Grassy Posted November 26, 2018 Report Share Posted November 26, 2018 Our present sony back up cam that is mounted on the upper back of the cab is just not working. Especially is less than perfect light conditions. I saw a back up cam on a pedestal just ahead of the 5th hitch recently.. the owner wasn't around..didn't see the brand of it. Have done some searching and cannot find. Antone have any recommendations ? Thanks Quote . Arctic Fox 29-5T . Beagle co-pilots - Faffy and Lulu Link to comment Share on other sites More sharing options...
Cotreker Posted March 19, 2019 Report Share Posted March 19, 2019 Check out Rear View Safety, high quality products. I use two camera's and 9" monitor all wired. Camera's are night capable and have speakers. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 19, 2019 Report Share Posted March 19, 2019 I second Rear View Safety. I've used a wide variety of brands over the years. RVS is as good as it gets. We use them exclusively on our truck builds. One thing to note - they use a 5-pin connector, NOT a 4-pin. There are adaptors for both Voyager cables and for the 4-pin. Their monitors and DVR systems are very good. I'll answer any questions you might have if I can. Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Cotreker Posted March 19, 2019 Report Share Posted March 19, 2019 Jack can you please explain how you add more than 3 camera's to this system since the limit is three. I think you do some type of a switch system. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 20, 2019 Report Share Posted March 20, 2019 19 hours ago, Cotreker said: Jack can you please explain how you add more than 3 camera's to this system since the limit is three. I think you do some type of a switch system. RVS and other providers have quad monitors that handle 4 inputs. They also have DVR-based systems that handle 9 or more channels of input and then display those on a monitor, using the DVR remote to switch between views. Let's ignore the DVR system and go back to the quad system. With that, if you wish more than four views you have to use a switch that accepts the additional inputs and outputs onto one of the available channels on the monitor. So you get a 4-way switch and you can send a total of seven images to the monitor - four from the switch and three from the remaining channels on the monitor. Cabcam sells a reasonable switch, as do others. Or you could build your own and support even more channels of input. In the past, I've used Cat 5 cable to run cameras to the switch and switched as many as 6 channels off that. With a rotary switch; all of which I custom built. Just depends on how complicated you want to be. Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Cotreker Posted March 21, 2019 Report Share Posted March 21, 2019 Thanks Jack great details, I will build one. My RVS system has a limit of only 3 camera's a few more should work fine. I will start sourcing some CAT 5 cable. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 21, 2019 Report Share Posted March 21, 2019 16 hours ago, Cotreker said: Thanks Jack great details, I will build one. My RVS system has a limit of only 3 camera's a few more should work fine. I will start sourcing some CAT 5 cable. You don't have to use cat5. Look at security wire. That actually is a little heavier and can be used for multiple things. Or, take the easy route and buy the CabCam switch. Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
jay Posted March 25, 2019 Report Share Posted March 25, 2019 I prefer this one:MC7108,a wireless camera system from haloview. It has high image quality with reasonable price. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted May 18, 2019 Report Share Posted May 18, 2019 We use a system called Cab Cam on our tractors and combine. They work great. They take a ton of abuse. I even have one out on the end of the auger so my wife can see when she loads the trucks. https://www.ebay.com/itm/323762453368 Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
