LindaH Posted November 18, 2018 Report Share Posted November 18, 2018 Worked just fine yesterday, but today on many (not all) of the HD channels I get the message, "Signal lost on HD channel, switching, tuning to SD equivalent." All of the Local channels (out of Tucson) come in on HD just fine and a handful of other channels that I've checked come in on HD. But others (like 190 and 184, for example...but there are others) show signal loss on the HD channel. Could this be a problem with Dish? Or perhaps the equipment (Winegard Trav'ler and VIP 612 DVR receiver)? If it's the equipment, we're headed to Quartzsite and we'll have Satellite Advantage take a look at it. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
Dutch_12078 Posted November 18, 2018 Report Share Posted November 18, 2018 Check your diagnostics to see what signal level you're getting on the 129 sat compared to the others. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
LindaH Posted November 18, 2018 Author Report Share Posted November 18, 2018 "Diagnostics" doesn't give me any information on signal strength. However, if I go to "System Info," both 110 & 119 light up green, but 129 turns red with a big "X." So I'm assuming this means that the 129 is out on the Trav'ler. If that's the case, we'll check with Satellite Advantage to see if they can order a new LNB for us. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
LindaH Posted November 18, 2018 Author Report Share Posted November 18, 2018 Well, the problem seems to have cured itself. This morning, we'd put the antenna down so we could go drain tanks and get propane. When we came back, I put the antenna up and all 3 satellites had an asterisk by them. DH said why not put the antenna down and raise it again? So I did. This time when I did the same test as above, all 3 satellites turned green and I can now get the HD channels! Fingers crossed, it won't give us further problems. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
Dutch_12078 Posted November 18, 2018 Report Share Posted November 18, 2018 Ok, I wish you well with it, Linda! Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
LindaH Posted November 18, 2018 Author Report Share Posted November 18, 2018 Thanks, Dutch. I'm keeping my fingers crossed! LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted November 18, 2018 Report Share Posted November 18, 2018 We have had wind tweak the dish just enough to lose HD as you did. Did the shutdown/lower and raised it back up. Success! This is with a Winegard Traveler 1000. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
rogerhardy Posted December 21, 2018 Report Share Posted December 21, 2018 I had the same issue last summer. After spending hours on the phone with Winegard and Dish, I discovered I had a couple loose cables. I tightened the cables into the receiver and the wall (about a quarter turn loose) and problem was solved. Link to comment Share on other sites More sharing options...
LindaH Posted December 22, 2018 Author Report Share Posted December 22, 2018 We haven't had any further problems since my 11/17 post. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 22, 2018 Report Share Posted December 22, 2018 Glad to see it's still working ok, Linda! Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
