportsmobile to get it fixed. The guy had quickly removed the driver seat to get good access when the shop manager suggested he test the breaker first. There was no breaker labeled for the macerator. But he did find one that was tripped so he checked that one. Then labeled it for the macerator and everything worked fine. But, he sure was proud of how quickly he removed that seat that didn't need moving at all. Linda Sand Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 31, 2018 Author Report Share Posted December 31, 2018 I may just buy a new board for the unit. But I would like to figure out how fix the board. I do have three used printed circuit boards for it. Just not one of them operated properly. I like a challenge but the DW is getting irritated about this subject. In 6 years I have only sold 1 of these in my repair business. So I could just stock it in my supplies if I get one of the old ones operating. At least I am not bored sitting in the desert while testing things. Safe travels,. Vern Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 31, 2018 Author Report Share Posted December 31, 2018 Ok now is the time to laff. Or get out a bottle of good stuff. so today I was going to really try and see how these printed circuit boards work. Trace what part of the system I think is bad. Study what to do when I start working on it. Now it is snowing out side in Congress Az. But today is a good day to attack this subject. As you can see the pcb I am talking about. It is more than just an igniter board. Now I have installed three different pcb including the one in the picture. I have installed three different control boxes on the burner itself. Still it will not work correctly. Tighten every connection, push pin connectors sorta and just finally frustrated. Pull pcb forwards to test where 12vdc is and is not. Studied where to test on the relays on the board. With printed circuit board pulled forwards off the pins it sits on and darn ------- thing starts working on its own. happy new year everyone,. Vern Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 31, 2018 Author Report Share Posted December 31, 2018 Not gonna touch it a few days if it keeps operating. Now I did try a new wiring harness on the lower right plug connection. It did not help. Last summer I threw out the top right connecting wiring harness. I did keep the terminal end for the board. whisky for now,. Vern Link to comment Share on other sites More sharing options...
sandsys Posted December 31, 2018 Report Share Posted December 31, 2018 2 hours ago, Wrknrvr said: thing starts working on its own. Makes you have trouble deciding whether to cheer or swear, doesn't it? Linda Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Pat & Pete Posted December 31, 2018 Report Share Posted December 31, 2018 2 hours ago, Wrknrvr said: Not gonna touch it a few days if it keeps operating. Now I did try a new wiring harness on the lower right plug connection. It did not help. Last summer I threw out the top right connecting wiring harness. I did keep the terminal end for the board. whisky for now,. Vern From your description , I'd think there's a bad connection , somewhere . Maybe due to corrosion ? Think a bad crimp ... Goes around , comes around . Link to comment Share on other sites More sharing options...
noteven Posted January 1, 2019 Report Share Posted January 1, 2019 There. “Fixed.” If any consolation Vern it was -29C here this morning. Warming up over night tonight. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
sandsys Posted January 1, 2019 Report Share Posted January 1, 2019 5 hours ago, Pat & Pete said: From your description , I'd think there's a bad connection , somewhere . Maybe due to corrosion ? Think a bad crimp ... What is that spray Nick Russell and Greg White are always recommending? Something that improves electrical connectivity. Apparently, my brain has already gone to bed without me. Linda Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Jaydrvr Posted January 1, 2019 Report Share Posted January 1, 2019 8 hours ago, sandsys said: What is that spray Nick Russell and Greg White are always recommending? Something that improves electrical connectivity. Apparently, my brain has already gone to bed without me. Linda Most likely Caig DeOxit.... Jay Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 1, 2019 Report Share Posted January 1, 2019 54 minutes ago, Jaydrvr said: Most likely Caig DeOxit.... Jay That's it . Very good stuff that actually works . Leaves wire and metal as if they were new . Goes around , comes around . Link to comment Share on other sites More sharing options...
sandsys Posted January 1, 2019 Report Share Posted January 1, 2019 6 hours ago, Jaydrvr said: Most likely Caig DeOxit.... Jay Nope. That one is not familiar. Ah, found it. It's Strike Hold. Linda Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 1, 2019 Author Report Share Posted January 1, 2019 So there is probably a bad connection there somewhere. I have not touch the board since it started working. It snowed in Congress Az yesterday and was well below freezing last night. Not to warm up for awhile in Az so will let it be for awhile. The plug connections come from the factory with a pure silicone base sealer and there is no evidence of corrosion at any place. So if it will work for a week or two as is I will let it alone. I will get back with what I do find in the future. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
