Verizon Unlimited Data Plan for Jetpacks
3 hours ago, Second Chance said:
I just logged on to my on-line account and I was off by $11, so I stand corrected - sorry about that. It's $105 for the two smartphones (3GB/month each) and the MiFi (unliminted data). All three lines are on the same prepaid plan with auto-pay, multi-line, and military discounts.
Rob
Wow, that is a good deal!  Thanks!
  • Replies 250
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  The jetpack showed up this afternoon and in a short time I was again online with Verizon.
  With the thing sitting right here on the desk it reported -112dB. Fairly usable but pretty slow, definitely slower than the Pepwave BR-1 w/BoatANT. I anticipated this so got an antenna-connector adapter and connected it to the BoatANT. Signal strength popped up to -103dB and it got way faster. Multiple Speedtest runs varied between 1Mbps to 4Mbps. It's definitely faster than the Pepwave in this location.
  When the other antenna adaptor shows up I'll plug in the other BoatANT. I expect that to help at least a little.
  Two BoatANTs? They cover 700mHz to 2.5gHz; one was used for cell and the other for wifi. Wifi performance was phenomenal for an omni antenna but it's not needed for that anymore.
  BTW, the phones don't work here at all for voice or data.
Edited by jbh
-C&J-
CG reviews & more - www.fugawetribe.com
On 11/24/2018 at 8:57 AM, edatlanta said:
I have 1 smartphone and 2 7730L jetpacks.  My smartphone has a unlimited data, but 15gb limit as a hotspot.  My 2 jetpacks have the 15gb limit also, but I pay $20.00 each/month for them.
I am interested in the prepaid jetpack program, but for two concerns:
1.  Both of my Jetpacks have static IP's which I need and wonder if prepaid will allow this and if the static IP's will migrate to the new plan.  I have already paid for the static IP's on these two devices and don't want to have to do it again.  If you walk into a Verizon store and even utter the words "static IP's" they look at you like you have 2 heads.
2.  The cost.  I don't see from the info at Verizon.com anyway other than each prepaid plan will cost me an additional $45.00/month - $65.00-$20.00.  Would it be worth it to me to have a jetpack with unlimited data when I have unlimited data on my smartphone that I connect to my TV (Samsung Smart View) and can and do stream a lot?
I went to a corporate Verizon store yesterday and got an answer to my questions.
The static IP will have to go away with the prepaid plan.  Since I can't live with that my options for the current prepaid jetpack plan is off the table.  They did say that if the IP issue wasn't an issue I would have to have a separate account for the prepaid jetpack.  It can't be on the same account as an unlimited postpaid smartphone.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch
2010 Jayco Designer 35RLTS, RV Flex Armor Roof
That is what we have.  I can check both accounts online.
Sandie & Joel
WiFiRanger Ambassador
X2
2014 smart Fortwo
13 hours ago, Dutch_12078 said:
Would one of the dynamic IP services work for your application?
https://dyn.com/dynamic-dns/
https://www.noip.com/remote-access
Don't know at this point.  I will definitely take a look.  Thanks.
Ed
KM4STL
40 minutes ago, jbh said:
  Will it harm the jetpack battery to always have it plugged in? Or is it "smart?"
Which model jetpack? Some of the older ones are known to have "swelling" battery issues if left plugged in all the time. Some of the later ones they are making them where you can remove the battery and plug them in and they work fine thus not having to worry about over charging the battery or anything.
The 7730l doesn't like being plugged in continuously.  But it only cost me ~$20 to buy a replacement battery on Amazon.  I'll probably put it on a timer so it gets charged for a number of hours then have the timer turn off.
Sandie & Joel
  This is the newest 8800L. It's plugged into a low-power 12v-5v USB source, which it did correctly identify, rather than the high-power wallwart that comes with it. I felt the thing and it's hardly even warm, certainly not overheating the battery, so I suspect it's ok. I need to run it on the 12v source.
-C&J-
I just purchased a ~$12 "smart outlet" on Amazon.  It's designed to turn things on and off and doesn't even need a "hub" in order to operate.  Instead of tethering the 7730l to my WiFiRanger I'll use a wallwart plugged into it.  All I need to do is figure out how many hours it needs to be charged and how often.
Sandie & Joel
Might I ask where you obtained the USB cable for it?  Accessory spec'd for it from VZW or simply a standard (with appropriate current rating) USB cable?
Thanks!
Thanks!
Most new devices are coming with a USB-C cable and I looked at the specs and that appears what the 8800L uses. - https://www.verizonwireless.com/internet-devices/verizon-jetpack-mifi-8800l/
"The MiFi 8800L lets you connect with up to 15 trusted devices at a time. You can even share files over your local Wi-Fi connection by using a storage device with a USB-C connector."
So basically any USB-C cable will work fine. Something like this. - https://www.amazon.com/dp/B07CZTZLB8/ref=twister_B07KJXWCQQ?_encoding=UTF8&psc=1
Edited by BlueLghtning
The 8800L comes with a USB cable, I just plugged it into an ordinary 12v-5v USB adaptor rather than the AC wallwart.
  BTW, it's the same temperature to my hand  when it's not plugged in  as when it's plugged in to low power. The only time it got warmer was when the cat sat on it.
-C&J-
 I want to Thank all of you for sharing this information on the unlimited plan and the 8800l jetpack. I got one today at a local store and it took a while to convince them that this plan was in effect. I had to come to this forum and get the plan number so they could find it. Thanks for posting the plan number or it would not have happened.
Thanks,
Ken....
2017 DRV Fullhouse JX450
2020 Volvo VNR 42-640, D13, 455hp, Ishift, 189"wb, factory single, ET Junior Hitch @ 195", Jacklopee, Directlink
2016 GMC 3500 Denali DRW, CC, LB, Curt 25k, Sold
I took the plunge and ordered another Jetpack and plan on keeping my existing 2 7730's and see how the new one does before I give up one.  Neither is on contract so I can drop one of them easily.  I did decide to get the unlimited/prepaid with their new 8800L and wow what a difference in d/l and u/l speed.  I know this isn't a scientific test, but with the two 7730's sitting right by the 8800 the d/l speed of the 8800 is 40-50% faster and has been every time I tested them.
Now time will tell how it all goes.  I did watch a couple of movies last night with the new 8800L and zero buffering.  We will see over coming days.  I plan to work it hard initially.
How are you able to monitor the usage of your new prepaid unit?  It doesn't show up on the verizon app that I have I guess since the new one is on another account.  I know I can look at the 8800 when I sign on to it at 192.168.1.1, but that only shows zero usage with a 10gig plan.  I'm not sure that that means, but zero usage obviously won't ever get to any upper limit.
Ed
KM4STL
I don't have a Verizon Jetpack, and would like to order the 8800 along with the Prepaid Unlimited Data Plan.  Online you appear to be limited to either an MHS900L or a 7730L with the prepaid plan.
Has anyone figured out how to directly online order the 8800 along with the new plan?
Mark & Teri
Mark & Teri's Travels
  I connected the other BoatANT and got a surprise.
  With one antenna the fastest I could consistently get was 4 Mbps; now it's 20 Mbps!
  Unfortunately tower overload kills the speed from late afternoon through the evening; everyone gets home and cranks up their devices.
-C&J-
My WiFiRanger keeps track of usage by each device on my network.
Sandie & Joel
I'm also seeing periods of slow service for brief periods of time in the afternoon and evening.  The last time it happened I switched to my AT&T hotspot for a while.  The next time I notice it I'll try to remember to see if my post-paid phone is suffering anything similar.
Verizon's website seems to say that pre-paid plans are lower in the prioritization scheme than post-paid ones, which would result in them being slowed more than postpaid during times of network or tower congestion.  When I use Fast.com to speedtest I notice that it takes quite a bit longer and "jumps around" a lot before reaching a "decision" as to what the speed is.  I'm wondering if the speed is more erratic because it's being throttled a bit?
Sandie & Joel
