ANG0225 Posted October 21, 2018 Report Share Posted October 21, 2018 Hi All, I am wanting to install something like what is in the picture on my holding tank on my 2012 Chaparral by Coachmen. Any help on how to get access to the holding tank? Link to comment Share on other sites More sharing options...
Kirk W Posted October 21, 2018 Report Share Posted October 21, 2018 You may be looking for a tank heating pad such as this? They come in both 12V and 120V versions and can be found on Amazon. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
FL-JOE Posted October 22, 2018 Report Share Posted October 22, 2018 I doubt on a fiver you will be able to get to it through lower storage, but check that first. Black tank should be located directly below toilet drop. In all likelihood you will have to cut out opening in flexible material under RV. Also, in most of the fivers I have owned if it gets too cold the gate valves can be problematic and possibly freeze. There is nothing worse than to have your black tank full and no way to dump it. When the temps were heading toward the 20's we would start dumping pink antifreeze in the toilet to flush instead of a lot of water. It seemed that temps in the high 20's and above it wasn't a problem. Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
Kirk W Posted October 22, 2018 Report Share Posted October 22, 2018 7 minutes ago, FL-JOE said: Also, in most of the fivers I have owned if it gets too cold the gate valves can be problematic and possibly freeze. There are heaters for that purpose as well. UltraHeat - RV Gate Valve Heater , Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
