Broncohauler Posted September 22, 2018 Report Share Posted September 22, 2018 Looking for a Teflon pad for my Trailer Saver hitch. I know it needs a smaller size to still lock in the pin. Dose anyone know what size, or best place to get it? thanks guys Link to comment Share on other sites More sharing options...
TXiceman Posted September 22, 2018 Report Share Posted September 22, 2018 Diameter does not matter much. The problem is thicker ones may or may not work. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Broncohauler Posted September 22, 2018 Author Report Share Posted September 22, 2018 Thickness is what I meant to say I know some people found out the hard way about getting the correct size. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted September 22, 2018 Report Share Posted September 22, 2018 Are they teflon? I thought the material was UHMW polyethylene. I would like to know a source as well. Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
DesertMiner Posted September 22, 2018 Report Share Posted September 22, 2018 http://www.hensleymfg.com/product-category/trailersaver-parts/ Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 22, 2018 Report Share Posted September 22, 2018 Any RV parts source. Just get the thinner of the 2 flavours they have. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Big5er Posted September 22, 2018 Report Share Posted September 22, 2018 https://www.etrailer.com/dept-pg-Accessories_and_Parts-pt-Lube_Plate.aspx read the specs on each one to see the thickness. Most seem to be 3/16" but there are some 1/8" thick ones MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Hot Rod Posted September 23, 2018 Report Share Posted September 23, 2018 I never had a problem with the standard ones, always work fine on my older trailersaver. BUT others have reported issues and need the thin one. Link to comment Share on other sites More sharing options...
SWharton Posted September 23, 2018 Report Share Posted September 23, 2018 Amazon has the 3/16 one. Link to comment Share on other sites More sharing options...
Big5er Posted September 23, 2018 Report Share Posted September 23, 2018 Here is an 1/8" one on Amazon MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
GlennWest Posted September 23, 2018 Report Share Posted September 23, 2018 Just ordered that one from Etrailer along with some trim 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 23, 2018 Report Share Posted September 23, 2018 The replacement hitch I put on Red Rover had no clearance for a pad, even a 1/8" one. I wound up using a spray dry lubricant. Not as pretty but it worked. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
GlennWest Posted September 23, 2018 Report Share Posted September 23, 2018 Don't really know if it will work on my Et Hitch. But will find out. The 3/16" was so tight, it was hard to release. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Ronbo Posted September 24, 2018 Report Share Posted September 24, 2018 Those that can’t use the plate with the rt hitch, do you have a Brinkley head? I have one of the the heads Henry made and it works fine with a plate. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
SWharton Posted September 24, 2018 Report Share Posted September 24, 2018 Couldn't you get a standing block and sand it down a bit? Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 24, 2018 Report Share Posted September 24, 2018 15 minutes ago, Ronbo said: Those that can’t use the plate with the rt hitch, do you have a Brinkley head? I have one of the the heads Henry made and it works fine with a plate. It was a standard Binkley head and from the time frame, my was probably from the batches coming in from China. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
GlennWest Posted September 24, 2018 Report Share Posted September 24, 2018 Mine also has the standard Brinkley head. Mine was make just before Henry got his knee surgery. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Ronbo Posted September 24, 2018 Report Share Posted September 24, 2018 I have one of his first super Brinkley. I use a normal thickness Teflon pad. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 24, 2018 Report Share Posted September 24, 2018 An ET, with a Super Binkley, isn't a Binkley, that the OP has on his Trailer Saver hitch. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Broncohauler Posted September 24, 2018 Author Report Share Posted September 24, 2018 Thanks guys. And thanks Phil for the link. I’m going to try out the 1/8 inch one Phil linked at Amazon. I’ll let you know the results. Link to comment Share on other sites More sharing options...
orca Posted September 24, 2018 Report Share Posted September 24, 2018 I have never tried this myself but another RVr told me that in a pinch you can use the bottom of a 5 gal pail. I don't know how durable they would be but they are cheap and plentyfull. 2004 Freightliner m2 106 2015 DRV lx450 Fullhouse 2019 Indian Springfield 2014 Yamaha 950 V-Star Link to comment Share on other sites More sharing options...
