alan0043 Posted October 22, 2018 Report Share Posted October 22, 2018 Hi Everyone, How do you winterize a residential frig with an ice maker ? The frig in question is an Insignia 20.7 cu. ft. model # NS-RFD 21 SS7 . The frig has no water filter. Thank you for any help, Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Lance A Lott Posted October 22, 2018 Report Share Posted October 22, 2018 Turn the water of and disconnect the pipe, start the ice making cycle and then pressurize the waterline with air. That should push most of the water out. Quote Link to comment Share on other sites More sharing options...
orca Posted October 22, 2018 Report Share Posted October 22, 2018 I would still use rv antifreeze with the air blowout. On my fridge i could not activate the icemaker without tapeing the fridge light "off" and using a jumper wire to run the icemaker till antifreeze came out. Quote 2004 Freightliner m2 106 2015 DRV lx450 Fullhouse 2019 Indian Springfield 2014 Yamaha 950 V-Star Link to comment Share on other sites More sharing options...
Kirk W Posted October 22, 2018 Report Share Posted October 22, 2018 The other parts of the refrigerator just need to be emptied and the unit off, leaving the doors propped open partially for ventilation. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
lenp Posted October 23, 2018 Report Share Posted October 23, 2018 I simply connect the input (suction) side of the pump into a jug of RV antifreeze, turn on the pump and ice maker and let it sit until I see pink ice (slush). I have to do the same for the washer/dryer until I see pink water in the machine. Of course, the water heater is in bypass mode. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Anthony Posted September 21, 2019 Report Share Posted September 21, 2019 Hi Al, just wondering how you made out winterizing your Insignia fridge? i have the same model, the manual offers no helpful information.... Thank you, Anthony Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted September 21, 2019 Report Share Posted September 21, 2019 (edited) On 10/22/2018 at 10:00 AM, orca said: I would still use rv antifreeze with the air blowout. On my fridge i could not activate the icemaker without tapeing the fridge light "off" and using a jumper wire to run the icemaker till antifreeze came out. One must exercise care when using the jumper to induce the ice maker to operate, more than 15-16 seconds may burn out the heater element in the ice maker tray. Edited September 21, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
alan0043 Posted September 22, 2019 Author Report Share Posted September 22, 2019 17 hours ago, Anthony said: Hi Al, just wondering how you made out winterizing your Insignia fridge? i have the same model, the manual offers no helpful information.... Thank you, Anthony Hi Anthony, The winterizing worked out ok. I don't use the ice maker. My water line going to the frig is shut off under the sink in my trailer. The folks here on the forum will give you good advice. Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
