solo318 Posted September 18, 2018 Report Share Posted September 18, 2018 We spent the weekend in Chattanooga/lookout mountain campground. Everyone we met was nice. (well not everyone. Our neighbor was a middle aged angry woman who refused to clean up after herself or her dogs). The RV was well liked and well received. The campsite itself was TERRIBLE but the park was nice and clean and the pool was fantastic. The staff was excellent and the owner was also. The camp site was curved. Although it was long enough it was hard to find a spot that would get everything off the grass. ( I know, First world Problems). The sight was gravel and every time the jacks took the weight of the rv off the rear wheels everything would "slide" down the hill a little bit. I finally just put one side on wood and used the other side jacks to even it out. Is there a better way? Click For Full-Size Image. Link to comment Share on other sites More sharing options...
jenandjon Posted September 18, 2018 Report Share Posted September 18, 2018 I keep some 2X8 boards about 3 or 4 ft long. when I need to level side to side I back the trailer up on them. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 19, 2018 Report Share Posted September 19, 2018 Are you using the plastic lego style blocks under the jacks? If you are, that is a common problem. What I did was buy a horse stall mat from Tractor Supply and cut it into strips then blocks. I ended up with 12x12 squares. Since these are rubber, the jacks don't slide. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Vegas Teacher Posted September 19, 2018 Report Share Posted September 19, 2018 13 hours ago, Alie&Jim's Carrilite said: Are you using the plastic lego style blocks under the jacks? If you are, that is a common problem. What I did was buy a horse stall mat from Tractor Supply and cut it into strips then blocks. I ended up with 12x12 squares. Since these are rubber, the jacks don't slide. I like that idea. Link to comment Share on other sites More sharing options...
solo318 Posted September 19, 2018 Author Report Share Posted September 19, 2018 16 hours ago, Alie&Jim's Carrilite said: Are you using the plastic lego style blocks under the jacks? If you are, that is a common problem. What I did was buy a horse stall mat from Tractor Supply and cut it into strips then blocks. I ended up with 12x12 squares. Since these are rubber, the jacks don't slide. That's a brilliant idea. What did you cut it with? Click For Full-Size Image. Link to comment Share on other sites More sharing options...
DesertMiner Posted September 19, 2018 Report Share Posted September 19, 2018 These work pretty good.........https://rvsnappad.com/ Link to comment Share on other sites More sharing options...
rickeieio Posted September 19, 2018 Report Share Posted September 19, 2018 We're old school. Level side x side with wood scraps before unhooking. Not a big deal if you forget to pick them up. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 19, 2018 Report Share Posted September 19, 2018 5 hours ago, solo318 said: That's a brilliant idea. What did you cut it with? I used a straight edge and a razor knife. Scored as deep as I could and made several passes. If you let the edge hang off a table, it will open the cut and you can make your second pass. If you have access to a table saw or jig saw, sawsall, band saw, those would be faster. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted September 20, 2018 Report Share Posted September 20, 2018 I have lived in Chattanooga since 1985 and full timed since 2010 with much time still spent in the area. I have never heard of a "Chattanooga/Lookout Mountain Campground". Can you be more specific? Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
RandyA Posted September 21, 2018 Report Share Posted September 21, 2018 On 9/19/2018 at 12:23 PM, solo318 said: That's a brilliant idea. What did you cut it with? Yep, Jim is a pretty smart feller. I made my mud flaps out of the same stuff. The mat I bought was 1/2". I cut them out with a saber saw and a 14 TPI blade. For me that worked well. A circular saw with a plywood blade does not work well. More smoke from burning rubber than chips. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
