John Laninga Posted September 17, 2018 Report Share Posted September 17, 2018 I've had the Mobley system since they first became available, moved the SIM to a United Explore MiFi device almost a year ago. It has worked fine until now. I wanted to check something so I took the SIM card out of the Explore, and since I put it back in I get an error message "SIM not installed" and then to check the SIM card for proper insertion. I tried that multiple times, the Explore won't come up. I checked my ATT app, it shows the United Explore device on my account and it shows it as active. So wondering if anyone had any experience with this error and what I can do about it. Thanks for any help you can give me. ==John 2015 Entegra Aspire 44B diesel pusher with 2017 GMC Acadia Denali toad Web site, albums, blog and more here Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 18, 2018 Report Share Posted September 18, 2018 Have you tried putting the SIM back in the Mobley? You may have damaged one of the contacts in the Explore. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Yarome Posted September 18, 2018 Report Share Posted September 18, 2018 A dirty sim or damaged contact (provided it has been inserted in the right direction... which happens.. ;-)) would be my guess as well. Might try cleaning the SIM contacts with a pencil eraser. If all else fails I would pick up a new SIM from the ATT store... takes all of 5 minutes... and try that next before dealing with the possibility of a damaged SIM reader slot. I don't know how or why but SIM's "do" go bad on occassion... I guess. In the early mobley days I had to have mine replaced for no apparent reason. Hadn't removed it from my mobley and just stopped being able to gain internet access one day. Thought it might be some issue with my account, went into the ATT store, they handed me a new SIM and all has been right with the world since. To note... we have 4 in our family using the mobley/explore setup. Pulled our SIM's during the "caution" period and have since placed them back into our Unite Explore's. All are working flawlessly. To note: SIM/Cellular and all that business isn't much in my wheelhouse so take the above with a grain of salt. Link to comment Share on other sites More sharing options...
Smitty77_7 Posted September 19, 2018 Report Share Posted September 19, 2018 Please close the loop back on this, once you get it sorted out:)! May help other's us down the road:)! Best, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
John Laninga Posted September 20, 2018 Author Report Share Posted September 20, 2018 So far no go. I put the SIM back in my Mobley and got two green lights, which I believe means it is on and on the Internet. However, no SSID is being transmitted, either a known or unknown. Guess I’ll try a few more things and if all else fails visit an ATT store. But I have doubts that anyone working in a retail store knows what a Mobley is. 2015 Entegra Aspire 44B diesel pusher with 2017 GMC Acadia Denali toad Web site, albums, blog and more here Link to comment Share on other sites More sharing options...
Pat & Pete Posted September 20, 2018 Report Share Posted September 20, 2018 Have you tried resetting the Mobley ? This from the user guide : Reset the Mobile Hotspot You can reset the mobile hotspot to its factory settings on the mobile hotspot itself or on the full AT&T Wi-Fi Manager home page. (This is useful if you have lost your Administrator login for the AT&T Wi-Fi Manager home page.) Notes: • If you reset the modem to factory settings, all of your customizations will be lost. • When you reset the mobile hotspot, any currently connected devices will lose access and will have to be reconnected after the mobile hotspot restarts. On the mobile hotspot: Press and hold the Reset Key until the LED 1 indicator turns red (about 7 seconds). After the device has reset, reconnect Wi-Fi devices. On the full AT&T Wi-Fi Manager home page: Log in as Administrator. Click Settings on the navigation menu on the left side. Click Advanced Device Reset. Click Reset Goes around , comes around . Link to comment Share on other sites More sharing options...
John Laninga Posted September 22, 2018 Author Report Share Posted September 22, 2018 I was quite impressed with the store level ATT support I got. Told them my problem, had the SIM card in the United Explore. She got a new card, flashed all the data with a scanner/writer, and re-registered the device. Unit powered up, tested the connection, and all is well. No issues about the Connected Car although I told her I used it in my RV, which of course is true. I found the support to be easy, quick, thorough and maybe best of all no charge. Go Connected Car! 2015 Entegra Aspire 44B diesel pusher with 2017 GMC Acadia Denali toad Web site, albums, blog and more here Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 23, 2018 Report Share Posted September 23, 2018 Glad you got it straightened out with so little fuss, John! Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Smitty77_7 Posted September 25, 2018 Report Share Posted September 25, 2018 Also good to hear they did not bother you any on the SIM being in the Unite Explore. I've had mine in for two years now. Felt so comfortable, perhaps a mistake, that I went ahead and canceled my second Mobley account. Kept the Mobley as a back up, but with the other options we have available to us, we just did not need the second Mobley's data - so canceled. (I'd kept for about a year, in case ATT did not like my SIM from what I call Mobley #1 in the Unite Explore, and canceled that line on me. If they had, I'd have had Mobley #2's line, and would have reverted to using Mobley #2.) I did as the ATT tech helping us in San Diego about 8 months ago, about the Car Connect SIM's being used in other devices. He was up on the Car Connect (Which most ATT Store Employees that I've encountered were not.), and said that he had one in the newer Netgear Nighthawk device, as his primary Data provider at home. So that also gave me another level of comfort. Glad you're back up and running:)! Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 26, 2018 Report Share Posted September 26, 2018 As far as I've seen on the cell related forums, Howards, etc., it still looks like the only Mobley SIM swappers that have had any push back from AT&T have been those putting the SIM in phones instead of another hotspot. It seems that as long as we use the SIM in the same device class as the Mobley, we're good with AT&T. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
John Laninga Posted October 8, 2018 Author Report Share Posted October 8, 2018 After the success I had with ATT the problem resurfaced. I had the United Explore off, since the coach was in for service. When I got it back and turned it back on once again I got the SIM error. I took it to a different ATT store, the manager said that it probably was the United Explore causing the problem. Only suggestion was to get a new router. So when I got back I put the SIM back in the Mobley, did a factory reset, and reset passwords etc. my Mobley is running fine with no rebooting after 2 hours (but it is still on 1.0.1 software). So my problem was the United Explore, not the SIM card or my account. John 2015 Entegra Aspire 44B diesel pusher with 2017 GMC Acadia Denali toad Web site, albums, blog and more here Link to comment Share on other sites More sharing options...
Dutch_12078 Posted October 8, 2018 Report Share Posted October 8, 2018 It's good you at least know where the problems is now, John. If your Mobley does update, as it likely will at some point, the preliminary evidence seems to be that as long as the voltage powering the device stays at 13 volts or so, the Mobley will not shut down since it will think the engine is still running. I'm still running my SIM in my Unite, so I haven't done any testing of that though. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Smitty77_7 Posted October 10, 2018 Report Share Posted October 10, 2018 Please do keep us updated as things change. Unite Explore being the problem seems a bit odd(?). Now you're going to make me do some looking to see what software version is reflected on mu Unite Explore with the Mobley SIM installed. (Knocking on wood, no similar problems at this time:)!) Best to you, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Dutch_12078 Posted October 10, 2018 Report Share Posted October 10, 2018 From what I've seen on the cell forums, the Unite series hotspots are one of the most popular for Mobley SIM swaps. I think the only other failures I've seen mentioned was a DOA refurbished unit bought on eBay and a damaged SIM. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
