Brad & Jacolyn Posted October 31, 2018 Report Share Posted October 31, 2018 I remember reading here recently that someone had a cooling fan starting to make noise on their smart. Thanks for posting that because as soon as I read that mine starting making that noise. Now I knew what it was right away because I had it changed out 4 years ago and it cost $800 back then. Afraid to know what is would cost now. So after looking over a couple of smart car forums I ran across the same problem. There were pictures and his solution was to put a pusher fan on the front of the radiator (it has been working since 2012). So after messaging the man and asking a couple questions I found the same fan he used (at O'riellys). He absolutely assured me that unless you want to bleed and swear ALOT you need to pull the front clip (he said it is actually not a bad job to do). Checked on Evilution and FQ101 forums and found disassembly directions. After comparing them I determined that other than a couple of steps in a different order it covered the same stuff. So I printed the directions and yesterday I tore into it and guess what? Removing the front clip is actually easy. Just should have 2 people for lifting it off (not heavy just protecting paint). I stopped for lunch plus I was doing it in a campground so all these 'the helpers' slowed things down (but we were all entertained). Anyway, the job was completed in 5 1/2 hours (figuring out fan mounts was time consuming) and everything is all right with the world again. Won't let me add pictures. But I'll keep trying. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Big5er Posted October 31, 2018 Report Share Posted October 31, 2018 Sweet!...if mine goes out again I will be calling you. I'll chat with your lovely bride while you work 😋 MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted October 31, 2018 Author Report Share Posted October 31, 2018 Kinda backwards but we have after and then before the fan. Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
sclord2002 Posted October 31, 2018 Report Share Posted October 31, 2018 I did the same thing on my Smart after the stock fan quit working. The new pusher fan would not work untill the latched fault for a shorted cooling fan was reset. All is well now. A/C works great in summer heat at idle and no overheat in heavy traffic. The front clip is not nearly so intimidating after removing and replacing it with my wifes help. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 31, 2018 Report Share Posted October 31, 2018 Since ya'll are so experienced in removing the front clip, how about doing ours and mounting the tow bar base plate? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 1, 2018 Report Share Posted November 1, 2018 Jim, sent you a text 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted November 1, 2018 Author Report Share Posted November 1, 2018 Jim front clip removal is 40 minutes if you have never done it. Print directions off Evilution or I can try to send them to you. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted November 1, 2018 Report Share Posted November 1, 2018 4 hours ago, Brad & Jacolyn said: Jim front clip removal is 40 minutes if you have never done it. Print directions off Evilution or I can try to send them to you. Brad I don't know Brad.... My arm is still pretty bad from that dryer... I might need help on this..... 😉 Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted November 2, 2018 Author Report Share Posted November 2, 2018 I'm in Texas c'mon over. You just want to try and get me to bleed on some project of yours this time. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
HERO Maker Posted December 11, 2018 Report Share Posted December 11, 2018 So, what was the cost of the fan? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
GlennWest Posted December 11, 2018 Report Share Posted December 11, 2018 Did it help the AC out in stop and go traffic? In summer, mine can get uncomfortable in town. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
adept99 Posted December 11, 2018 Report Share Posted December 11, 2018 And jus where were all you shade tree mechanics when our fan gave up? Yeah, so we got the $800 version just like Brad & Jacolyn's first attempt. BTW - We're gonna be in TX for a couple of months after the 1st of the year, Galveston and San Antonio. Starting to stockpile DR Pepper now in hopes of having enough to kinda slip through Baytown without too much ugliness. Paul & Paula + Daisy the amazing wiggle worm dog... 2001 Volvo 770 Autoshift, Singled, w/ Aluminum Bed - Toy Draggin 2013 395AMP XLR Thunderbolt Toy Hauler 2013 Smart Passion 2012 CanAm Spyder RT 2013 Harley Davidson Street Glide Link to comment Share on other sites More sharing options...
HERO Maker Posted December 11, 2018 Report Share Posted December 11, 2018 Well, at 1st, Dallas MB was going to have to order the part, but they found it in the shop. They dropped me off for lunch and it will be done in a couple of hours. $634 total. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
sclord2002 Posted December 11, 2018 Report Share Posted December 11, 2018 Glen, my new pusher fan lets the a/c cool well in stop and go traffic........maybe slightly less cool air than on the open road, but comfortable. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
GlennWest Posted December 11, 2018 Report Share Posted December 11, 2018 so it is better with your new fan 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
