GlennWest Posted November 24, 2018 Report Share Posted November 24, 2018 My current mini split mount has rubbed on the pavement a couple of times. Not anything damaged but not something I care to have. I was looking under back of Teton and looks like a unit will fit where the spare tire is. Fairly large deep area. Large enough to allow good air flow too I believe. Going to be putting a 36k unit on. Put spare on truck. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
sushidog Posted November 25, 2018 Report Share Posted November 25, 2018 A 3 ton mini-split will freeze you out of there in death valley in the summer. Which model have you chosen? Are you going to use the existing holes from your factory roof mounted ACs for mounting drop-in evaporator cassette ceiling units, or do you plan on using wall mounted interior units? Two zone or three? Sounds like an Interesting project - that should have come from the factory. Much quieter, better cooling, higher efficiency and lower electric consumption. Maybe they'll get the hint one day. Chip Link to comment Share on other sites More sharing options...
GlennWest Posted November 25, 2018 Author Report Share Posted November 25, 2018 Pioneer. Two cassettes in roof. Same location of factory acs. 18k cassettes. Factory was 30k. Not that much more really. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted November 25, 2018 Author Report Share Posted November 25, 2018 The only issue I might have is service. Most residential seviced personal are accustomed to units on ground, easy to get to. Would have to get under the Teton and sit on butt to work on it. We are at their mercy since we can't buy the gas. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Daveh Posted November 25, 2018 Report Share Posted November 25, 2018 3 hours ago, GlennWest said: The only issue I might have is service. Most residential seviced personal are accustomed to units on ground, easy to get to. Would have to get under the Teton and sit on butt to work on it. We are at their mercy since we can't buy the gas. I didn't know this about not being able to buy the gas. Shoot. I wanted to DIY this. Dave and Lana Hasper Link to comment Share on other sites More sharing options...
GlennWest Posted November 25, 2018 Author Report Share Posted November 25, 2018 Yes, one has to have a license to buy it. Now if you know someone???? I have a vacuum pump, gauges, know how. Just no license. If you can keep the lines within the pre charged gas amount, all you have to do is pull a vacuum. It would be advisable to pressurize with nitrogen first to check for leaks. Much better test than vacuum. My bedroom unit will need extra. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Daveh Posted November 25, 2018 Report Share Posted November 25, 2018 No I don't. I know they sell the precharged mini split units but that is a one-time thing and like you said---maintenance. Dave and Lana Hasper Link to comment Share on other sites More sharing options...
GlennWest Posted November 25, 2018 Author Report Share Posted November 25, 2018 I did some searching today and R 410a can be purchased on ebay. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Daveh Posted November 25, 2018 Report Share Posted November 25, 2018 I was wondering Glenn as there are some you tube videos of guys charging these things DIY> Good to know. Keep us updated on your system. Watching carefully. Dave and Lana Hasper Link to comment Share on other sites More sharing options...
GlennWest Posted November 25, 2018 Author Report Share Posted November 25, 2018 yes, their is. Just goggle mini split in rv and you will find several 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
