Cotreker Posted September 25, 2018 Report Share Posted September 25, 2018 On a number of recent trips my dash will flash "ECM Requires Maintenance". This summer I replaced the batteries and of course this message came up, false alarm. However the truck has not been start very well this summer on 2nd or even 3rd crank. I use the truck about every 2 weeks and keep the new batteries on a trickle charger. Have cleaned wires at batteries and checked for any loose connections, even use dia-electric greese. Any starting tips I should be doing, key on for 20 seconds, they chank. Hit fuel pedal or not.?? ?Is there an issue with my ECM that only Volvo can address? Dennis 2006 Volvo VNL 670 New oil and fuel filters Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
DesertMiner Posted September 25, 2018 Report Share Posted September 25, 2018 Did you check your ECM power fuses at the battery while you were “cleaning things up”? There are usually 2 or 3 fuse holders that supply battery power to your various computers. Those fuse holders can get mighty dirty! Sometimes it’s just time to replace the fuses with new ones due to all of the vibration. Good idea to add this to your regular maintenance checklist. Link to comment Share on other sites More sharing options...
Cotreker Posted September 25, 2018 Author Report Share Posted September 25, 2018 No fuses are located directly on battery. I will look futher up the cables. Any other suggestions as where to look for these fuses? Boy did I make typos in my above questions Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Parrformance Posted September 25, 2018 Report Share Posted September 25, 2018 There are some large fuses under the fuse panel in the center of the dash in the Volvo. 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Big5er Posted September 25, 2018 Report Share Posted September 25, 2018 8 hours ago, Cotreker said: No fuses are located directly on battery. I will look futher up the cables. Any other suggestions as where to look for these fuses? Mine is just one year older than yours and I have inline fuses on all of the smaller wires that connect to the batteries. Could someone have put a fuse block in and removed them? Try following those smaller wires for a bit. EDIT: Although I suppose the difference could be engine type? What engine do you have? MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Cotreker Posted September 26, 2018 Author Report Share Posted September 26, 2018 Volvo D12 engine Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Big5er Posted September 26, 2018 Report Share Posted September 26, 2018 Same engine I have...hmm. Where did your fuses go? MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
noteven Posted September 26, 2018 Report Share Posted September 26, 2018 My guess: a bad ground will be found... poetry. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Cotreker Posted September 27, 2018 Author Report Share Posted September 27, 2018 Ok found the fuse in plain sight, where is the ground? I really want to fix this issue. Thanks All, Dennis Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Cotreker Posted September 28, 2018 Author Report Share Posted September 28, 2018 Checked fuse ok, cleaned terminals added more dialectic greese and tightened all posts. Still started after three attempts. Last run just 4 days prior to this, no battery charger connected so I could read true voltage of all 4 batteries. 12.72 volts as expected. At a loss to why truck will not start on first attempt or second. On rare occasions it will. Do I live with this or let Volvo take a look? Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Parrformance Posted September 28, 2018 Report Share Posted September 28, 2018 Fix it, before it get's more serious. These symptoms are just a warning of something failing. Did all of this begin when the batteries were replaced, or before hand? 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
noteven Posted September 28, 2018 Report Share Posted September 28, 2018 Cotreker - I’m not a Volvo-familiar person - but - are you saying this condition is new? In other words the engine could sit for weeks and start instantly vs now it wants to be turned over for some time? As in enough time that the voltage drop on the batteries is causing the ecm to whine about voltage? What happens when you begins with fully tendered batteries and cold engine when you crank one time until it starts? Don’t go over 30-45seconds depending on ambient temp and overheat the starter... it reads like you are cranking in short goes.... Modern engines goes through some “boot up” sequences before fuel is injected - depending on outside temperature etc "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 29, 2018 Report Share Posted September 29, 2018 If the engine is turning over at a normal cranking speed, then you may have a fuel issue. I'm wondering if the fuel tail is draining and having to reprime. Have you had a fuel filter change recently? There is a check valve in the system that goes bad and allows the system to lose pressure. Maybe others will chime in about the fuel side. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
DesertMiner Posted September 29, 2018 Report Share Posted September 29, 2018 Use your manual primer pump before you try starting it next time....that may help to see if it’s a fuel related problem. Link to comment Share on other sites More sharing options...
Cotreker Posted September 30, 2018 Author Report Share Posted September 30, 2018 Has been happening even prior to the new batteries. I just hit the fuel primer this morning, temp outside is 47 degrees. Started on the secend long start about 20 seconds. Could this be a sensor? Maybe weak cam sensor? Truck has been plugged into a battery trickle charger batteries new this summer all 4. Oil and fuel filter change begining of the summer. Please give me more ideas of what to check. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
DesertMiner Posted September 30, 2018 Report Share Posted September 30, 2018 How many pumps did it take to prime the fuel system? Did you ever check to see what fault codes you might have? Did this problem just happen one day or over a period of time? Link to comment Share on other sites More sharing options...
noteven Posted September 30, 2018 Report Share Posted September 30, 2018 Sounds like air where fuel should be... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Cotreker Posted September 30, 2018 Author Report Share Posted September 30, 2018 This problem has been around for awhile, rarley has the truck started off on first chank, but it did in the past. This problem appears to be getting worse, can not have this issue go into the winter months. As for the pump, this is the first time I have ever used it, after a few strokes fuel came out the overflow area next to the pump. What should I look for when pumping and how many strokes? I do not own a code reader, how much are they and where to buy. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
DesertMiner Posted September 30, 2018 Report Share Posted September 30, 2018 You have a diagnostic area in the “drivers information display” (DID) right there on your dash. You should be able to pull up the fault codes under the “diagnostics” page. Write down all of the codes. Might help with some troubleshooting.... Link to comment Share on other sites More sharing options...
Cotreker Posted October 1, 2018 Author Report Share Posted October 1, 2018 Ok, I read my book and then saw the youTube. I have codes to read but not sure which to address. Should I reset my codes to clean out the old codes and then see what come up fresh? A few interesting codes: 1. Fuel Feed Pressure - Mechanical fault - Inactive # of events 2 MID 128 PID 94 FMI 7 #2 Injector #6 6 Events did not write down additional details #3 SAE J1939 Data Link Data Erratic # of events 4 #4 Component Failure (so does the MID, PID, FMI explain the failures?) # of events 3 This morning I primed my fuel system with about 7 strokes. Started after 2 attempts 20 seconds hitting the key. So 6 hours later the truck started right away (BIG SMILE) to read codes. I shut down the engine and attempted to start it again and it fired right up. Normally it hard starts when it is warm, weird. Did priming the fuel system appear fix things? I will do a test start Monday or Tuesday. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 1, 2018 Report Share Posted October 1, 2018 Your system is losing prime. Now the hard part begins. What connection or check valve or injector is remaining open (partially)? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Cotreker Posted October 2, 2018 Author Report Share Posted October 2, 2018 Checked fuse ok, cleaned terminals added more dialectic greese and tightened all posts. Still started after three attempts. Last run just 4 days prior to this, no battery charger connected so I could read true voltage of all 4 batteries. 12.72 volts as expected. At a loss to why truck will not start on first attempt or second. On rare occasions it will. Do I live with this or let Volvo take a look? Ready for some tips where to look for leaks? Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Cotreker Posted October 2, 2018 Author Report Share Posted October 2, 2018 Where should i look for leaks? Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
DesertMiner Posted October 2, 2018 Report Share Posted October 2, 2018 I would clear all the codes before starting it again and see what you get. You may have a small leak on the injector that was mentioned in the fault codes. Priming usually takes more than 7 strokes if you had an air leak and I’m wondering if you should see fuel coming out of the primer. Primers have known to leak and caused hard starting. Just a thought. Usually an air leak in your fuel line doesn’t trigger an “ECM” code unless the leak is causing another issue that the ECM would care about. Link to comment Share on other sites More sharing options...
Cotreker Posted October 4, 2018 Author Report Share Posted October 4, 2018 Thank you Desert Miner I plan to do your recommendations in the very near future. Can cleaning the injectors by treating the fuel make them stop leaking? Products such as Amsoil or BG. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
