Seeria Posted November 23, 2018 Report Share Posted November 23, 2018 Hello everyone I picked up a Wave, brand new, but seems to be having problems igniting the entire pad. After running it for 30 minutes, six times now, it will only light a small area on the bottom which results in next to no heat output even when on high. I've looked over instructions, done videos, but can't find anything on why a brand new pad won't light. I've heard nothing back from Amazon where I purchased the item. Any ideas? Suggestions? Kind regards ~Laughter is as essential as the air we breathe~ Link to comment Share on other sites More sharing options...
Fhkw9DPJ8V1g Posted November 23, 2018 Report Share Posted November 23, 2018 Is the pressure from your gas line properly regulated? Are you using a connection that was used previously for a different appliance with no problems? Gas flow is the first thing that comes to mind for me. Link to comment Share on other sites More sharing options...
Seeria Posted November 24, 2018 Author Report Share Posted November 24, 2018 Thanks I bought the Camco hose and pressure regulator they recommend, sooo guessing it is the right one? All parts are new minus the 20lb tank, which is a couple years old. Camco Low Pressure Gas Regulator with 12' Hose 7000 BTUs/Hr Simple and Quick Install - Use with Low Pressure Gas Fired Heaters (57721) This hose https://www.amazon.com/gp/product/B002UC8MJW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 Also picked up the Camco 57633 90° Elbow Connector for Olympian Wave Heaters but haven't attached it yet. This is a Wave 3 btw. Kind regards ~Laughter is as essential as the air we breathe~ Link to comment Share on other sites More sharing options...
Al F Posted November 24, 2018 Report Share Posted November 24, 2018 Should be under warranty, give Olympian support a call. Phone # should be in your owners manual. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
hiljoball Posted November 24, 2018 Report Share Posted November 24, 2018 Sounds like a gas flow problem. It could be the flow control valve on the tank. Try the regulator on another tank. Also, with the regulator in place, try closing the valve on the tank, then open it slowly, and then try turning on the heater.. The regulator may not be engaging with the tank flow control valve. Could be the regulator - can you find another one to try. John JohnTitanium 29EX 29/34 Fifthwheel Link to comment Share on other sites More sharing options...
Sehc Posted November 25, 2018 Report Share Posted November 25, 2018 Does the Olympian require full gas pressure? I had a different brand that did not work with a pressure regulator at the bottle. It had a built-in pressure regulator. Link to comment Share on other sites More sharing options...
Al F Posted November 25, 2018 Report Share Posted November 25, 2018 16 minutes ago, Sehc said: Does the Olympian require full gas pressure? I had a different brand that did not work with a pressure regulator at the bottle. It had a built-in pressure regulator. The Olympian only works off of low pressure propane. You must have a regulator between the propane bottle/tank and the heater. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Sehc Posted November 26, 2018 Report Share Posted November 26, 2018 Thanks. Yes I found the information. They use reduction to 11 inch water column. Link to comment Share on other sites More sharing options...
Al F Posted November 26, 2018 Report Share Posted November 26, 2018 That also works out to be 1/2 PSI (Pounds Sq Inch). Very, very low pressure, especially compared to the pressure in your motorhome or tow vehicle engine fuel line. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Sehc Posted November 26, 2018 Report Share Posted November 26, 2018 Different fuels. Link to comment Share on other sites More sharing options...
