Arizona Drifter Posted October 12, 2018 Report Share Posted October 12, 2018 My front ac and my bedroom tv run on shore power but do not run when the generator is on. This is a recent happening. What should I be looking for? I have a 2013 class a. Also my generator doesn’t seem to charge up the house batteries. Link to comment Share on other sites More sharing options...
Kirk W Posted October 12, 2018 Report Share Posted October 12, 2018 Check to be sure all of your circuit breakers are closed properly by opening each one and closing it again. Pay particular attention tothose on the generator set. It sounds like you have a 50a RV and one phase is not getting power. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 12, 2018 Report Share Posted October 12, 2018 Just a quick thought. Your auto transfer switch probably has one 110 volt wire burned at the connection. Or something in that area to cause that problem Now it could be something else. But that is where I would start. If you get near that switch it may smell like burnt wiring. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
oldjohnt Posted October 12, 2018 Report Share Posted October 12, 2018 Good question Drifter. FWIW I'm pretty much in agreement with the above. My first question is what is your transfer method ??? I assume an auto transfer switch but have seen manual systems. If she works on shore power but once the genny runs certain electrical appliances DO NOT, one (among several) possibilities is a transfer switch problem and I would look there for burned or loose or disconnected wires. Of course, any fuses or breakers need to be checked. When my genny powers up there's a delay after which the transfer switch engages and it makes an audible sound when that happens. Take a good look n listen at your switch when the genny starts up, it needs to toggle (shore power to genset) to operate. I have also seen RV gensets with onboard breakers tripped which, of course, makes them inoperative to power the RV even though running fine. NOW WOULDNT THAT BE A SIMPLE FIX !!!!!!!!!!!!!!! Your house battery charger/converter likely only operates on ONE 120 VAC leg (assuming a 50 amp RV) of your system, so if the Genset only powers one leg (no idea from here how YOUR RV operates) and that's the leg the Converter/Charger is connected to, SEE ALL THAT ABOVE AND BELOW. Your Genset may be configured and wired to serve BOTH legs of 120 VAC, I just cant say from here. Check breakers on the Genset itself or close by including the panel and elsewhere, check the transfer switch for burned or loose or missing/disconnected wires and/or burned electrical odor, take two aspirins and call me at the office lol John T Link to comment Share on other sites More sharing options...
Arizona Drifter Posted October 16, 2018 Author Report Share Posted October 16, 2018 Thanks for the replies. It was one of the generator circuit breakers. Link to comment Share on other sites More sharing options...
oldjohnt Posted October 16, 2018 Report Share Posted October 16, 2018 "I have also seen RV gensets with onboard breakers tripped which, of course, makes them inoperative to power the RV even though running fine. NOW WOULDNT THAT BE A SIMPLE FIX !!!!!!!!!!!!!!! " CONGRATULATIONS Thanks for the feedback, a nice "simple fix" is always great to come across. John T Link to comment Share on other sites More sharing options...
Kirk W Posted October 17, 2018 Report Share Posted October 17, 2018 3 hours ago, Arizona Drifter said: It was one of the generator circuit breakers. The key was that part of the circuits worked and part did not. That lead to the suspicion that one phase was open as your distribution box has two separate supplies, one from L1 and the other from L2. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 17, 2018 Report Share Posted October 17, 2018 Cross Posted somehow? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
chirakawa Posted October 17, 2018 Report Share Posted October 17, 2018 A butterfly is an insect with brightly colored wings. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
RV_ Posted October 17, 2018 Report Share Posted October 17, 2018 RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
